[MOAB-dev] r3455 - MOAB/trunk
kraftche at cae.wisc.edu
Thu Jan 21 11:04:26 CST 2010
Author: kraftche
Date: 2010-01-21 11:04:25 -0600 (Thu, 21 Jan 2010)
New Revision: 3455
Modified:
MOAB/trunk/configure.ac
Log:
Disable iMesh by default if sizeof(MBEntityHandle) != sizeof(void*), and warn.
Fail configuration if user specifies --enable-imesh and handle size is invalid
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac 2010-01-20 22:09:28 UTC (rev 3454)
+++ MOAB/trunk/configure.ac 2010-01-21 17:04:25 UTC (rev 3455)
@@ -11,14 +11,17 @@
-# iMesh
+# iMesh Part 1 of 3
CONFIGURE_FORTRAN=no
+FORCE_ENABLE_IMESH=no
AC_ARG_ENABLE( [imesh],
[AC_HELP_STRING([--enable-imesh(=nofortran)],[Build iMesh interface. If optional
'nofortran' argument is given, support for FORTRAN name mangling will be disabled.])
AC_HELP_STRING([--disable-imesh],[Don't build support for iMesh interface.])],
-[DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --enable-imesh=\"${enableval}\""],
+[FORCE_ENABLE_IMESH=yes
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --enable-imesh=\"${enableval}\""],
[enableval=yes] )
case $enableval in
@@ -36,11 +39,7 @@
AC_MSG_ERROR([Invalid argument to --enable-imesh : $enableval])
esac
-AC_MSG_CHECKING([if iMesh support is to be built])
-AC_MSG_RESULT([$ENABLE_imesh])
-AM_CONDITIONAL([ENABLE_imesh],[test "xyes" = "x$ENABLE_imesh"])
# Compilers
@@ -75,7 +74,84 @@
fi
fi
+# HANDLE SIZE
+AC_CHECK_HEADER([inttypes.h], [AC_DEFINE(MOAB_HAVE_INTTYPES_H, [], [MOAB qualified HAVE_INTTYPES_H]) ])
+AC_CHECK_HEADER([stdint.h], [AC_DEFINE(MOAB_HAVE_STDINT_H, [], [MOAB qualified HAVE_STDINT_H]) ])
+AC_CHECK_HEADER([sys/types.h],[AC_DEFINE(MOAB_HAVE_SYS_TYPES_H, [], [MOAB qualified HAVE_SYS_TYPES_H])])
+AC_CHECK_HEADER([stddef.h], [AC_DEFINE(MOAB_HAVE_STDDEF_H, [], [MOAB qualified HAVE_STDDEF_H]) ])
+AC_CHECK_HEADER([stdlib.h], [AC_DEFINE(MOAB_HAVE_STDLIB_H, [], [MOAB qualified HAVE_STDLIB_H]) ])
+SIZEOF_MBENTITYHANDLE=0
+AC_CHECK_SIZEOF(void *)
+SIZEOF_VOID_P=$ac_cv_sizeof_void_p
+AC_ARG_ENABLE([64bit-handles],
+ [AC_HELP_STRING([--enable-64bit-handles],[Force MBEntityHandle to be 64 bits])],
+ [AC_CHECK_TYPE([uint64_t],
+ [AC_DEFINE(MOAB_FORCE_64_BIT_HANDLES,[],[Use int64_t for handles])
+ SIZEOF_MBENTITYHANDLE=8
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --enable-64bit-handles"],
+ [AC_MSG_ERROR([Platform does not have uint64_t. Cannot force 64-bit handles])])
+AC_ARG_ENABLE([32bit-handles],
+ [AC_HELP_STRING([--enable-32bit-handles],[Force MBEntityHandle to be 32 bits])],
+ [AC_CHECK_TYPE([uint32_t],
+ [AC_DEFINE(MOAB_FORCE_32_BIT_HANDLES,[],[Use int32_t for handles])
+ SIZEOF_MBENTITYHANDLE=4
+ DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --enable-32bit-handles"],
+ [AC_MSG_ERROR([Platform does not have uint32_t. Cannot force 32-bit handles])])
+if test "x$SIZEOF_MBENTITYHANDLE" = "x0"; then
+ SIZEOF_MBENTITYHANDLE=$SIZEOF_VOID_P
+ AC_CHECK_TYPE([size_t],
+ [AC_DEFINE(MOAB_HAVE_SIZE_T,[],[System provides size_t typedef])],
+ [AC_CHECK_SIZEOF(unsigned long)
+ if test "$SIZEOF_UNSIGNED_LONG" -ne "$SIZEOF_VOID_P"; then
+ AC_MSG_ERROR([Cannot define handle with sizeof void*: size_t not found and long is of incorrect size.])
