[MOAB-dev] r3598 - MOAB/trunk/examples/SetsNTags
Rajeev Jain
jain at mcs.anl.gov
Thu Mar 11 17:44:58 CST 2010
There is some more bug in this program/logic that I wasn't able to fix.
Attached sc.cub has nodesets which must appear as Dirichlet sets, but they don't. If material sets are not present then Dirichlet sets (nodesets) appear, this time Neumann sets don't appear. I think this has to do with the way file is parsed..
Rajeev
To: moab-dev at mcs.anl.gov
Sent: Thursday, March 11, 2010 17:38:55
Subject: [MOAB-dev] r3598 - MOAB/trunk/examples/SetsNTags
Author: jain
Date: 2010-03-11 17:38:55 -0600 (Thu, 11 Mar 2010)
New Revision: 3598
Modified:
MOAB/trunk/examples/SetsNTags/SetsNTags.cpp
Log:
o Cleared the number of entities before the loop continues
Modified: MOAB/trunk/examples/SetsNTags/SetsNTags.cpp
--- MOAB/trunk/examples/SetsNTags/SetsNTags.cpp 2010-03-11 21:04:03 UTC (rev 3597)
+++ MOAB/trunk/examples/SetsNTags/SetsNTags.cpp 2010-03-11 23:38:55 UTC (rev 3598)
@@ -41,6 +41,7 @@
std::cout << tag_nms[i] << " " << set_id << " has "
<< set_ents.size() << " entities." << std::endl;
+ set_ents.clear();
Get your preferred Email name!
Now you can @ymail.com and @rocketmail.com.
http://mail.promotions.yahoo.com/newdomains/aa/
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100311/cdaae022/attachment-0001.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100311/cdaae022/attachment-0001.obj>
