[MOAB-dev] python imesh
    James Porter
    jvporter at wisc.edu
    Fri Mar  5 15:21:31 CST 2010
It should be possible. Make sure to replicate the LD_LIBRARY_PATH and PYTHONPATH environment variables from the "test" command for the PyTAPS buildbot command: <http://gnep.mcs.anl.gov:8010/builders/pytaps/builds/52/steps/test/logs/stdio>. I can't make any promises that this will actually work, but I can't think of a reason it wouldn't (provided you aren't trying to do anything from around midnight to 2 AM, when the builds are respinning).
However, assuming you have MOAB built and working as a shared lib, it's pretty easy to install PyTAPS for yourself. I have a MOAB/CGM/Lasso-specific guide on the ITAPS wiki: https://trac.mcs.anl.gov/projects/ITAPS/wiki/InstallingPyTAPS
- Jim
----- Original Message -----
Date: Friday, March 5, 2010 3:04 pm
Subject: python imesh
To: jvporter at wisc.edu
Cc: Developer correspondence for MOAB <moab-dev at lists.mcs.anl.gov>
> Hi,
> I'm trying to get an installation of the imesh python interface for a
> quick hack I'd like to write. Any idea if the stuff built by buildbot
> on gnep can be used directly? THanks,
> Alvaro
