[MOAB-dev] r3582 - in MOAB/trunk: . src src/io test test/io tools tools/dagmc
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Wed Mar 10 13:50:12 CST 2010
Author: kraftche
Date: 2010-03-10 13:50:12 -0600 (Wed, 10 Mar 2010)
New Revision: 3582
Added:
   MOAB/trunk/src/CMakeLists.txt
   MOAB/trunk/src/io/CMakeLists.txt
   MOAB/trunk/test/CMakeLists.txt
   MOAB/trunk/test/io/CMakeLists.txt
   MOAB/trunk/tools/CMakeLists.txt
Modified:
   MOAB/trunk/CMakeLists.txt
   MOAB/trunk/tools/dagmc/CMakeLists.txt
Log:
code rearranging part 5 of 5: update cmake build
This doesn't fix many of the existing issues with the cmake build
(missing tests, missing tools, missing options, etc.)  It does allow
those things that did build before the rearranging of the source
code to continue to builed.
Modified: MOAB/trunk/CMakeLists.txt
--- MOAB/trunk/CMakeLists.txt	2010-03-10 18:25:50 UTC (rev 3581)
+++ MOAB/trunk/CMakeLists.txt	2010-03-10 19:50:12 UTC (rev 3582)
@@ -8,7 +8,10 @@
   enable_testing()
   list (APPEND CMAKE_MODULE_PATH "${MOAB_SOURCE_DIR}/config")
+  include (config/GetAcInitVersion.cmake)
+  # enable_language( Fortran )
   get_ac_init_version()
   set ( MOAB_VERSION_MAJOR  "${MAJOR_VERSION}"  )
   set ( MOAB_VERSION_MINOR  "${MINOR_VERSION}"  )
@@ -81,7 +84,7 @@
     set ( MOAB_HAVE_PTRDIFF_T ${HAVE_PTRDIFF_T} )
   endif ( NOT MOAB_FORCE_64_BIT_HANDLES AND NOT MOAB_FORCE_32_BIT_HANDLES )
-  try_compile( TEMPLATE_DEFS_INCLUDED ${MOAB_BINARY_DIR} ${MOAB_SOURCE_DIR}/cmake/TemplateSpecialization.cxx OUTPUT_VARIABLE BLORT )
+  try_compile( TEMPLATE_DEFS_INCLUDED ${MOAB_BINARY_DIR} ${MOAB_SOURCE_DIR}/config/TemplateSpecialization.cxx OUTPUT_VARIABLE BLORT )
   if ( TEMPLATE_DEFS_INCLUDED )
     set ( MOAB_DEFINES "${MOAB_DEFINES} -DTEMPLATE_DEFS_INCLUDED" )
   endif ( TEMPLATE_DEFS_INCLUDED )
@@ -93,266 +96,11 @@
   option ( MOAB_USE_MPI    "Should MOAB be compiled with MPI support?"       OFF )
   option ( MOAB_USE_HDF    "Include HDF I/O in the build?"                   OFF )
   option ( MOAB_USE_NETCDF "Include NetCDF support (ExodusII) in the build?" OFF )
-  # Documentation
-  # Optional tools
-  option ( MOAB_BUILD_MBCONVERT    "Build the MOAB mesh converter tool?"  ON )
-  option ( MOAB_BUILD_HEXMODOPS    "Build the hexahedral modops tool?"    ON )
-  option ( MOAB_BUILD_MBCHACO      "Build MOAB Chaco interface?"          OFF )
-  option ( MOAB_BUILD_MBPERF       "Build the MOAB performance tool?"     ON )
-  option ( MOAB_BUILD_QVDUAL       "Build the qvdual application?"        OFF )
-  option ( MOAB_BUILD_MBSIZE       "Build the mbsize tool?"               ON )
