[MOAB-dev] r3575 - in MOAB/trunk: doc itaps src test/io	test/parallel
    kraftche at cae.wisc.edu
    Tue Mar  9 17:39:50 CST 2010
Author: kraftche
Date: 2010-03-09 17:39:49 -0600 (Tue, 09 Mar 2010)
New Revision: 3575
Added:
   MOAB/trunk/doc/user.dox.in
   MOAB/trunk/itaps/Makefile.am
   MOAB/trunk/src/FCDefs.h.in
   MOAB/trunk/test/io/Makefile.am
   MOAB/trunk/test/parallel/Makefile.am
Log:
add files missing from previous checkin
Added: MOAB/trunk/doc/user.dox.in
--- MOAB/trunk/doc/user.dox.in	                        (rev 0)
+++ MOAB/trunk/doc/user.dox.in	2010-03-09 23:39:49 UTC (rev 3575)
@@ -0,0 +1,840 @@
+ # Doxyfile 1.2.11.1
+# This file describes the settings to be used by the documentation system
+# doxygen (www.doxygen.org) for a project
+# All text after a hash (#) is considered a comment and will be ignored
+# The format is:
+#       TAG = value [value, ...]
+# For lists items can also be appended using:
+#       TAG += value [value, ...]
+# Values that contain spaces should be placed between quotes (" ")
+# General configuration options
+# The PROJECT_NAME tag is a single word (or a sequence of words surrounded
+# by quotes) that should identify the project.
+PROJECT_NAME           = moab
+# The PROJECT_NUMBER tag can be used to enter a project or revision number.
+# This could be handy for archiving the generated documentation or
+# if some version control system is used.
+PROJECT_NUMBER         =
+# The OUTPUT_DIRECTORY tag is used to specify the (relative or absolute)
+# base path where the generated documentation will be put.
+# If a relative path is entered, it will be relative to the location
+# where doxygen was started. If left blank the current directory will be used.
+OUTPUT_DIRECTORY       = user
+# The OUTPUT_LANGUAGE tag is used to specify the language in which all
+# documentation generated by doxygen is written. Doxygen will use this
+# information to generate all constant output in the proper language.
+# The default language is English, other supported languages are:
+# Brazilian, Chinese, Croatian, Czech, Danish, Dutch, Finnish, French,
+# German, Hungarian, Italian, Japanese, Korean, Norwegian, Polish,
+# Portuguese, Romanian, Russian, Slovak, Slovene, Spanish and Swedish.
+OUTPUT_LANGUAGE        = English
+# If the EXTRACT_ALL tag is set to YES doxygen will assume all entities in
+# documentation are documented, even if no documentation was available.
+# Private class members and static file members will be hidden unless
+# the EXTRACT_PRIVATE and EXTRACT_STATIC tags are set to YES
+EXTRACT_ALL            = NO
+# If the EXTRACT_PRIVATE tag is set to YES all private members of a class
+# will be included in the documentation.
+EXTRACT_PRIVATE        = NO
+# If the EXTRACT_STATIC tag is set to YES all static members of a file
+EXTRACT_STATIC         = YES
+# If the HIDE_UNDOC_MEMBERS tag is set to YES, Doxygen will hide all
+# undocumented members of documented classes, files or namespaces.
+# If set to NO (the default) these members will be included in the
+# various overviews, but no documentation section is generated.
+# This option has no effect if EXTRACT_ALL is enabled.
+HIDE_UNDOC_MEMBERS     = NO
+# If the HIDE_UNDOC_CLASSES tag is set to YES, Doxygen will hide all
+# undocumented classes that are normally visible in the class hierarchy.
+# If set to NO (the default) these class will be included in the various
+# overviews. This option has no effect if EXTRACT_ALL is enabled.
+HIDE_UNDOC_CLASSES     = NO
+# If the BRIEF_MEMBER_DESC tag is set to YES (the default) Doxygen will
+# include brief member descriptions after the members that are listed in
+# the file and class documentation (similar to JavaDoc).
+# Set to NO to disable this.
+BRIEF_MEMBER_DESC      = YES
+# If the REPEAT_BRIEF tag is set to YES (the default) Doxygen will prepend
+# the brief description of a member or function before the detailed description.
+# Note: if both HIDE_UNDOC_MEMBERS and BRIEF_MEMBER_DESC are set to NO, the
+# brief descriptions will be completely suppressed.
+REPEAT_BRIEF           = YES
+# If the ALWAYS_DETAILED_SEC and REPEAT_BRIEF tags are both set to YES then
+# Doxygen will generate a detailed section even if there is only a brief
+# description.
