[MOAB-dev] Simple instructions & script for building parallel MOAB with prerequisites
Dmitry Karpeev karpeev at mcs.anl.gov
Thu Feb 11 13:18:23 CST 2010
I have developed a script to install MOAB with a basic set of
prerequisites,
as I'm installing MOAB on various parallel machines and some automation was
necessary.  The script isn't full-proof, but it comes with exhaustive
step-by-step
instructions on the ITAPS Wiki page:
http://trac.mcs.anl.gov/projects/ITAPS/wiki/BuildingAndUsingMOAB
I intended for these installation instructions to become part of the
revamped MOAB
Wiki page.  It would be good if people started trying to use these
instructions and scripts internally
to see if they are adequate.  These are aimed at a novice user, which
explains the level of detail there.
Thanks.
Dmitry.
On Thu, Feb 11, 2010 at 11:45 AM, Tim Tautges <tautges at mcs.anl.gov> wrote:
> Hi all,
>  It's VERY important that we start using the central installed version of
> visit and other tools at ANL.  If the tools as-installed aren't configured
> properly, then let's get them fixed.  Bob can help with install-type issues,
> though we should also all have permissions for writing into that space.
> - tim
> Iulian Grindeanu wrote:
>> Hi,
>> It is here
>> /homes/iulian/lib/VisIt/bin/visit
>> ----- Original Message -----
>> From: "Hongjun Kim" <hongjun at mcs.anl.gov>
>> To: "Iulian R. Grindeanu" <iulian at mcs.anl.gov>
>> Sent: Thursday, February 11, 2010 11:00:09 AM GMT -06:00 US/Canada Central
>> Subject: Visit build
>> Hi!
>> Can you tell me where your visit is for me to use?
>> Thanks.
>> Hong-Jun
> "You will keep in perfect peace him whose mind is
>  steadfast, because he trusts in you."               Isaiah 26:3
>             Tim Tautges            Argonne National Laboratory
>         (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>         phone: (608) 263-8485      1500 Engineering Dr.
>           fax: (608) 263-4499      Madison, WI 53706
> Fathom mailing list
> Fathom at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/fathom
