[MOAB-dev] ray_intersect_sets function
    hongjun at mcs.anl.gov
    Sat Mar 13 21:57:25 CST 2010
Thank you for your reply.
I used "min_tolerance_intersections" as 20000 which is large enough.
I think "ray_intersect_sets" finds an intersected box of leaf tree node and then, triangles only in the leaf tree node are checked for intersection again.
"min_tolerance_intersections" is used just for the latter triangle intersection check as a maximum number of intersection checks.
Therefore, only one intersection per geometry surface meshset is found.
If it is correct and it is not intended, I will change it.
Thanks.
Hong-Jun
----- Original Message -----
To: hongjun at mcs.anl.gov, moab-dev at mcs.anl.gov
Sent: Friday, March 12, 2010 6:23:11 PM GMT -06:00 US/Canada Central
Subject: Re: [MOAB-dev] ray_intersect_sets function
Hi Hong-jun,
If I remember correctly (which I may not), this function returns up to min_tolerance_intersections outside of the tolerance distance, and all intersections inside of the tolerance distance. This is an optimization for particle tracking where in general, only the closest intersection is desired.
If you want all intersections, set the tolerance larger than the maximum extent of your geometry. Alternatively, set min_tolerance_intersections to a large number.
Brandon
From: "hongjun at mcs.anl.gov" <hongjun at mcs.anl.gov>
To: moab-dev at mcs.anl.gov
Sent: Fri, March 12, 2010 5:30:44 PM
Subject: [MOAB-dev] ray_intersect_sets function
Hi! All
I have a question about ray tracing function,
MBOrientedBoxTreeTool::ray_intersect_sets(
                                    std::vector<double>& distances_out,
                                    std::vector<MBEntityHandle>& sets_out,
                                    std::vector<MBEntityHandle>& facets_out,
                                    MBEntityHandle root_set,
                                    double tolerance,
                                    unsigned min_tolerace_intersections,
                                    const double ray_point[3],
                                    const double unit_ray_dir[3],
                                    const double* ray_length,
                                    TrvStats* accum );
When I use this function, it just returns one intersection distance/set/facet for sphere or curved surfaces.
Is it a bug or is it intended?
Otherwise, am I using incorrectly?
Could any body give me some advices for me?
Thanks.
Hong-Jun