+ALWAYS_DETAILED_SEC    = NO
+# If the FULL_PATH_NAMES tag is set to YES then Doxygen will prepend the full
+# path before files name in the file list and in the header files. If set
+# to NO the shortest path that makes the file name unique will be used.
+FULL_PATH_NAMES        = NO
+# If the FULL_PATH_NAMES tag is set to YES then the STRIP_FROM_PATH tag
+# can be used to strip a user defined part of the path. Stripping is
+# only done if one of the specified strings matches the left-hand part of
+# the path. It is allowed to use relative paths in the argument list.
+STRIP_FROM_PATH        =
+# The INTERNAL_DOCS tag determines if documentation
+# that is typed after a \internal command is included. If the tag is set
+# to NO (the default) then the documentation will be excluded.
+# Set it to YES to include the internal documentation.
+INTERNAL_DOCS          = NO
+# If the CLASS_DIAGRAMS tag is set to YES (the default) Doxygen will
+# generate a class diagram (in Html and LaTeX) for classes with base or
+# super classes. Setting the tag to NO turns the diagrams off.
+CLASS_DIAGRAMS         = YES
+# If the SOURCE_BROWSER tag is set to YES then a list of source files will
+# be generated. Documented entities will be cross-referenced with these sources.
+SOURCE_BROWSER         = NO
+# Setting the INLINE_SOURCES tag to YES will include the body
+# of functions and classes directly in the documentation.
+INLINE_SOURCES         = NO
+# Setting the STRIP_CODE_COMMENTS tag to YES (the default) will instruct
+# doxygen to hide any special comment blocks from generated source code
+# fragments. Normal C and C++ comments will always remain visible.
+STRIP_CODE_COMMENTS    = YES
+# If the CASE_SENSE_NAMES tag is set to NO then Doxygen will only generate
+# file names in lower case letters. If set to YES upper case letters are also
+# allowed. This is useful if you have classes or files whose names only differ
+# in case and if your file system supports case sensitive file names. Windows
+# users are adviced to set this option to NO.
+CASE_SENSE_NAMES       = YES
+# If the SHORT_NAMES tag is set to YES, doxygen will generate much shorter
+# (but less readable) file names. This can be useful is your file systems
+# doesn't support long names like on DOS, Mac, or CD-ROM.
+SHORT_NAMES            = NO
+# If the HIDE_SCOPE_NAMES tag is set to NO (the default) then Doxygen
+# will show members with their full class and namespace scopes in the
+# documentation. If set to YES the scope will be hidden.
+HIDE_SCOPE_NAMES       = NO
+# If the VERBATIM_HEADERS tag is set to YES (the default) then Doxygen
+# will generate a verbatim copy of the header file for each class for
+# which an include is specified. Set to NO to disable this.
+VERBATIM_HEADERS       = YES
+# If the SHOW_INCLUDE_FILES tag is set to YES (the default) then Doxygen
+# will put list of the files that are included by a file in the documentation
+# of that file.
+SHOW_INCLUDE_FILES     = YES
+# If the JAVADOC_AUTOBRIEF tag is set to YES then Doxygen
+# will interpret the first line (until the first dot) of a JavaDoc-style
+# comment as the brief description. If set to NO, the JavaDoc
+# comments  will behave just like the Qt-style comments (thus requiring an
+# explict @brief command for a brief description.
+JAVADOC_AUTOBRIEF      = NO
+# If the INHERIT_DOCS tag is set to YES (the default) then an undocumented
+# member inherits the documentation from any documented member that it
+# reimplements.
+INHERIT_DOCS           = YES
+# If the INLINE_INFO tag is set to YES (the default) then a tag [inline]
+# is inserted in the documentation for inline members.
+INLINE_INFO            = YES
+# If the SORT_MEMBER_DOCS tag is set to YES (the default) then doxygen
+# will sort the (detailed) documentation of file and class members
+# alphabetically by member name. If set to NO the members will appear in
+# declaration order.
+SORT_MEMBER_DOCS       = YES
+# If member grouping is used in the documentation and the DISTRIBUTE_GROUP_DOC
+# tag is set to YES, then doxygen will reuse the documentation of the first
+# member in the group (if any) for the other members of the group. By default
+# all members of a group must be documented explicitly.
+DISTRIBUTE_GROUP_DOC   = NO
+# The TAB_SIZE tag can be used to set the number of spaces in a tab.
+# Doxygen uses this value to replace tabs by spaces in code fragments.
+TAB_SIZE               = 8
+# The GENERATE_TODOLIST tag can be used to enable (YES) or
+# disable (NO) the todo list. This list is created by putting \todo
+# commands in the documentation.
