[MOAB-dev] r3473 - in MOAB/branches/perf: . benchmarks
karpeev at mcs.anl.gov
Fri Jan 22 16:02:39 CST 2010
Author: karpeev
Date: 2010-01-22 16:02:39 -0600 (Fri, 22 Jan 2010)
New Revision: 3473
Added:
MOAB/branches/perf/NOTES.BUILD
MOAB/branches/perf/benchmarks/
MOAB/branches/perf/benchmarks/Makefile.am
MOAB/branches/perf/benchmarks/mbparead.cpp
Modified:
MOAB/branches/perf/Makefile.am
MOAB/branches/perf/configure.ac
Log:
Added a benchmark based on mbparallelcomm_test.
Modified: MOAB/branches/perf/Makefile.am
--- MOAB/branches/perf/Makefile.am 2010-01-22 21:36:27 UTC (rev 3472)
+++ MOAB/branches/perf/Makefile.am 2010-01-22 22:02:39 UTC (rev 3473)
@@ -11,9 +11,9 @@
SUBDIRS += mhdf
endif
if PARALLEL
- SUBDIRS += parallel
+ SUBDIRS += parallel
endif
-SUBDIRS += . test tools doc doxygen
+SUBDIRS += . test tools benchmarks doc doxygen
BUILT_SOURCES = MBCN_protos.h
Added: MOAB/branches/perf/NOTES.BUILD
--- MOAB/branches/perf/NOTES.BUILD (rev 0)
+++ MOAB/branches/perf/NOTES.BUILD 2010-01-22 22:02:39 UTC (rev 3473)
@@ -0,0 +1,21 @@
+# define the source: SRC=trunk or SRC=${MOAB_DIR}/branches/perf, etc
+SRC=${MOAB_DIR}/branches/perf
+cd ${SRC}
+make distclean
+rm -f config.log make.log
+autoreconf -fi
+# define the build: BUILD=gcc, etc
+BUILD=gcc
+mkdir -p ${SRC}/build/${BUILD}
+cd ${SRC}/build/${BUILD}
+export MPI_PREFIX=${SHARP_DIR}/mpich2/mpich2-1.2.1/gcc
+export HDF5_PREFIX=${SHARP_DIR}/hdf5/hdf5-1.8.3/parallel/gcc
+export ZLIB_PREFIX=${SHARP_DIR}/zlib/zlib-1.2.3/gcc
+export SZIP_PREFIX=${SHARP_DIR}/szip/szip-2.1/gcc
+CC=${MPI_PREFIX}/bin/mpicc CXX=${MPI_PREFIX}/bin/mpicxx ../../configure --with-mpi=${MPI_PREFIX} --with-hdf5=${HDF5_PREFIX} --with-zlib=${ZLIB_PREFIX} --with-szip=${SZIP_PREFIX} --disable-debug 2>&1 | tee configure.log
+make 2>&1 | tee make.log
+make check 2>&1 | tee make.check.log
Added: MOAB/branches/perf/benchmarks/Makefile.am
--- MOAB/branches/perf/benchmarks/Makefile.am (rev 0)
+++ MOAB/branches/perf/benchmarks/Makefile.am 2010-01-22 22:02:39 UTC (rev 3473)
@@ -0,0 +1,13 @@
+AUTOMAKE_OPTIONS = foreign
+DEFS = $(DEFINES) -DIS_BUILDING_MB
+LDADD = $(top_builddir)/libMOAB.la
+INCLUDES += -I$(top_srcdir) \
+ -I$(top_srcdir)/parallel \
+ -I$(top_builddir)
+bin_PROGRAMS = mbparead
+mbparead_SOURCES = mbparead.cpp
+mbparead_DEPENDENCIES = $(top_builddir)/libMOAB.la
Added: MOAB/branches/perf/benchmarks/mbparead.cpp
--- MOAB/branches/perf/benchmarks/mbparead.cpp (rev 0)
+++ MOAB/branches/perf/benchmarks/mbparead.cpp 2010-01-22 22:02:39 UTC (rev 3473)
@@ -0,0 +1,486 @@
+/** test of MBParallelComm functionality
+ * To run:
+ * mpirun -np <#procs> mbparallelcomm_test
+#include "MBParallelComm.hpp"
+#include "MBParallelConventions.h"
+#include "ReadParallel.hpp"
+#include "FileOptions.hpp"
+#include "MBTagConventions.hpp"
