[MOAB-dev] Puzzling find_skin behaviour
    Tim Tautges
    tautges at mcs.anl.gov
    Thu Feb  4 10:49:53 CST 2010
Thanks Jason.
- tim
>> Roman Putanowicz wrote:
>>> Hi,
>>> I have encountered puzzling behaviour of find_skin of MBSkinner.
>>> I have mesh in gmsh format partitioned into four partitions.
>>> I read the mesh and then I want to draw boundary of each partition.
>>> I reduce the line width for each partition in order to see edges
>>> even if the overlap. The code to perform the above alrorithm is
>>> shown below.
> Fixed in SVN revision 3524.
> - jason
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
