[MOAB-dev] Mesh partitioning question(s)
Tim Tautges tautges at mcs.anl.gov
Tue Mar 9 19:35:12 CST 2010
Dmitry Karpeev wrote:
> A couple of questions (any clues appreciated):
> 1) What are the appropriate mesh file formats that support partial file read-in?
> For example, when I try to read in a .cub mesh, I can't have each
> process just read
> its appropriate piece in.  In terms of parallel/mbparallelcomm_test, I
> can't use
> readpar_option == -2.  I have meshes in the VTK format here, as well
> as some .h5m
> and .smf mesh files.
If you're referring to the parallel read option, only h5m, I believe.  When you try other file formats, do they fail or
just not behave as advertised?  That should be logged in a ticket...
> 2) In absence of GEOM_DIMENSION tag, what is the appropriate tag to define
> a parallel mesh partition?
I've used MATERIAL_SET in the past, as well as PARALLEL_PARTITION (which is the tag used by mbzoltan to write the
partition).
- tim
> Thanks.
> Dmitry.
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