+#include "MBCore.hpp"
+#include "ScdVertexData.hpp"
+#include "StructuredElementSeq.hpp"
+#include "SequenceManager.hpp"
+#include "MBError.hpp"
+#include "MBmpi.h"
+#include <iostream>
+#include <sstream>
+#include <assert.h>
+#define REALTFI 1
+const bool debug = false;
+#define ERROR(a, b) {std::cerr << a << std::endl; return b;}
+#define PRINT_LAST_ERROR {\
+ std::string last_error;\
+ result = mbImpl->get_last_error(last_error);\
+ if (last_error.empty()) std::cerr << "(none)" << std::endl;\
+ else std::cerr << last_error << std::endl;\
+#define RRA(a) if (MB_SUCCESS != result) {\
+ std::string tmp_str; mbImpl->get_last_error(tmp_str);\
+ tmp_str.append("\n"); tmp_str.append(a);\
+ dynamic_cast<MBCore*>(mbImpl)->get_error_handler()->set_last_error(tmp_str); \
+ return result;}
+MBErrorCode create_linear_mesh(MBInterface *mbImpl,
+ int N, int M, int &nshared);
+MBErrorCode create_scd_mesh(MBInterface *mbImpl,
+ int IJK, int &nshared);
+MBErrorCode read_file(MBInterface *mbImpl, std::vector<std::string> &filenames,
+ const char *tag_name, int tag_val, int distrib,
+ int parallel_option, int resolve_shared, int with_ghosts,
+ int use_mpio, bool print_parallel);
+MBErrorCode test_packing(MBInterface *mbImpl, const char *filename);
+MBErrorCode report_nsets(MBInterface *mbImpl);
+MBErrorCode report_iface_ents(MBInterface *mbImpl,
+ std::vector<MBParallelComm *> &pcs);
+void print_usage(const char *);
+int main(int argc, char **argv)
+ // need to init MPI first, to tell how many procs and rank
+ int err = MPI_Init(&argc, &argv);
+ int nprocs, rank;
+ err = MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
+ err = MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+ // start time
+ double stime, rtime, dtime, ltime;
+ if (0 == rank) stime = MPI_Wtime();
+ // create MOAB instance based on that
+ MBInterface *mbImpl = new MBCore;
+ if (NULL == mbImpl) return 1;
+ MBErrorCode result = MB_SUCCESS;
+ // each interior proc has a vector of N+M vertices, sharing
+ // M vertices each with lower- and upper-rank processors, except
+ // procs on the end
+ // get N, M from command line
+ if (argc < 3) {
+ if (0 == rank) print_usage(argv[0]);
+ err = MPI_Finalize();
+ return 1;
+ int npos = 1, tag_val, distrib, with_ghosts = 1, resolve_shared = 1,
+ use_mpio = 0;
+ bool print_parallel = false;
+ const char *tag_name;
+ std::vector<std::string> filenames;
+ int parallel_option = 0;
+ int num_files;
+ if (!strcmp(argv[npos], "-p")) print_parallel = true;
+ while (npos != argc) {
+ MBErrorCode tmp_result;
+ int nshared = -1;
+ int this_opt = strtol(argv[npos++], NULL, 0);
+ switch (this_opt) {
+ case 0:
+ case -1:
+ case -2:
+ case -3:
+ parallel_option = this_opt;
+ continue;
+ case 3:
+ // read a file in parallel from the filename on the command line