-  option ( MOAB_BUILD_MBSKIN       "Build the mbskin tool?"               ON )
-  option ( MOAB_BUILD_MBTAGPROP    "Build the mbtagprop tool?"            ON )
-  option ( MOAB_BUILD_SPHEREDECOMP "Build the sphere decomposition tool?" ON )
-  option ( MOAB_BUILD_MBSURFPLOT   "Build the mbsurfplot application?"    ON )
-  option ( MOAB_BUILD_MBZOLTAN     "Build the mbzoltan partitioner?"      OFF )
-  option ( MOAB_BUILD_DAGMC        "Build the dagmc tool?"                ON )
-  option ( MOAB_BUILD_MBCOUPLER    "Build the mesh coupler tool?"         ON )
   # iMesh
   option ( MOAB_BUILD_IMESH        "Build the iMesh interface?"           ON )
-  # MOAB Library
-  set ( MOAB_LIB_SRCS
-    AEntityFactory.cpp
-    BSPTreePoly.cpp
-    DualTool.cpp
-    EntitySequence.cpp
-    ExoIIUtil.cpp
-    FileOptions.cpp
-    FileTokenizer.cpp
-    GeomTopoTool.cpp
-    GmshUtil.cpp
-    HigherOrderFactory.cpp
-    HomXform.cpp
-    MBAdaptiveKDTree.cpp
-    MBAffineXform.cpp
-    MBAlloc.cpp
-    MBAxisBox.cpp
-    MBBits.cpp
-    MBBSPTree.cpp
-    MBCN.cpp
-    MBCartVect.cpp
-    MBMatrix3.cpp
-    MBCore.cpp
-    MBFactory.cpp
-    MBGeomUtil.cpp
-    MBMeshSet.cpp
-    MBOrientedBox.cpp
-    MBOrientedBoxTreeTool.cpp
-    MBRange.cpp
-    MBRangeSeqIntersectIter.cpp
-    MBReadUtil.cpp
-    MBReaderWriterSet.cpp
-    MBSkinner.cpp
-    MBSysUtil.cpp
-    MBUtil.cpp
-    MBWriteUtil.cpp
-    MeshSetSequence.cpp
-    MeshTopoUtil.cpp
-    PolyElementSeq.cpp
-    ReadABAQUS.cpp
-    ReadGmsh.cpp
-    ReadIDEAS.cpp
-    ReadMCNP5.cpp
-    ReadNASTRAN.cpp
-    ReadSms.cpp
-    ReadSTL.cpp
-    ReadTetGen.cpp
-    ReadVtk.cpp
-    ScdElementData.cpp
-    ScdVertexData.cpp
-    SequenceData.cpp
-    SequenceManager.cpp
-    SparseTagSuperCollection.cpp
-    SparseTagCollection.cpp
-    StructuredElementSeq.cpp
-    SweptElementData.cpp
-    SweptElementSeq.cpp
-    SweptVertexData.cpp
-    TagInfo.cpp
-    TagServer.cpp
-    Tqdcfr.cpp
-    TypeSequenceManager.cpp
-    UnstructuredElemSeq.cpp
-    VertexSequence.cpp
-    VtkUtil.cpp
-    WriteAns.cpp
-    WriteGMV.cpp
-    WriteGmsh.cpp
-    WriteSTL.cpp
-    WriteTemplate.cpp
-    WriteVtk.cpp
-  include_directories(
-    ${MOAB_SOURCE_DIR}
-    ${MOAB_BINARY_DIR}
-  if ( MOAB_USE_NETCDF )
-    find_package( NetCDF )
-    if ( NetCDF_FOUND )
-      set ( MOAB_DEFINES "${MOAB_DEFINES} -DNETCDF_FILE" )
-        ${MOAB_LIB_SRCS}
-        ReadNCDF.cpp
-        WriteNCDF.cpp
-        WriteSLAC.cpp
-        ${NetCDF_INCLUDE_DIRECTORIES}
-    endif ( NetCDF_FOUND )
-  endif ( MOAB_USE_NETCDF )
-  if ( MOAB_USE_HDF )
-    # HDF5
-    find_package( HDF5 )
-    if ( HDF5_FOUND )
-      set ( MOAB_DEFINES "${MOAB_DEFINES} -DHDF5_FILE" )
-      check_function_exists( H5Pset_fapl_mpio MOAB_HDF_HAVE_PARALLEL )
-        ${MOAB_LIB_SRCS}
-        ReadHDF5.cpp
-        WriteHDF5.cpp
-        ${HDF5_INCLUDE_DIRECTORIES}
-        ${MOAB_SOURCE_DIR}/mhdf/include
-      add_subdirectory( mhdf )
-    endif ( HDF5_FOUND )
-  endif ( MOAB_USE_HDF )
-  if ( MOAB_USE_MPI )
-    find_package( MPI )
-    # CMake FindMPI script is sorely lacking:
-    if ( MPI_LIBRARY AND MPI_INCLUDE_PATH )
-      set( MPI_FOUND 1 )
-    endif ( MPI_LIBRARY AND MPI_INCLUDE_PATH )
-    if ( MPI_FOUND )
-      set ( MOAB_DEFINES "${MOAB_DEFINES} -DUSE_MPI" )
-        ${MPI_INCLUDE_PATH}
-        ${MOAB_SOURCE_DIR}/parallel
-    endif ( MPI_FOUND )
-  endif ( MOAB_USE_MPI )
-  set_source_files_properties( ${MOAB_LIB_SRCS}
-    COMPILE_FLAGS "-DIS_BUILDING_MB ${MOAB_DEFINES}"
-  add_library( MOAB
-    ${MOAB_LIB_SRCS}
-  if ( MOAB_USE_MPI AND MPI_FOUND )
-    add_subdirectory( refiner )
-    include_directories( ${MOAB_SOURCE_DIR}/refiner )
-    target_link_libraries( MOAB MOABrefiner )
-  endif ( MOAB_USE_MPI AND MPI_FOUND )
-  if ( MOAB_USE_HDF AND HDF5_FOUND )
-      mhdf
-      ${HDF5_LIBRARIES}
-  endif ( MOAB_USE_HDF AND HDF5_FOUND )
-    add_subdirectory( parallel )
-    target_link_libraries( MOAB MOABpar )
-  if ( MOAB_USE_NETCDF AND NetCDF_FOUND )
-      ${NetCDF_LIBRARIES}
-  endif ( MOAB_USE_NETCDF AND NetCDF_FOUND )
-  ## Tools/libraries dependent on MOAB:
-  # Zoltan
-  # Chaco
-  # QVDual
-  if ( MOAB_BUILD_QVDUAL )
-    add_subdirectory( tools/qvdual )
-  endif ( MOAB_BUILD_QVDUAL )
-  # CGM
-  if ( MOAB_BUILD_DAGMC )
-    add_subdirectory( tools/dagmc )
-  endif ( MOAB_BUILD_DAGMC )
-  # MBCoupler
-  if ( MOAB_USE_MPI AND MPI_FOUND AND MOAB_BUILD_MBCOUPLER )
-    add_subdirectory( tools/mbcoupler )
-  endif ( MOAB_USE_MPI AND MPI_FOUND AND MOAB_BUILD_MBCOUPLER )
-  # iMesh Babel
-  if ( MOAB_BUILD_IMESH )
-    option( MOAB_IMESH_FORTRAN "Should MOAB include iMesh FORTRAN bindings?" OFF )
-    add_subdirectory( tools/iMesh )
-  endif ( MOAB_BUILD_IMESH )
-  if ( MOAB_IMESH_FORTRAN )
-    enable_language( Fortran )
-    # This determines FORTRAN calling conventions and defines FC_FUNC and FC_FUNC_
-    # to macros which can be used from C to call FORTRAN.
-    #include( ${MOAB_SOURCE_DIR}/cmake/FortranCallingConvention.cmake)
-  endif ( MOAB_IMESH_FORTRAN )
+  add_subdirectory( src )
+  add_subdirectory( tools )
+  add_subdirectory( test )
-  include( ${MOAB_SOURCE_DIR}/cmake/AutoconfHeader.cmake )
-  # Define some more variables so they will be substituted properly in the autoconf files.
