[MOAB-dev] r3603 - MOAB/trunk/src/io
iulian at mcs.anl.gov
Fri Mar 12 13:25:45 CST 2010
Author: iulian
Date: 2010-03-12 13:25:45 -0600 (Fri, 12 Mar 2010)
New Revision: 3603
Modified:
MOAB/trunk/src/io/ReadSmf.cpp
MOAB/trunk/src/io/ReadSmf.hpp
Log:
eliminate some compile warnings
Modified: MOAB/trunk/src/io/ReadSmf.cpp
--- MOAB/trunk/src/io/ReadSmf.cpp 2010-03-12 19:19:36 UTC (rev 3602)
+++ MOAB/trunk/src/io/ReadSmf.cpp 2010-03-12 19:25:45 UTC (rev 3603)
@@ -21,7 +21,6 @@
#include <assert.h>
#include <stdlib.h>
-#include <string.h>
#include <iostream>
#include "ReadSmf.hpp"
@@ -54,7 +53,7 @@
{ "scale", &ReadSmf::scale },
{ "rot", &ReadSmf::rot },
- { NULL, NULL }
+ { "", NULL }
MBAffineXform mat_from_args(std::vector<std::string> & argv)
@@ -292,8 +291,8 @@
cmd_entry *entry = &read_cmds[0];
bool handled = 0;
- while( entry->name && !handled )
- if( streq(entry->name, cmd) )
+ while( entry->name.length() && !handled )
+ if( streq(entry->name.c_str() , cmd) )
(this->*(entry->cmd))(argv);
handled = 1;
@@ -339,7 +338,7 @@
int vert[3];
- for(int i=0; i<argv.size(); i++)
+ for(unsigned int i=0; i<argv.size(); i++)
vert[i] = atoi(argv[i].c_str());
state->face(vert, ivar);
Modified: MOAB/trunk/src/io/ReadSmf.hpp
--- MOAB/trunk/src/io/ReadSmf.hpp 2010-03-12 19:19:36 UTC (rev 3602)
+++ MOAB/trunk/src/io/ReadSmf.hpp 2010-03-12 19:25:45 UTC (rev 3603)
@@ -58,7 +58,7 @@
typedef void (ReadSmf::*read_cmd)( std::vector<std::string> & argv);
- struct cmd_entry { char *name; read_cmd cmd; };
+ struct cmd_entry { std::string name; read_cmd cmd; };
void init();
protected:
