[MOAB-dev] debugging mbparallelcomm_test on cosmea
Dima Karpeev
karpeev at gmail.com
Tue Jan 19 10:53:22 CST 2010
I understand that it's an alloc problem.
I'm running mbparallelcomm_test. I'm trying to track it witha debugger
now, but doing it on cosmea is a bit hard: I can't submit jobs with
fewer than 4 procs: each node has 4 cores.
I was just wondering if this was a known problem.
Dmitry
On Jan 19, 2010, at 8:38, Jason Kraftcheck <kraftche at cae.wisc.edu>
wrote:
> Dmitry Karpeev wrote:
>> I'm trying to get some parallel runs out of mbparallelcomm_test on
>> cosmea,
>> but I keep getting this error (when running in parallel):
>> terminate called after throwing an instance of 'std::bad_alloc'
>> what(): St9bad_alloc
>> The exception appears to be thrown on rank 0, which causes an abort
>> across the comm.
>> Any ideas about what's going on?
>> I'm about to dig in to see what the problem may be, but I thought
>> someone might
>> save me the trouble :-)
> This is the result of a failed memory allocation (new, malloc, or
> perhaps an
> increase in the stack size.) Are you trying to allocate a very
> large array?
> - jason