+ tag_name = "MATERIAL_SET";
+ tag_val = -1;
+ num_files = strtol(argv[npos++], NULL, 0);
+ if (0 == num_files) {
+ return 1;
+ while (num_files-- && npos < argc)
+ filenames.push_back(std::string(argv[npos++]));
+ if (npos < argc) tag_name = argv[npos++];
+ if (npos < argc) tag_val = strtol(argv[npos++], NULL, 0);
+ if (npos < argc) distrib = strtol(argv[npos++], NULL, 0);
+ else distrib = 1;
+ if (npos < argc) resolve_shared = strtol(argv[npos++], NULL, 0);
+ if (npos < argc) with_ghosts = strtol(argv[npos++], NULL, 0);
+ if (npos < argc) use_mpio = strtol(argv[npos++], NULL, 0);
+ tmp_result = read_file(mbImpl, filenames, tag_name, tag_val,
+ distrib, parallel_option,
+ resolve_shared, with_ghosts, use_mpio,
+ print_parallel);
+ if (MB_SUCCESS != tmp_result) {
+ result = tmp_result;
+ std::cerr << "Couldn't read mesh; error message:" << std::endl;
+ PRINT_LAST_ERROR;
+ MPI_Abort(MPI_COMM_WORLD, result);
+ nshared = -1;
+ break;
+ case 4:
+ filenames.push_back(argv[npos++]);
+ tmp_result = test_packing(mbImpl, filenames[0].c_str());
+ std::cerr << "Packing test failed; error message:" << std::endl;
+ PRINT_LAST_ERROR
+ break;
+ case 5:
+ distrib = 1;
+ tag_val = -1;
+ with_ghosts = 0;
+ resolve_shared = 1;
+ while (npos < argc)
+ distrib, parallel_option, resolve_shared,
+ with_ghosts, use_mpio, print_parallel);
+ PRINT_LAST_ERROR;
+ nshared = -1;
+ break;
+ default:
+ std::cerr << "Unrecognized option \"" << this_opt
+ << "\"; skipping." << std::endl;
+ tmp_result = MB_FAILURE;
+ if (0 == rank) rtime = MPI_Wtime();
+ if (0 == rank) dtime = MPI_Wtime();
+ result = mbImpl->delete_mesh();
+ if (MB_SUCCESS != result) {
+ std::cerr << "Couldn't delete mesh on rank " << rank
+ << "; error message: " << std::endl;
+ PRINT_LAST_ERROR;
+ if (MB_SUCCESS == result)
+ std::cerr << "Proc " << rank << ": Success." << std::endl;
+ if (0 == rank) std::cout << "Times: "
+ << dtime-stime << " "
+ << rtime-stime << " "
+ << dtime - ltime
+ << " (total/read/delete)"
+ << std::endl;
+ delete mbImpl;
+ return (MB_SUCCESS == result ? 0 : 1);
+void print_usage(const char *command)
+ std::cerr
+ << "Usage: " << command
+ << " [readpar_option] <opt> <input> [...] where:" << std::endl
+ << " readpar_option = 0 (BCAST_DELETE) (default), -1 (READ_DELETE), " << std::endl
+ << " -2 (READ_PARALLEL), -3 (BCAST)" << std::endl
+ << "opt input" << std::endl
+ << "=== =====" << std::endl
+ << " 1 <linear_ints> <shared_verts> " << std::endl
+ << " 2 <n_ints> " << std::endl
+ << " 3* <# files> <file_names...> [<tag_name>=\"MATERIAL_SET\" [tag_val] [distribute=1] [resolve_shared=1] [with_ghosts=1] [use_mpio=0]" << std::endl
+ << " 4 <file_name> " << std::endl
+ << "*Note: if opt 3 is used, it must be the last one." << std::endl;
+ // get and report various numbers...