+ fi]
+ AC_CHECK_TYPE([ptrdiff_t],
+ [AC_DEFINE(MOAB_HAVE_PTRDIFF_T,[],[System provides ptrdiff_t typedef])],
+ [AC_CHECK_SIZEOF(long)
+ AC_CHECK_SIZEOF(void *)
+ if test "$SIZEOF_LONG" -ne "$SIZEOF_VOID_P"; then
+ AC_MSG_ERROR([Cannot define handle with sizeof void*: ptrdiff_t not found and long is of incorrect size.])
+ fi]
+fi
+# iMesh Part 2 of 3
+# The iMesh option must be checked before configuring the compilers
+# so that we know if we need Fortran. This stuff has to be done
+# after configuring the compilers so that we know what size of
+# various types are.
+AC_MSG_CHECKING([size of MBEntityHandle])
+AC_MSG_RESULT([$SIZEOF_MBENTITYHANDLE])
+IMESH_VALID_HANDLE_SIZE=yes
+if test $SIZEOF_VOID_P -ne $SIZEOF_MBENTITYHANDLE; then
+ IMESH_VALID_HANDLE_SIZE=no
+ AC_MSG_WARN([Cannot build iMesh API because sizeof(MBEntityHandle) != sizeof(void*)])
+ if test "x$FORCE_ENABLE_IMESH" = "xno"; then
+ ENABLE_imesh=no
+ fi
+fi
+AC_MSG_CHECKING([if iMesh support is to be built])
+AC_MSG_RESULT([$ENABLE_imesh])
+AM_CONDITIONAL([ENABLE_imesh],[test "xyes" = "x$ENABLE_imesh"])
+if test "x$ENABLE_imesh" = "xyes"; then
+ if test "x$IMESH_VALID_HANDLE_SIZE" != "xyes"; then
+ AC_MSG_ERROR([Cannot build iMesh API with sizeof(MBEntityHandle) != sizeof(void*)])
+ fi
+fi
# Version Stuff
@@ -107,39 +183,6 @@
AC_SUBST(MOAB_CXX_LIBS)
-# HANDLE SIZE
-AC_CHECK_HEADER([inttypes.h], [AC_DEFINE(MOAB_HAVE_INTTYPES_H, [], [MOAB qualified HAVE_INTTYPES_H]) ])
-AC_CHECK_HEADER([stdint.h], [AC_DEFINE(MOAB_HAVE_STDINT_H, [], [MOAB qualified HAVE_STDINT_H]) ])
-AC_CHECK_HEADER([sys/types.h],[AC_DEFINE(MOAB_HAVE_SYS_TYPES_H, [], [MOAB qualified HAVE_SYS_TYPES_H])])
-AC_CHECK_HEADER([stddef.h], [AC_DEFINE(MOAB_HAVE_STDDEF_H, [], [MOAB qualified HAVE_STDDEF_H]) ])
-AC_CHECK_HEADER([stdlib.h], [AC_DEFINE(MOAB_HAVE_STDLIB_H, [], [MOAB qualified HAVE_STDLIB_H]) ])
-AC_ARG_ENABLE([64bit-handles],
- [AC_HELP_STRING([--enable-64bit-handles],[Force MBEntityHandle to be 64 bits])],
- [AC_CHECK_TYPE([uint64_t],
- [AC_DEFINE(MOAB_FORCE_64_BIT_HANDLES,[],[Use int64_t for handles])
- DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --enable-64bit-handles"],
- [AC_MSG_ERROR([Platform does not have uint64_t. Cannot force 64-bit handles])])
-AC_ARG_ENABLE([32bit-handles],
- [AC_HELP_STRING([--enable-32bit-handles],[Force MBEntityHandle to be 32 bits])],
- [AC_CHECK_TYPE([uint32_t],
- [AC_DEFINE(MOAB_FORCE_32_BIT_HANDLES,[],[Use int32_t for handles])
- DISTCHECK_CONFIGURE_FLAGS="$DISTCHECK_CONFIGURE_FLAGS --enable-32bit-handles"],
- [AC_MSG_ERROR([Platform does not have uint32_t. Cannot force 32-bit handles])])
-if test "x$HANDLE_TYPE" = "x"; then
- AC_CHECK_TYPE([size_t],
- [AC_DEFINE(MOAB_HAVE_SIZE_T,[],[System provides size_t typedef])],
- [AC_MSG_WARN([size_t not defined, assuming sizeof(void*) == sizeof(long)])]
- AC_CHECK_TYPE([ptrdiff_t],
- [AC_DEFINE(MOAB_HAVE_PTRDIFF_T,[],[System provides ptrdiff_t typedef])],
- [AC_MSG_WARN([ptrdiff_t not defined, assuming sizeof(void*) == sizeof(long)])]
-fi
# System Headers
AC_CHECK_HEADER([ieeefp.h],[DEFINES="$DEFINES -DHAVE_IEEEFP_H"] )
@@ -979,7 +1022,7 @@
AM_CONDITIONAL( HAVE_CGM, [test "x$CGM_MISSING" = "xno"] )
-# iMesh Babel
+# iMesh Part 3 of 3 (Babel)
AC_ARG_WITH(babel,