-  set( MB_VERSION        "\"${MOAB_VERSION}\"" )
-  set( MB_VERSION_MAJOR  ${MOAB_VERSION_MAJOR} )
-  set( MB_VERSION_MINOR  ${MOAB_VERSION_MINOR} )
-  if ( DEFINED MOAB_VERSION_PATCH )
-    set( MB_VERSION_PATCH  ${MOAB_VERSION_PATCH} )
-  endif ( DEFINED MOAB_VERSION_PATCH )
-  set( MB_VERSION_STRING "\"${MOAB_VERSION_STRING}\"" )
-  autoconf_header( ${MOAB_SOURCE_DIR}/MBVersion.h.in ${MOAB_BINARY_DIR}/MBVersion.h )
-  autoconf_header( ${MOAB_SOURCE_DIR}/MBEntityHandle.h.in ${MOAB_BINARY_DIR}/MBEntityHandle.h )
-  file( WRITE ${MOAB_BINARY_DIR}/MBCN_protos.h "" )
-# Testing
-  add_executable( moab_test MBTest.cpp )
-  target_link_libraries( moab_test MOAB )
-  add_test( TestMOAB ${EXECUTABLE_OUTPUT_PATH}/moab_test -nostress )
-  # FIXME: moab_test depends on: test/mb_big_test.g test/cell1.gen test/cell2.gen
-  add_executable( seq_man_test TestTypeSequenceManager.cpp )
-  target_link_libraries( seq_man_test MOAB )
-  set_source_files_properties( TestTypeSequenceManager.cpp
-    COMPILE_FLAGS "-DIS_BUILDING_MB ${MOAB_DEFINES}" )
-   add_test( TestTypeSequenceManager ${EXECUTABLE_OUTPUT_PATH}/seq_man_test )
-  add_executable( homxform_test HomXform.cpp )
-  set_source_files_properties( HomXform.cpp
-    COMPILE_FLAGS "-DTEST ${MOAB_DEFINES}" )
-  target_link_libraries( homxform_test MOAB )
-  add_test( TestHomXform ${EXECUTABLE_OUTPUT_PATH}/homxform_test )
-  add_executable( scdseq_test scdseq_test.cpp )
-  set_source_files_properties( scdseq_test.cpp
-  target_link_libraries( scdseq_test MOAB )
-  add_test( TestSCDSeq ${EXECUTABLE_OUTPUT_PATH}/scdseq_test )
-  add_executable( tqdcfr Tqdcfr.cpp )
-  set_source_files_properties( Tqdcfr.cpp
-    COMPILE_FLAGS "-DTEST -DIS_BUILDING_MB ${MOAB_DEFINES}" )
-  target_link_libraries( tqdcfr MOAB )
-  add_test( TestTQDCFR ${EXECUTABLE_OUTPUT_PATH}/tqdcfr )
-  add_executable( bsp_tree_test bsp_tree_test.cpp )
-  set_source_files_properties( bsp_tree_test.cpp
-  target_link_libraries( bsp_tree_test MOAB )
-  add_test( TestBSPTree ${EXECUTABLE_OUTPUT_PATH}/bsp_tree_test )
Copied: MOAB/trunk/src/CMakeLists.txt (from rev 3579, MOAB/trunk/CMakeLists.txt)
--- MOAB/trunk/src/CMakeLists.txt	                        (rev 0)
+++ MOAB/trunk/src/CMakeLists.txt	2010-03-10 19:50:12 UTC (rev 3582)
@@ -0,0 +1,107 @@
+  # MOAB Library
+  set ( MOAB_LIB_SRCS
+    AEntityFactory.cpp
+    BitTagServer.cpp
+    BSPTreePoly.cpp
+    DualTool.cpp
+    EntitySequence.cpp
+    FileOptions.cpp
+    GeomTopoTool.cpp
+    HigherOrderFactory.cpp
+    HomXform.cpp
+    MBAdaptiveKDTree.cpp
+    MBAffineXform.cpp
+    MBAxisBox.cpp
+    MBBSPTree.cpp
+    MBCN.cpp
+    MBCartVect.cpp
+    MBMatrix3.cpp
+    MBCore.cpp
+    MBFactory.cpp
+    MBGeomUtil.cpp
+    MBMeshSet.cpp
+    MBOrientedBox.cpp
+    MBOrientedBoxTreeTool.cpp
+    MBRange.cpp
+    MBRangeSeqIntersectIter.cpp
+    MBReadUtil.cpp
+    MBReaderWriterSet.cpp
+    MBSkinner.cpp
+    MBSysUtil.cpp
+    MBUtil.cpp
+    MBWriteUtil.cpp
+    MeshSetSequence.cpp
+    MeshTopoUtil.cpp
+    PolyElementSeq.cpp
+    ScdElementData.cpp
+    ScdVertexData.cpp
+    SequenceData.cpp
+    SequenceManager.cpp
+    SparseTagSuperCollection.cpp
+    SparseTagCollection.cpp
+    StructuredElementSeq.cpp
+    SweptElementData.cpp
+    SweptElementSeq.cpp
+    SweptVertexData.cpp
+    TagInfo.cpp
+    TagServer.cpp
+    TypeSequenceManager.cpp
+    UnstructuredElemSeq.cpp
+    VertexSequence.cpp
+  include_directories(
+    ${MOAB_SOURCE_DIR}/src
+    ${MOAB_BINARY_DIR}/src
+    ${MOAB_SOURCE_DIR}/src/io
+    ${MOAB_BINARY_DIR}/src/io
+    ${MOAB_SOURCE_DIR}/src/moab
+    ${MOAB_BINARY_DIR}/src/moab
+    ${MOAB_SOURCE_DIR}/src/io/moab
+    ${MOAB_BINARY_DIR}/src/io/moab
+  if ( MOAB_USE_MPI )
+    find_package( MPI )
+    # CMake FindMPI script is sorely lacking:
+    if ( MPI_LIBRARY AND MPI_INCLUDE_PATH )
+      set( MPI_FOUND 1 )
+    endif ( MPI_LIBRARY AND MPI_INCLUDE_PATH )
+    if ( MPI_FOUND )
+      set ( MOAB_DEFINES "${MOAB_DEFINES} -DUSE_MPI" )
+        ${MPI_INCLUDE_PATH}
+        ${MOAB_SOURCE_DIR}/parallel
+    endif ( MPI_FOUND )
+  endif ( MOAB_USE_MPI )
+  set_source_files_properties( ${MOAB_LIB_SRCS}
+    COMPILE_FLAGS "-DIS_BUILDING_MB ${MOAB_DEFINES}"
+  add_library( MOAB
+    ${MOAB_LIB_SRCS}
+  add_subdirectory( io )
+  target_link_libraries( MOAB moabio )
+  if ( MOAB_USE_MPI AND MPI_FOUND )
+    add_subdirectory( parallel )
+    target_link_libraries( MOAB MOABpar )
+  endif ( MOAB_USE_MPI AND MPI_FOUND )
+  include( ${MOAB_SOURCE_DIR}/config/AutoconfHeader.cmake )
+  # Define some more variables so they will be substituted properly in the autoconf files.
+  set( MB_VERSION        "\"${MOAB_VERSION}\"" )
+  set( MB_VERSION_MAJOR  ${MOAB_VERSION_MAJOR} )
+  set( MB_VERSION_MINOR  ${MOAB_VERSION_MINOR} )
+  if ( DEFINED MOAB_VERSION_PATCH )
+    set( MB_VERSION_PATCH  ${MOAB_VERSION_PATCH} )
+  endif ( DEFINED MOAB_VERSION_PATCH )
+  set( MB_VERSION_STRING "\"${MOAB_VERSION_STRING}\"" )
+  autoconf_header( ${MOAB_SOURCE_DIR}/src/moab/MBVersion.h.in ${MOAB_BINARY_DIR}/src/moab/MBVersion.h )
+  autoconf_header( ${MOAB_SOURCE_DIR}/src/moab/MBEntityHandle.h.in ${MOAB_BINARY_DIR}/src/moab/MBEntityHandle.h )
+  file( WRITE ${MOAB_BINARY_DIR}/src/MBCN_protos.h "" )
Property changes on: MOAB/trunk/src/CMakeLists.txt
___________________________________________________________________
Added: svn:mergeinfo
Copied: MOAB/trunk/src/io/CMakeLists.txt (from rev 3579, MOAB/trunk/CMakeLists.txt)
--- MOAB/trunk/src/io/CMakeLists.txt	                        (rev 0)
+++ MOAB/trunk/src/io/CMakeLists.txt	2010-03-10 19:50:12 UTC (rev 3582)
@@ -0,0 +1,92 @@
+  # MOAB Library
+  set ( MOABIO_LIB_SRCS
+    ExoIIUtil.cpp
+    FileTokenizer.cpp
+    GmshUtil.cpp
+    ReadABAQUS.cpp
+    ReadGmsh.cpp
