[MOAB-dev] buildbot failure in Fathom on moab-par
    moab-dev at mcs.anl.gov
    Sat Mar 13 00:08:22 CST 2010
The Fathomatic has detected a failed build of moab-par on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/95
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
Warning: acis file has sequence numbers!
Running test_write_shared_sets ...
Running test_var_length_parallel ...
Running test_read_elements ...
Running test_read_elements_by_rank ...
Running test_read_tags ...
Running test_read_global_tags ...
Running test_read_sets ...
PASS: parallel_hdf5_test
PASS: mhdf_parallel
01:   0.00: Generating mesh
00:   0.00: Generating mesh
Using default interval count: 2
00:   0.00: Resolving shared entities
01:   0.00: Resolving shared entities
00:   0.00: Beginning parallel write
01:   0.01: Beginning parallel write
Wrote 16 hexes in 0.02 seconds.
01:   0.05: Finalizing MPI
00:   0.02: Removing written file
Wall time: generate: 0.000530005, resovle shared: 0.00850701, write_file: 0.163152
00:   0.02: Finalizing MPI
PASS: parallel_write_test
All 8 tests passed
Making check in oldinc
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-par/build/test/oldinc'
make  test_oldinc
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-par/build/test/oldinc'
mpiCC -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/home/jvporter/include -isystem /home/jvporter/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -I../../src -I../../src/parallel -I../../src/oldinc -I../../src -I../../src/parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -Wall -pipe -O2 -DNDEBUG -MT test_oldinc.o -MD -MP -MF .deps/test_oldinc.Tpo -c -o test_oldinc.o test_oldinc.cpp
In file included from test_oldinc.cpp:45:
../../src/oldinc/MBParallelData.hpp:4:24: error: MBFoward.hpp: No such file or directory
test_oldinc.cpp: In function 'int main()':
test_oldinc.cpp:72: warning: unused variable 'read_ptr'
test_oldinc.cpp:73: warning: unused variable 'write_ptr'
test_oldinc.cpp:74: warning: unused variable 'read_util'
test_oldinc.cpp:75: warning: unused variable 'write_util'
test_oldinc.cpp:76: warning: unused variable 'io_set_ptr'
sincerely,
 -The Fathomatic