+ int rank;
+ MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+ MBRange matsets, geomsets, parsets;
+ int nsets;
+ MBTag mtag = 0, gtag = 0, ptag = 0, gidtag;
+ MBErrorCode result = mbImpl->tag_get_handle("MATERIAL_SET", mtag);
+ result = mbImpl->tag_get_handle("GEOM_DIMENSION", gtag);
+ result = mbImpl->tag_get_handle("PARALLEL_PARTITION", ptag);
+ result = mbImpl->tag_get_handle("GLOBAL_ID", gidtag);
+ result = mbImpl->get_number_entities_by_type(0, MBENTITYSET, nsets);
+ std::cout << "Proc " << rank << ": Total of " << nsets
+ << " entity sets." << std::endl;
+#define PRINTSETS(a, b, c, p) \
+ if (a) {\
+ result = mbImpl->get_entities_by_type_and_tag(0, MBENTITYSET, & a,\
+ p, 1, b); \
+ if (! b .empty()) {\
+ std::vector<int> ids( b .size());\
+ result = mbImpl->tag_get_data(gidtag, b, &ids[0]); \
+ if (MB_SUCCESS == result) {\
+ std::cout << "Proc " << rank << ": " << c \
+ << " (total " << b.size() << "): " \
+ << ids[0]; \
+ for (unsigned int i = 1; i < b .size(); i++) \
+ std::cout << ", " << ids[i]; \
+ std::cout << std::endl; \
+ PRINTSETS(mtag, matsets, "material sets", NULL);
+ int tval = 3;
+ void *pval = &tval;
+ PRINTSETS(gtag, geomsets, "geom sets (vols)", &pval);
+ tval = 2;
+ geomsets.clear();
+ PRINTSETS(gtag, geomsets, "geom sets (surfs)", &pval);
+ tval = 1;
+ geomsets.clear();
+ PRINTSETS(gtag, geomsets, "geom sets (curves)", &pval);
+ tval = 0;
+ geomsets.clear();
+ PRINTSETS(gtag, geomsets, "geom sets (verts)", &pval);
+ PRINTSETS(ptag, parsets, "partition sets", NULL);
+ if (debug) {
+ // list info on all ent sets, reuse parsets
+ parsets.clear();
+ result = mbImpl->get_entities_by_type(0, MBENTITYSET, parsets);
+ std::cout << "Total sets (by range): " << parsets.size() << "; sets: " << std::endl;
+ parsets.print(" ");
+ mbImpl->list_entities(parsets);
+ return MB_SUCCESS;
+ std::vector<std::string> &filenames,
+ int distrib, int parallel_option, int resolve_shared,
+ int with_ghosts, int use_mpio, bool print_parallel)
+ std::ostringstream options;
+ switch (parallel_option) {
+ case 0:
+ options << "PARALLEL=BCAST_DELETE;PARTITION=" << tag_name;
+ break;
+ case -1:
+ options << "PARALLEL=READ_DELETE;PARTITION=" << tag_name;
+ break;
+ case -2:
+ options << "PARALLEL=READ_PART;PARTITION=" << tag_name;
+ break;
+ case -3:
+ options << "PARALLEL=BCAST;PARTITION=" << tag_name;
+ break;
+ default:
+ return MB_FAILURE;
+ if (-1 != tag_val)
+ options << ";PARTITION_VAL=" << tag_val;
+ if (1 == distrib)
+ options << ";PARTITION_DISTRIBUTE";
+ if (1 == resolve_shared)
+ options << ";PARALLEL_RESOLVE_SHARED_ENTS";
+ if (1 == with_ghosts)
+ options << ";PARALLEL_GHOSTS=3.0.1";
+ if (1 == use_mpio)
+ options << ";USE_MPIO";
+ options << ";CPUTIME";
+ if (print_parallel)
+ options << ";PRINT_PARALLEL";
+ std::vector<MBParallelComm*> pcs(filenames.size());
+ std::vector<ReadParallel*> rps(filenames.size());
+ MBErrorCode result;
+ if (1 < filenames.size()) {
+ for (unsigned int i = 0; i < filenames.size(); i++) {
+ pcs[i] = new MBParallelComm(mbImpl);
+ rps[i] = new ReadParallel(mbImpl, pcs[i]);
+ result = rps[i]->load_file(filenames[i].c_str(), 0,
+ FileOptions(options.str().c_str()), 0, 0, 0);
+ PRINT_LAST_ERROR;
+ break;
+ // exchange tag
+ MBRange tmp_range;
+ result = pcs[i]->exchange_tags("GLOBAL_ID", tmp_range);
+ std::cerr << "Tag exchange didn't work." << std::endl;
+ break;
+ else {
+ result = mbImpl->load_file(filenames[0].c_str(), 0,