+    ReadIDEAS.cpp
+    ReadMCNP5.cpp
+    ReadNASTRAN.cpp
+    ReadSmf.cpp
+    ReadSms.cpp
+    ReadSTL.cpp
+    ReadTetGen.cpp
+    ReadVtk.cpp
+    SMF_State.cpp
+    Tqdcfr.cpp
+    VtkUtil.cpp
+    WriteAns.cpp
+    WriteGMV.cpp
+    WriteGmsh.cpp
+    WriteSTL.cpp
+    WriteSmf.cpp
+    WriteTemplate.cpp
+    WriteVtk.cpp
+    ${MOAB_SOURCE_DIR}/src/parallel
+    ${MOAB_BINARY_DIR}/src/parallel
+    ${MOAB_SOURCE_DIR}/src/parallel/moab
+    ${MOAB_BINARY_DIR}/src/parallel/moab
+  if ( MOAB_USE_NETCDF )
+    find_package( NetCDF )
+    if ( NetCDF_FOUND )
+      set ( MOAB_DEFINES "${MOAB_DEFINES} -DNETCDF_FILE" )
+        ${MOABIO_LIB_SRCS}
+        ReadNCDF.cpp
+        WriteNCDF.cpp
+        WriteSLAC.cpp
+        ${NetCDF_INCLUDE_DIRECTORIES}
+    endif ( NetCDF_FOUND )
+  endif ( MOAB_USE_NETCDF )
+  if ( MOAB_USE_HDF )
+    # HDF5
+    find_package( HDF5 )
+    if ( HDF5_FOUND )
+      set ( MOAB_DEFINES "${MOAB_DEFINES} -DHDF5_FILE" )
+      check_function_exists( H5Pset_fapl_mpio MOAB_HDF_HAVE_PARALLEL )
+        ReadHDF5.cpp
+        WriteHDF5.cpp
+        ${HDF5_INCLUDE_DIRECTORIES}
+        ${MOAB_SOURCE_DIR}/mhdf/include
+      add_subdirectory( mhdf )
+    endif ( HDF5_FOUND )
+  endif ( MOAB_USE_HDF )
+  set_source_files_properties( ${MOABIO_LIB_SRCS}
+  add_library( moabio
+  if ( MOAB_USE_HDF AND HDF5_FOUND )
+    target_link_libraries( moabio
+      mhdf
+      ${HDF5_LIBRARIES}
+  endif ( MOAB_USE_HDF AND HDF5_FOUND )
+  if ( MOAB_USE_NETCDF AND NetCDF_FOUND )
+      ${NetCDF_LIBRARIES}
+  endif ( MOAB_USE_NETCDF AND NetCDF_FOUND )
Property changes on: MOAB/trunk/src/io/CMakeLists.txt
Added: MOAB/trunk/test/CMakeLists.txt
--- MOAB/trunk/test/CMakeLists.txt	                        (rev 0)
+++ MOAB/trunk/test/CMakeLists.txt	2010-03-10 19:50:12 UTC (rev 3582)
@@ -0,0 +1,49 @@
+  add_subdirectory(io)
+  add_executable( moab_test MBTest.cpp )
+  target_link_libraries( moab_test MOAB )
+  add_test( TestMOAB ${EXECUTABLE_OUTPUT_PATH}/moab_test -nostress )
+  # FIXME: moab_test depends on: test/mb_big_test.g test/cell1.gen test/cell2.gen
+  add_executable( seq_man_test TestTypeSequenceManager.cpp )
+  target_link_libraries( seq_man_test MOAB )
+  set_source_files_properties( TestTypeSequenceManager.cpp
+    COMPILE_FLAGS "-DIS_BUILDING_MB ${MOAB_DEFINES}" )
+   add_test( TestTypeSequenceManager ${EXECUTABLE_OUTPUT_PATH}/seq_man_test )
+  add_executable( homxform_test ${MOAB_SOURCE_DIR}/src/HomXform.cpp )
+  set_source_files_properties( ${MOAB_SOURCE_DIR}/src/HomXform.cpp
+    COMPILE_FLAGS "-DTEST ${MOAB_DEFINES}" )
+  target_link_libraries( homxform_test MOAB )
+  add_test( TestHomXform ${EXECUTABLE_OUTPUT_PATH}/homxform_test )
+  add_executable( scdseq_test scdseq_test.cpp )
+  set_source_files_properties( scdseq_test.cpp
+  target_link_libraries( scdseq_test MOAB )
