[MOAB-dev] MOAB/trunk build failure
    Dmitry Karpeev
    karpeev at mcs.anl.gov
    Thu Mar 11 20:15:07 CST 2010
Beats me: I just checked out that version.
Here's the command and the output:
svn co https://svn.mcs.anl.gov/repos/ITAPS/MOAB/trunk ${FATHOM_DIR}/moab/trunk
Checked out revision 3596.
This is followed by:
Running autoreconf -fi
Putting files in AC_CONFIG_AUX_DIR, `config'.
export CC=${MPI2_PREFIX}/bin/mpicc
export CXX=${MPI2_PREFIX}/bin/mpicxx
./configure --with-mpi=${MPI2_PREFIX} --with-netcdf=${NETCDF_PREFIX}
--with-hdf5=${HDF5_PREFIX} --with-zlib=${ZLIB_PREFIX}
--with-szip=${SZIP_PREFIX} --disable-debug 2>&1 | tee configure.log
make 2>&1 | tee make.log
which produces the error I sent earlier.
I don't specify at --prefix at configure time, but I don't see how
that would produce the error I observe.
Thanks.
Dmitry.
On Thu, Mar 11, 2010 at 3:06 PM, Jason Kraftcheck <kraftche at cae.wisc.edu> wrote:
> Dmitry Karpeev wrote:
>> I just tried building MOAB/trunk on cosmea and failed at the make stage.
>> configure and make logs are attached.
>> Might that be due to the recent source code rearrangements?
> It looks like something did not get updated correctly in your source tree.
> Build fails with:
> MBCore.cpp(55): catastrophic error: could not open source file "WriteHDF5.hpp"
>  #  include "WriteHDF5.hpp"
> Build the compilation command includes:
>  -I./io
> which is where WriteHDF5.hpp should be.  So why do you not have a copy of
> WriteHDF5.hpp at that location?
> - jason