+ options.str().c_str());
+ pcs[0] = MBParallelComm::get_pcomm(mbImpl, 0);
+ assert(pcs[0]);
+ if (MB_SUCCESS == result) report_iface_ents(mbImpl, pcs);
+ return result;
+ // read the mesh
+ MBEntityHandle file_set;
+ MBErrorCode result = mbImpl->create_meshset( MESHSET_SET, file_set );
+ RRA("create_meshset failed.");
+ result = mbImpl->load_file(filename, &file_set, NULL);
+ std::cerr << "Reading file failed; message:" << std::endl;
+ PRINT_LAST_ERROR;
+ return result;
+ // get 3d entities and pack a buffer with them
+ MBRange ents, new_ents, whole_range;
+ result = mbImpl->get_entities_by_handle(file_set, ents);
+ RRA("Getting 3d ents failed.");
+ ents.insert(file_set);
+ MBParallelComm *pcomm = new MBParallelComm(mbImpl);
+ MBParallelComm::Buffer buff;
+ result = pcomm->pack_buffer(ents, false, true, false, -1, &buff);
+ RRA("Packing buffer count (non-stored handles) failed.");
+ std::vector<std::vector<MBEntityHandle> > L1hloc, L1hrem;
+ std::vector<std::vector<int> > L1p;
+ std::vector<MBEntityHandle> L2hloc, L2hrem;
+ std::vector<unsigned int> L2p;
+ buff.reset_ptr();
+ result = pcomm->unpack_buffer(buff.buff_ptr, false, -1, -1, L1hloc, L1hrem, L1p, L2hloc,
+ L2hrem, L2p, new_ents);
+ RRA("Unpacking buffer (non-stored handles) failed.");
+ MBRange iface_ents[6];
+ MBErrorCode result = MB_SUCCESS, tmp_result;
+ // now figure out which vertices are shared
+ MBRange part_ents;
+ for (unsigned int p = 0; p < pcs.size(); p++) {
+ // get entities owned by this partition
+ for (MBRange::iterator rit = pcs[p]->partition_sets().begin();
+ rit != pcs[p]->partition_sets().end(); rit++) {
+ tmp_result = mbImpl->get_entities_by_dimension(*rit, 3, part_ents, true);
+ if (MB_SUCCESS != tmp_result) result = tmp_result;
+ for (int i = 0; i < 4; i++) {
+ tmp_result = pcs[p]->get_iface_entities(-1, i, iface_ents[i]);
+ std::cerr << "get_iface_entities returned error on proc "
+ << pcs[p]->proc_config().proc_rank() << "; message: " << std::endl;
+ if (0 != i) iface_ents[4].merge(iface_ents[i]);
+ // report # iface entities
+ result = mbImpl->get_adjacencies(iface_ents[4], 0, false, iface_ents[5],
+ MBInterface::UNION);
+ int rank;
+ std::cerr << "Proc " << rank << " iface entities: " << std::endl;
+ std::cerr << " " << iface_ents[i].size() << " "
+ << i << "d iface entities." << std::endl;
+ std::cerr << " (" << iface_ents[5].size()
+ << " verts adj to other iface ents)" << std::endl;
+ if (iface_ents[0].size() != iface_ents[5].size())
+ std::cerr << "WARNING: number of interface vertices don't agree with "
+ << "vertex adjacencies on interface entities." << std::endl;
+ // report # regions owned by this proc
+ std::cout << "Proc " << rank << " owns " << part_ents.size()
+ << " 3d entities." << std::endl;
+ // get total # regions over all procs
+ int num_local = part_ents.size(), num_total;
+ int failure = MPI_Reduce(&num_local, &num_total, 1,
+ MPI_INT, MPI_SUM, 0, MPI_COMM_WORLD);
+ if (failure) result = MB_FAILURE;
+ if (0 == rank)
+ std::cout << "Total # owned regions = " << num_total << std::endl;
+ return result;
Modified: MOAB/branches/perf/configure.ac
--- MOAB/branches/perf/configure.ac 2010-01-22 21:36:27 UTC (rev 3472)
+++ MOAB/branches/perf/configure.ac 2010-01-22 22:02:39 UTC (rev 3473)
@@ -1030,6 +1030,7 @@
testdir.h
parallel/Makefile
mhdf/Makefile
+ benchmarks/Makefile
test/Makefile
test/h5file/Makefile
test/dual/Makefile