+GENERATE_TODOLIST      = YES
+# The GENERATE_TESTLIST tag can be used to enable (YES) or
+# disable (NO) the test list. This list is created by putting \test
+GENERATE_TESTLIST      = YES
+# The GENERATE_BUGLIST tag can be used to enable (YES) or
+# disable (NO) the bug list. This list is created by putting \bug
+GENERATE_BUGLIST       = YES
+# This tag can be used to specify a number of aliases that acts
+# as commands in the documentation. An alias has the form "name=value".
+# For example adding "sideeffect=\par Side Effects:\n" will allow you to
+# put the command \sideeffect (or @sideeffect) in the documentation, which
+# will result in a user defined paragraph with heading "Side Effects:".
+# You can put \n's in the value part of an alias to insert newlines.
+ALIASES                =
+# The ENABLED_SECTIONS tag can be used to enable conditional
+# documentation sections, marked by \if sectionname ... \endif.
+ENABLED_SECTIONS       =
+# The MAX_INITIALIZER_LINES tag determines the maximum number of lines
+# the initial value of a variable or define consist of for it to appear in
+# the documentation. If the initializer consists of more lines than specified
+# here it will be hidden. Use a value of 0 to hide initializers completely.
+# The appearance of the initializer of individual variables and defines in the
+# documentation can be controlled using \showinitializer or \hideinitializer
+# command in the documentation regardless of this setting.
+MAX_INITIALIZER_LINES  = 30
+# Set the OPTIMIZE_OUTPUT_FOR_C tag to YES if your project consists of C sources
+# only. Doxygen will then generate output that is more tailored for C.
+# For instance some of the names that are used will be different. The list
+# of all members will be omitted, etc.
+OPTIMIZE_OUTPUT_FOR_C  = NO
+# Set the SHOW_USED_FILES tag to NO to disable the list of files generated
+# at the bottom of the documentation of classes and structs. If set to YES the
+# list will mention the files that were used to generate the documentation.
+SHOW_USED_FILES        = YES
+# configuration options related to warning and progress messages
+# The QUIET tag can be used to turn on/off the messages that are generated
+# by doxygen. Possible values are YES and NO. If left blank NO is used.
+QUIET                  = NO
+# The WARNINGS tag can be used to turn on/off the warning messages that are
+# generated by doxygen. Possible values are YES and NO. If left blank
+# NO is used.
+WARNINGS               = YES
+# If WARN_IF_UNDOCUMENTED is set to YES, then doxygen will generate warnings
+# for undocumented members. If EXTRACT_ALL is set to YES then this flag will
+# automatically be disabled.
+WARN_IF_UNDOCUMENTED   = YES
+# The WARN_FORMAT tag determines the format of the warning messages that
+# doxygen can produce. The string should contain the $file, $line, and $text
+# tags, which will be replaced by the file and line number from which the
+# warning originated and the warning text.
+WARN_FORMAT            =
+# The WARN_LOGFILE tag can be used to specify a file to which warning
+# and error messages should be written. If left blank the output is written
+# to stderr.
+WARN_LOGFILE           =
+# configuration options related to the input files
+# The INPUT tag can be used to specify the files and/or directories that contain
+# documented source files. You may enter file names like "myfile.cpp" or
+# directories like "/usr/src/myproject". Separate the files or directories
+# with spaces.
+INPUT                  = @top_srcdir@/src/moab \
+                         @top_srcdir@/src/parallel/moab
+# If the value of the INPUT tag contains directories, you can use the
+# FILE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
+# and *.h) to filter out the source-files in the directories. If left
+# blank all files are included.
+FILE_PATTERNS          = *.cpp *.hpp *.h *.dox
+#FILE_PATTERNS          = *.dox
+# The RECURSIVE tag can be used to turn specify whether or not subdirectories
+# should be searched for input files as well. Possible values are YES and NO.
+# If left blank NO is used.
+RECURSIVE              = YES
+# The EXCLUDE tag can be used to specify files and/or directories that should
+# excluded from the INPUT source files. This way you can easily exclude a
+# subdirectory from a directory tree whose root is specified with the INPUT tag.
+EXCLUDE                =
+# EXCLUDE_PATTERNS tag to specify one or more wildcard patterns to exclude
+# certain files from those directories.
+EXCLUDE_PATTERNS       =
+# The EXAMPLE_PATH tag can be used to specify one or more files or
+# directories that contain example code fragments that are included (see
+# the \include command).
+EXAMPLE_PATH           =
+# If the value of the EXAMPLE_PATH tag contains directories, you can use the
+# EXAMPLE_PATTERNS tag to specify one or more wildcard pattern (like *.cpp
+EXAMPLE_PATTERNS       =
+# The IMAGE_PATH tag can be used to specify one or more files or
+# directories that contain image that are included in the documentation (see
+# the \image command).
