[MOAB-dev] r3595 - MOAB/trunk/test/parallel
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Thu Mar 11 13:48:49 CST 2010
Author: kraftche
Date: 2010-03-11 13:48:49 -0600 (Thu, 11 Mar 2010)
New Revision: 3595
Modified:
   MOAB/trunk/test/parallel/Makefile.am
Log:
more include path fixes
Modified: MOAB/trunk/test/parallel/Makefile.am
--- MOAB/trunk/test/parallel/Makefile.am	2010-03-11 19:48:23 UTC (rev 3594)
+++ MOAB/trunk/test/parallel/Makefile.am	2010-03-11 19:48:49 UTC (rev 3595)
@@ -24,7 +24,6 @@
         $(HDF5_TESTS)
 if PARALLEL_HDF5
-  AM_CPPFLAGS += -I$(top_srcdir)/mhdf/include
   HDF5_TESTS = parallel_hdf5_test mhdf_parallel parallel_write_test
 else
   HDF5_TESTS =
@@ -35,6 +34,7 @@
 pcomm_unit_SOURCES = pcomm_unit.cpp
 parallel_hdf5_test_SOURCES = parallel_hdf5_test.cc
 mhdf_parallel_SOURCES = mhdf_parallel.c
+mhdf_parallel_CPPFLAGS = $(AM_CPPFLAGS) $(CPPFLAGS) -I$(top_srcdir)/src/io/mhdf/include
 parallel_unit_tests_SOURCES = parallel_unit_tests.cpp
 parallel_write_test_SOURCES = parallel_write_test.cc
 uber_parallel_test_SOURCES = uber_parallel_test.cpp
