[MOAB-dev] r3439 - MOAB/trunk/tools
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Tue Jan 19 16:27:08 CST 2010
kraftche at cae.wisc.edu wrote:
> Author: kraftche
> Date: 2010-01-19 16:20:34 -0600 (Tue, 19 Jan 2010)
> New Revision: 3439
> Modified:
>    MOAB/trunk/tools/skin.cpp
> Log:
> Include vertex count in mbskin output
That check-in message should have been:
mbskin utility improvements
  o add option to merge coincident vertices
  o fix option parsing
     - check that block ids have valid syntax
     - allow concatenated flags
     - do not unconditionally treat last arg(s) as input/output files
  o add option to specify name of tag in which to store skin flag
  o fix incorrect help (wrong tag name) for -t option