+IMAGE_PATH             =
+# The INPUT_FILTER tag can be used to specify a program that doxygen should
+# invoke to filter for each input file. Doxygen will invoke the filter program
+# by executing (via popen()) the command <filter> <input-file>, where <filter>
+# is the value of the INPUT_FILTER tag, and <input-file> is the name of an
+# input file. Doxygen will then use the output that the filter program writes
+# to standard output.
+INPUT_FILTER           =
+# If the FILTER_SOURCE_FILES tag is set to YES, the input filter (if set using
+# INPUT_FILTER) will be used to filter the input files when producing source
+# files to browse.
+FILTER_SOURCE_FILES    = NO
+# configuration options related to the alphabetical class index
+# If the ALPHABETICAL_INDEX tag is set to YES, an alphabetical index
+# of all compounds will be generated. Enable this if the project
+# contains a lot of classes, structs, unions or interfaces.
+ALPHABETICAL_INDEX     = NO
+# If the alphabetical index is enabled (see ALPHABETICAL_INDEX) then
+# the COLS_IN_ALPHA_INDEX tag can be used to specify the number of columns
+# in which this list will be split (can be a number in the range [1..20])
+COLS_IN_ALPHA_INDEX    = 5
+# In case all classes in a project start with a common prefix, all
+# classes will be put under the same header in the alphabetical index.
+# The IGNORE_PREFIX tag can be used to specify one or more prefixes that
+# should be ignored while generating the index headers.
+IGNORE_PREFIX          =
+# configuration options related to the HTML output
+# If the GENERATE_HTML tag is set to YES (the default) Doxygen will
+# generate HTML output.
+GENERATE_HTML          = YES
+# The HTML_OUTPUT tag is used to specify where the HTML docs will be put.
+# If a relative path is entered the value of OUTPUT_DIRECTORY will be
+# put in front of it. If left blank `html' will be used as the default path.
+HTML_OUTPUT            =
+# The HTML_HEADER tag can be used to specify a personal HTML header for
+# each generated HTML page. If it is left blank doxygen will generate a
+# standard header.
+HTML_HEADER            =
+# The HTML_FOOTER tag can be used to specify a personal HTML footer for
+# standard footer.
+HTML_FOOTER            =
+# The HTML_STYLESHEET tag can be used to specify a user defined cascading
+# style sheet that is used by each HTML page. It can be used to
+# fine-tune the look of the HTML output. If the tag is left blank doxygen
+# will generate a default style sheet
+HTML_STYLESHEET        =
+# If the HTML_ALIGN_MEMBERS tag is set to YES, the members of classes,
+# files or namespaces will be aligned in HTML using tables. If set to
+# NO a bullet list will be used.
+HTML_ALIGN_MEMBERS     = YES
+# If the GENERATE_HTMLHELP tag is set to YES, additional index files
+# will be generated that can be used as input for tools like the
+# Microsoft HTML help workshop to generate a compressed HTML help file (.chm)
+# of the generated HTML documentation.
+GENERATE_HTMLHELP      = NO
+# If the GENERATE_HTMLHELP tag is set to YES, the GENERATE_CHI flag
+# controls if a separate .chi index file is generated (YES) or that
+# it should be included in the master .chm file (NO).
+GENERATE_CHI           = NO
+# If the GENERATE_HTMLHELP tag is set to YES, the BINARY_TOC flag
+# controls whether a binary table of contents is generated (YES) or a
+# normal table of contents (NO) in the .chm file.
+BINARY_TOC             = NO
+# The TOC_EXPAND flag can be set to YES to add extra items for group members
+# to the contents of the Html help documentation and to the tree view.
+TOC_EXPAND             = NO
+# The DISABLE_INDEX tag can be used to turn on/off the condensed index at
+# top of each HTML page. The value NO (the default) enables the index and
+# the value YES disables it.
+DISABLE_INDEX          = NO
+# This tag can be used to set the number of enum values (range [1..20])
+# that doxygen will group on one line in the generated HTML documentation.
+ENUM_VALUES_PER_LINE   = 4
+# If the GENERATE_TREEVIEW tag is set to YES, a side panel will be
+# generated containing a tree-like index structure (just like the one that
+# is generated for HTML Help). For this to work a browser that supports
+# JavaScript and frames is required (for instance Netscape 4.0+
+# or Internet explorer 4.0+).
+GENERATE_TREEVIEW      = NO
+# If the treeview is enabled (see GENERATE_TREEVIEW) then this tag can be
+# used to set the initial width (in pixels) of the frame in which the tree
+# is shown.