+  add_test( TestSCDSeq ${EXECUTABLE_OUTPUT_PATH}/scdseq_test )
+  add_executable( tqdcfr ${MOAB_SOURCE_DIR}/src/io/Tqdcfr.cpp )
+  set_source_files_properties( ${MOAB_SOURCE_DIR}/src/io/Tqdcfr.cpp
+    COMPILE_FLAGS "-DTEST_TQDCFR -DIS_BUILDING_MB ${MOAB_DEFINES}" )
+  target_link_libraries( tqdcfr MOAB )
+  add_test( TestTQDCFR ${EXECUTABLE_OUTPUT_PATH}/tqdcfr )
+  add_executable( bsp_tree_test bsp_tree_test.cpp )
+  set_source_files_properties( bsp_tree_test.cpp
+  target_link_libraries( bsp_tree_test MOAB )
+  add_test( TestBSPTree ${EXECUTABLE_OUTPUT_PATH}/bsp_tree_test )
Added: MOAB/trunk/test/io/CMakeLists.txt
--- MOAB/trunk/test/io/CMakeLists.txt	                        (rev 0)
+++ MOAB/trunk/test/io/CMakeLists.txt	2010-03-10 19:50:12 UTC (rev 3582)
@@ -0,0 +1,17 @@
Added: MOAB/trunk/tools/CMakeLists.txt
--- MOAB/trunk/tools/CMakeLists.txt	                        (rev 0)
+++ MOAB/trunk/tools/CMakeLists.txt	2010-03-10 19:50:12 UTC (rev 3582)
@@ -0,0 +1,41 @@
+  # Documentation
+  # Optional tools
+  option ( MOAB_BUILD_MBCONVERT    "Build the MOAB mesh converter tool?"  ON )
+  option ( MOAB_BUILD_HEXMODOPS    "Build the hexahedral modops tool?"    ON )
+  option ( MOAB_BUILD_MBCHACO      "Build MOAB Chaco interface?"          OFF )
+  option ( MOAB_BUILD_MBPERF       "Build the MOAB performance tool?"     ON )
+  option ( MOAB_BUILD_QVDUAL       "Build the qvdual application?"        OFF )
+  option ( MOAB_BUILD_MBSIZE       "Build the mbsize tool?"               ON )
+  option ( MOAB_BUILD_MBSKIN       "Build the mbskin tool?"               ON )
+  option ( MOAB_BUILD_MBTAGPROP    "Build the mbtagprop tool?"            ON )
+  option ( MOAB_BUILD_SPHEREDECOMP "Build the sphere decomposition tool?" ON )
+  option ( MOAB_BUILD_MBSURFPLOT   "Build the mbsurfplot application?"    ON )
+  option ( MOAB_BUILD_MBZOLTAN     "Build the mbzoltan partitioner?"      OFF )
+  option ( MOAB_BUILD_DAGMC        "Build the dagmc tool?"                ON )
+  option ( MOAB_BUILD_MBCOUPLER    "Build the mesh coupler tool?"         ON )
+    add_subdirectory( refiner )
+    include_directories( ${MOAB_SOURCE_DIR}/refiner )
+    target_link_libraries( MOAB MOABrefiner )
+  # Zoltan
+  # Chaco
+  # QVDual
+  if ( MOAB_BUILD_QVDUAL )
+    add_subdirectory( qvdual )
+  endif ( MOAB_BUILD_QVDUAL )
+  # CGM
+  if ( MOAB_BUILD_DAGMC )
+    add_subdirectory( dagmc )
+  endif ( MOAB_BUILD_DAGMC )
+  # MBCoupler
+  if ( MOAB_USE_MPI AND MPI_FOUND AND MOAB_BUILD_MBCOUPLER )
+    add_subdirectory( mbcoupler )
+  endif ( MOAB_USE_MPI AND MPI_FOUND AND MOAB_BUILD_MBCOUPLER )
Modified: MOAB/trunk/tools/dagmc/CMakeLists.txt
--- MOAB/trunk/tools/dagmc/CMakeLists.txt	2010-03-10 18:25:50 UTC (rev 3581)
+++ MOAB/trunk/tools/dagmc/CMakeLists.txt	2010-03-10 19:50:12 UTC (rev 3582)
@@ -4,6 +4,10 @@
   ${CMAKE_CURRENT_BINARY_DIR}
   ${CMAKE_CURRENT_SOURCE_DIR}
 set( MOAB_DAGMC_LIB_SRCS
