[MOAB-dev] r3562 - MOAB/trunk/tools/dagmc
bmsmith6 at wisc.edu
Wed Mar 3 13:19:23 CST 2010
Author: bmsmith
Date: 2010-03-03 13:19:23 -0600 (Wed, 03 Mar 2010)
New Revision: 3562
Modified:
MOAB/trunk/tools/dagmc/DagMC.cpp
Log:
point_in_volume: Warn the user when the fast test fails instead of throwing an assert.
write_mcnp: Clear the MBRange before it is reused. This fixes a bug for tallies specified in CGM groups.
measure_volume and measure_area: In the ITER model, three surfaces are faceted with triangles and (unexpectedly) 1 polygon.
Only use the triangles, and print a warning. When viewed in Cubit, the triangles resolve the continuous surface.
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp 2010-03-03 18:26:12 UTC (rev 3561)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp 2010-03-03 19:19:23 UTC (rev 3562)
@@ -574,7 +574,7 @@
MBErrorCode rval;
const double epsilon = discardDistTol;
// Get OBB Tree for volume
assert(volume - setOffset < rootSets.size());
MBEntityHandle root = rootSets[volume - setOffset];
@@ -695,7 +695,10 @@
// triangulation. That shoudn't be possible (must be
// closer to at least one of the adjacent triagles than
// to the saddle vertex.)
- assert(false /*shouldn't be here*/);
+ std::cout << "point_in_volume fast test failure: xyz= " << x << " " << y << " " << z
+ << " uvw= " << u << " " << v << " " << w
+ << " vol=" << id_by_index(3, index_by_handle(volume)) << std::endl;
+ // For now, proceed with the slow test.
return point_in_volume_slow( volume, x, y, z, result );
@@ -760,8 +763,12 @@
if (MB_SUCCESS != rval)
return rval;
if (!triangles.all_of_type(MBTRI)) {
- std::cerr << "ERROR: Surface contains non-triangle elements. Cannot calculate volume." << std::endl;
- return MB_FAILURE;
+ std::cout << "WARNING: Surface " << id_by_index(2, index_by_handle(surfaces[i]))
+ << " contains non-triangle elements. Volume calculation may be incorrect."
+ << std::endl;
+ triangles.clear();
+ rval = MBI->get_entities_by_type( surfaces[i], MBTRI, triangles );
+ if (MB_SUCCESS != rval) return rval;
// calculate signed volume beneath surface (x 6.0)
@@ -796,8 +803,12 @@
return rval;
- std::cerr << "ERROR: Surface contains non-triangle elements. Cannot calculate area." << std::endl;
+ std::cout << "WARNING: Surface " << id_by_index(2, index_by_handle(surface))
+ << " contains non-triangle elements. Area calculation may be incorrect."
+ << std::endl;
+ rval = MBI->get_entities_by_type( surface, MBTRI, triangles );
// calculate sum of area of triangles
@@ -1154,6 +1165,7 @@
if (grp_names.empty()) continue;
// get sets associated with this group
+ grp_sets.clear();
rval = MBI->get_entities_by_type(group, MBENTITYSET, grp_sets);
if (MB_SUCCESS != rval) continue;