+TREEVIEW_WIDTH         = 250
+# configuration options related to the LaTeX output
+# If the GENERATE_LATEX tag is set to YES (the default) Doxygen will
+# generate Latex output.
+GENERATE_LATEX         = NO
+# The LATEX_OUTPUT tag is used to specify where the LaTeX docs will be put.
+# put in front of it. If left blank `latex' will be used as the default path.
+LATEX_OUTPUT           =
+# If the COMPACT_LATEX tag is set to YES Doxygen generates more compact
+# LaTeX documents. This may be useful for small projects and may help to
+# save some trees in general.
+COMPACT_LATEX          = NO
+# The PAPER_TYPE tag can be used to set the paper type that is used
+# by the printer. Possible values are: a4, a4wide, letter, legal and
+# executive. If left blank a4wide will be used.
+PAPER_TYPE             = letter
+# The EXTRA_PACKAGES tag can be to specify one or more names of LaTeX
+# packages that should be included in the LaTeX output.
+EXTRA_PACKAGES         =
+# The LATEX_HEADER tag can be used to specify a personal LaTeX header for
+# the generated latex document. The header should contain everything until
+# the first chapter. If it is left blank doxygen will generate a
+# standard header. Notice: only use this tag if you know what you are doing!
+LATEX_HEADER           =
+# If the PDF_HYPERLINKS tag is set to YES, the LaTeX that is generated
+# is prepared for conversion to pdf (using ps2pdf). The pdf file will
+# contain links (just like the HTML output) instead of page references
+# This makes the output suitable for online browsing using a pdf viewer.
+PDF_HYPERLINKS         = NO
+# If the USE_PDFLATEX tag is set to YES, pdflatex will be used instead of
+# plain latex in the generated Makefile. Set this option to YES to get a
+# higher quality PDF documentation.
+USE_PDFLATEX           = NO
+# If the LATEX_BATCHMODE tag is set to YES, doxygen will add the \\batchmode.
+# command to the generated LaTeX files. This will instruct LaTeX to keep
+# running if errors occur, instead of asking the user for help.
+# This option is also used when generating formulas in HTML.
+LATEX_BATCHMODE        = NO
+# configuration options related to the RTF output
+# If the GENERATE_RTF tag is set to YES Doxygen will generate RTF output
+# The RTF output is optimised for Word 97 and may not look very pretty with
+# other RTF readers or editors.
+GENERATE_RTF           = NO
+# The RTF_OUTPUT tag is used to specify where the RTF docs will be put.
+# put in front of it. If left blank `rtf' will be used as the default path.
+RTF_OUTPUT             =
+# If the COMPACT_RTF tag is set to YES Doxygen generates more compact
+# RTF documents. This may be useful for small projects and may help to
+COMPACT_RTF            = NO
+# If the RTF_HYPERLINKS tag is set to YES, the RTF that is generated
+# will contain hyperlink fields. The RTF file will
+# contain links (just like the HTML output) instead of page references.
+# This makes the output suitable for online browsing using WORD or other
+# programs which support those fields.
+# Note: wordpad (write) and others do not support links.
+RTF_HYPERLINKS         = NO
+# Load stylesheet definitions from file. Syntax is similar to doxygen's
+# config file, i.e. a series of assigments. You only have to provide
+# replacements, missing definitions are set to their default value.
+RTF_STYLESHEET_FILE    =
+# Set optional variables used in the generation of an rtf document.
+# Syntax is similar to doxygen's config file.
+RTF_EXTENSIONS_FILE    =
+# configuration options related to the man page output
+# If the GENERATE_MAN tag is set to YES (the default) Doxygen will
+# generate man pages
+GENERATE_MAN           = NO
+# The MAN_OUTPUT tag is used to specify where the man pages will be put.
+# put in front of it. If left blank `man' will be used as the default path.
+MAN_OUTPUT             =
+# The MAN_EXTENSION tag determines the extension that is added to
+# the generated man pages (default is the subroutine's section .3)
+MAN_EXTENSION          =
+# If the MAN_LINKS tag is set to YES and Doxygen generates man output,
+# then it will generate one additional man file for each entity
+# documented in the real man page(s). These additional files
+# only source the real man page, but without them the man command
+# would be unable to find the correct page. The default is NO.
+MAN_LINKS              = NO
+# configuration options related to the XML output
+# If the GENERATE_XML tag is set to YES Doxygen will
+# generate an XML file that captures the structure of
+# the code including all documentation. Note that this
+# feature is still experimental and incomplete at the
+# moment.
