[MOAB-dev] r3509 - MOAB/trunk
    iulian at mcs.anl.gov
    Fri Jan 29 10:57:46 CST 2010
Hi Tim and Jason,
I still get errors when running make check (I changed ReadSmf to not "exit", and some other changes suggested by Jason)
The first error reported is in parallel_hdf5_test.
The tests fail now even if I comment out (or not) the file stream in ReadSmf.
Iulian
----- Original Message -----
To: moab-dev at mcs.anl.gov
Sent: Friday, January 29, 2010 10:35:57 AM GMT -06:00 US/Canada Central
Subject: Re: [MOAB-dev] r3509 - MOAB/trunk
Thanks.
- tim
kraftche at cae.wisc.edu wrote:
> Author: kraftche
> Date: 2010-01-29 10:23:40 -0600 (Fri, 29 Jan 2010)
> New Revision: 3509
> Modified:
>    MOAB/trunk/MBReaderWriterSet.cpp
> Log:
> Fix some bugs in MBReaderWriterSet
> o One registration of CCMIO reader and writer, rather than separate
>   registration of each.
> o Report an error if there are two registrations with the same
>   string name.
> o Fix case-insensitive comparison of file name extensions.
> Modified: MOAB/trunk/MBReaderWriterSet.cpp
> --- MOAB/trunk/MBReaderWriterSet.cpp	2010-01-29 05:24:00 UTC (rev 3508)
> +++ MOAB/trunk/MBReaderWriterSet.cpp	2010-01-29 16:23:40 UTC (rev 3509)
> @@ -117,8 +117,7 @@
>  #ifdef CCMIO_FILE
>    const char* ccmio_sufxs[] = { "ccm", "ccmg", NULL };
> -  register_factory( NULL, WriteCCMIO::factory, "CCMIO files", ccmio_sufxs, "CCMIO");
> -  register_factory( ReadCCMIO::factory, NULL, "CCMIO files", ccmio_sufxs, "CCMIO");
> +  register_factory( ReadCCMIO::factory, WriteCCMIO::factory, "CCMIO files", ccmio_sufxs, "CCMIO");
>  #endif
>    register_factory( NULL, WriteGMV::factory, "GMV", "gmv", "GMV" );
> @@ -147,12 +146,20 @@
>    if (!reader && !writer)
>      return MB_FAILURE;
> +    // check for duplicate names
> +  iterator h = handler_by_name( name );
> +  if (h != end()) {
> +    mbError->set_last_error( "Conflicting string name for file formats: \"%s\"",
> +                             name );
> +    return MB_FAILURE;
>      // count extensions and check for duplicates
>    const char* const* iter;
>    for (iter = extensions; *iter; ++iter)
> -    iterator h = handler_from_extension( *iter );
> +    h = handler_from_extension( *iter );
>      if (h != end())
>        if (NULL != reader && h->have_reader())
> @@ -245,8 +252,8 @@
>      // try case-insensitive compare
>    for (iter = begin(); iter != end(); ++iter)
> -    if ((with_reader && iter->have_reader()) ||
> -        (with_writer && iter->have_writer()))
> +    if ((with_reader && !iter->have_reader()) ||
> +        (with_writer && !iter->have_writer()))
>        continue;
>      for (siter = iter->mExtensions.begin(); siter != iter->mExtensions.end(); ++siter)
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