+GENERATE_XML           = NO
+# Configuration options related to the preprocessor
+# If the ENABLE_PREPROCESSING tag is set to YES (the default) Doxygen will
+# evaluate all C-preprocessor directives found in the sources and include
+# files.
+ENABLE_PREPROCESSING   = YES
+# If the MACRO_EXPANSION tag is set to YES Doxygen will expand all macro
+# names in the source code. If set to NO (the default) only conditional
+# compilation will be performed. Macro expansion can be done in a controlled
+# way by setting EXPAND_ONLY_PREDEF to YES.
+MACRO_EXPANSION        = NO
+# If the EXPAND_ONLY_PREDEF and MACRO_EXPANSION tags are both set to YES
+# then the macro expansion is limited to the macros specified with the
+# PREDEFINED and EXPAND_AS_PREDEFINED tags.
+EXPAND_ONLY_PREDEF     = NO
+# If the SEARCH_INCLUDES tag is set to YES (the default) the includes files
+# in the INCLUDE_PATH (see below) will be search if a #include is found.
+SEARCH_INCLUDES        = YES
+# The INCLUDE_PATH tag can be used to specify one or more directories that
+# contain include files that are not input files but should be processed by
+# the preprocessor.
+INCLUDE_PATH           =
+# You can use the INCLUDE_FILE_PATTERNS tag to specify one or more wildcard
+# patterns (like *.h and *.hpp) to filter out the header-files in the
+# directories. If left blank, the patterns specified with FILE_PATTERNS will
+# be used.
+INCLUDE_FILE_PATTERNS  =
+# The PREDEFINED tag can be used to specify one or more macro names that
+# are defined before the preprocessor is started (similar to the -D option of
+# gcc). The argument of the tag is a list of macros of the form: name
+# or name=definition (no spaces). If the definition and the = are
+# omitted =1 is assumed.
+PREDEFINED             =
+# If the MACRO_EXPANSION and EXPAND_PREDEF_ONLY tags are set to YES then
+# this tag can be used to specify a list of macro names that should be expanded.
+# The macro definition that is found in the sources will be used.
+# Use the PREDEFINED tag if you want to use a different macro definition.
+EXPAND_AS_DEFINED      =
+# If the SKIP_FUNCTION_MACROS tag is set to YES (the default) then
+# doxygen's preprocessor will remove all function-like macros that are alone
+# on a line and do not end with a semicolon. Such function macros are typically
+# used for boiler-plate code, and will confuse the parser if not removed.
+SKIP_FUNCTION_MACROS   = YES
+# Configuration::addtions related to external references
+# The TAGFILES tag can be used to specify one or more tagfiles.
+TAGFILES               =
+# When a file name is specified after GENERATE_TAGFILE, doxygen will create
+# a tag file that is based on the input files it reads.
+GENERATE_TAGFILE       =
+# If the ALLEXTERNALS tag is set to YES all external classes will be listed
+# in the class index. If set to NO only the inherited external classes
+# will be listed.
+ALLEXTERNALS           = NO
+# The PERL_PATH should be the absolute path and name of the perl script
+# interpreter (i.e. the result of `which perl').
+PERL_PATH              =
+# Configuration options related to the dot tool
+# If you set the HAVE_DOT tag to YES then doxygen will assume the dot tool is
+# available from the path. This tool is part of Graphviz, a graph visualization
+# toolkit from AT&T and Lucent Bell Labs. The other options in this section
+# have no effect if this option is set to NO (the default)
+HAVE_DOT               = NO
+# If the CLASS_GRAPH and HAVE_DOT tags are set to YES then doxygen
+# will generate a graph for each documented class showing the direct and
+# indirect inheritance relations. Setting this tag to YES will force the
+# the CLASS_DIAGRAMS tag to NO.
+CLASS_GRAPH            = YES
+# If the COLLABORATION_GRAPH and HAVE_DOT tags are set to YES then doxygen
+# indirect implementation dependencies (inheritance, containment, and
+# class references variables) of the class with other documented classes.
+COLLABORATION_GRAPH    = YES
+# If set to YES, the inheritance and collaboration graphs will show the
+# relations between templates and their instances.
+TEMPLATE_RELATIONS     = YES
+# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDE_GRAPH, and HAVE_DOT
+# tags are set to YES then doxygen will generate a graph for each documented
+# file showing the direct and indirect include dependencies of the file with
+# other documented files.
+INCLUDE_GRAPH          = YES
+# If the ENABLE_PREPROCESSING, SEARCH_INCLUDES, INCLUDED_BY_GRAPH, and
+# HAVE_DOT tags are set to YES then doxygen will generate a graph for each
+# documented header file showing the documented files that directly or
+# indirectly include this file.
+INCLUDED_BY_GRAPH      = YES
+# If the GRAPHICAL_HIERARCHY and HAVE_DOT tags are set to YES then doxygen
+# will graphical hierarchy of all classes instead of a textual one.
+GRAPHICAL_HIERARCHY    = YES
+# The tag DOT_PATH can be used to specify the path where the dot tool can be
+# found. If left blank, it is assumed the dot tool can be found on the path.
+DOT_PATH               =
+# The DOTFILE_DIRS tag can be used to specify one or more directories that
+# contain dot files that are included in the documentation (see the
+# \dotfile command).
+DOTFILE_DIRS           =
+# The MAX_DOT_GRAPH_WIDTH tag can be used to set the maximum allowed width
+# (in pixels) of the graphs generated by dot. If a graph becomes larger than
+# this value, doxygen will try to truncate the graph, so that it fits within
+# the specified constraint. Beware that most browsers cannot cope with very
+# large images.
+MAX_DOT_GRAPH_WIDTH    = 1024
+# The MAX_DOT_GRAPH_HEIGHT tag can be used to set the maximum allows height
+# large images.
+MAX_DOT_GRAPH_HEIGHT   = 1024
+# If the GENERATE_LEGEND tag is set to YES (the default) Doxygen will
+# generate a legend page explaining the meaning of the various boxes and
+# arrows in the dot generated graphs.
+GENERATE_LEGEND        = YES
+# If the DOT_CLEANUP tag is set to YES (the default) Doxygen will
+# remove the intermedate dot files that are used to generate
+# the various graphs.
+DOT_CLEANUP            = YES
+# Configuration::addtions related to the search engine
+# The SEARCHENGINE tag specifies whether or not a search engine should be
+# used. If set to NO the values of all tags below this one will be ignored.
+SEARCHENGINE           = NO
+# The CGI_NAME tag should be the name of the CGI script that
+# starts the search engine (doxysearch) with the correct parameters.
+# A script with this name will be generated by doxygen.
+CGI_NAME               =
+# The CGI_URL tag should be the absolute URL to the directory where the
+# cgi binaries are located. See the documentation of your http daemon for
+# details.
+CGI_URL                =
+# The DOC_URL tag should be the absolute URL to the directory where the
+# documentation is located. If left blank the absolute path to the
+# documentation, with file:// prepended to it, will be used.
+DOC_URL                =
+# The DOC_ABSPATH tag should be the absolute path to the directory where the
+# documentation is located. If left blank the directory on the local machine
+# will be used.
+DOC_ABSPATH            =
+# The BIN_ABSPATH tag must point to the directory where the doxysearch binary
+# is installed.
+BIN_ABSPATH            =
+# The EXT_DOC_PATHS tag can be used to specify one or more paths to
+# documentation generated for other projects. This allows doxysearch to search
+# the documentation for these projects as well.
+EXT_DOC_PATHS          =
Added: MOAB/trunk/itaps/Makefile.am
--- MOAB/trunk/itaps/Makefile.am	                        (rev 0)
+++ MOAB/trunk/itaps/Makefile.am	2010-03-09 23:39:49 UTC (rev 3575)
@@ -0,0 +1,18 @@
+if ENABLE_imesh
+  imesh_DIR = imesh
+else
+  imesh_DIR =
+endif
+if ENABLE_igeom
+  igeom_DIR = igeom
+else
+  igeom_DIR =
+endif
+include_HEADERS = iBase.h iBase_f.h
+SUBDIRS = $(imesh_DIR) $(igeom_DIR)
+EXTRA_DIST = mkprotos.sh
Added: MOAB/trunk/src/FCDefs.h.in
--- MOAB/trunk/src/FCDefs.h.in	                        (rev 0)
+++ MOAB/trunk/src/FCDefs.h.in	2010-03-09 23:39:49 UTC (rev 3575)
@@ -0,0 +1,7 @@
+/* Define to a macro mangling the given C identifier (in lower and upper
+   case), which must not contain underscores, for linking with Fortran. */
+#undef FC_FUNC
+/* As FC_FUNC, but for C identifiers containing underscores. */
+#undef FC_FUNC_
Added: MOAB/trunk/test/io/Makefile.am
--- MOAB/trunk/test/io/Makefile.am	                        (rev 0)
+++ MOAB/trunk/test/io/Makefile.am	2010-03-09 23:39:49 UTC (rev 3575)
@@ -0,0 +1,64 @@
+LDADD = $(top_builddir)/src/libMOAB.la
+EXTRA_DIST = brick_cubit10.1.cub \
+             brick_cubit10.2.cub \
+             brick_cubit10.cub \
+	     gmsh2.msh \
+             ho_test.g \
+             ho_test.cub \
+             test.cub \
+             test.nas \
+	     sample.stl
+AM_CPPFLAGS += -DSRCDIR=$(srcdir) \
+               -I$(builddir) -I.. -I$(srcdir)/.. \
+               -I$(top_builddir)/src \
+               -I$(top_srcdir)/src \
+               -I$(top_srcdir)/src/io \
+               -I$(top_srcdir)/src/parallel \
+               -I$(top_builddir)/src/moab \
+               -I$(top_srcdir)/src/moab \
+               -I$(top_srcdir)/src/io/moab \
+               -I$(top_srcdir)/src/parallel/moab
+TESTS = tqdcfr \
+        vtk_test \
+        cub_file_test \
+	exodus_test \
+        gmsh_test \
+	nastran_test \
+        stl_test
+check_PROGRAMS = $(TESTS)
+tqdcfr_SOURCES = $(top_srcdir)/src/io/Tqdcfr.cpp
+tqdcfr_CXXFLAGS = -DTEST_TQDCFR $(CXXFLAGS)
+tqdcfr_DEPENDENCIES = $(LDADD)
+#test_rms_SOURCES = test_rms.cpp
+#test_rms_DEPENDENCIES = $(top_builddir)/libMOAB.la
+#test_exo_SOURCES = test_exo.cpp
+#test_exo_DEPENDENCIES = $(top_builddir)/libMOAB.la
+vtk_test_SOURCES = $(srcdir)/../TestUtil.hpp VtkTest.cpp
+vtk_test_DEPENDENCIES = $(LDADD)
+cub_file_test_SOURCES = $(srcdir)/../TestUtil.hpp cub_file_test.cc
+cub_file_test_DEPENDENCIES = $(LDADD)
+exodus_test_SOURCES = $(srcdir)/../TestUtil.hpp exodus_test.cc
+exodus_test_DEPENDENCIES = $(LDADD)
+gmsh_test_SOURCES = $(srcdir)/../TestUtil.hpp gmsh_test.cc
+gmsh_test_DEPENDENCIES = $(LDADD)
+nastran_test_SOURCES = $(srcdir)/../TestUtil.hpp nastran_test.cc
+nastran_test_DEPENDENCIES = $(LDADD)
+stl_test_SOURCES = $(srcdir)/../TestUtil.hpp stl_test.cc
+stl_test_DEPENDENCIES = $(LDADD)
+MOSTLYCLEANFILES = dumped_acis.sat
Added: MOAB/trunk/test/parallel/Makefile.am
--- MOAB/trunk/test/parallel/Makefile.am	                        (rev 0)
+++ MOAB/trunk/test/parallel/Makefile.am	2010-03-09 23:39:49 UTC (rev 3575)
@@ -0,0 +1,50 @@
+AM_CPPFLAGS += -DIS_BUILDING_MB \
+               -DSRCDIR=$(srcdir) \
+               -I$(builddir) \
+               -I.. -I$(srcdir)/.. \
+# Run parallel tests in parallel
+if USE_MPIEXEC
+  OLD_ENVIRONMENT := ${TESTS_ENVIRONMENT}
+  TESTS_ENVIRONMENT = ${MPIEXEC} ${MPIEXEC_NP} ${NP} ${OLD_ENVIRONMENT}
+endif
+TESTS = pcomm_unit \
+        parallel_unit_tests \
+        uber_parallel_test \
+        scdtest \
+        pcomm_serial \
+        $(HDF5_TESTS)
+if PARALLEL_HDF5
+  AM_CPPFLAGS += -I$(top_srcdir)/mhdf/include
+  HDF5_TESTS = parallel_hdf5_test mhdf_parallel parallel_write_test
+else
+  HDF5_TESTS =
+endif
+check_PROGRAMS = $(TESTS) mbparallelcomm_test
+pcomm_unit_SOURCES = pcomm_unit.cpp
+parallel_hdf5_test_SOURCES = parallel_hdf5_test.cc
+mhdf_parallel_SOURCES = mhdf_parallel.c
+parallel_unit_tests_SOURCES = parallel_unit_tests.cpp
+parallel_write_test_SOURCES = parallel_write_test.cc
+uber_parallel_test_SOURCES = uber_parallel_test.cpp
+pcomm_serial_SOURCES = pcomm_serial.cpp
+mbparallelcomm_test_SOURCES = mbparallelcomm_test.cpp
+scdtest_SOURCES = scdtest.cpp
+# Other files to clean up (e.g. output from tests)
+MOSTLYCLEANFILES = mhdf_ll.h5m
+EXTRA_DIST = ptest.cub \
+             64bricks_512hex.h5m
