[MOAB-dev] buildbot failure in Fathom on moab-par
    donotreply at mcs.anl.gov
    Tue Jan 19 00:05:35 CST 2010
The Fathomatic has detected a failed build of moab-par on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/42
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
Running test_read_tags ...
Running test_read_global_tags ...
Running test_read_sets ...
PASS: parallel_hdf5_test
PASS: mhdf_parallel
Using default interval count: 2
00:   0.01: Generating mesh
01:   0.01: Generating mesh
01:   0.01: Resolving shared entities
00:   0.01: Resolving shared entities
00:   0.01: Beginning parallel write
01:   0.01: Beginning parallel write
Wrote 01:   0.06: Finalizing MPI
16 hexes in 0.04 seconds.
00:   0.05: Removing written file
Wall time: generate: 0.00170898, resovle shared: 0.00849009, write_file: 0.175721
00:   0.05: Finalizing MPI
PASS: parallel_write_test
All 8 tests passed
Making check in .
make[3]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-par/build'
make  moab_test homxform_test scdseq_test tqdcfr test_adj seq_man_test geom_util_test xform_test obb_test vtk_test adaptive_kd_tree_tests bsp_tree_test file_options_test kd_tree_test var_len_test var_len_test_no_template tag_test mesh_set_test cub_file_test exodus_test gmsh_test nastran_test stl_test mbcn_test bsp_tree_poly_test kd_tree_tool kd_tree_time
make[4]: Entering directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-par/build'
mpiCC -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DIS_BUILDING_MB -I. -I./parallel -I. -I./mhdf/include -I./parallel -I/home/jvporter/include -isystem /home/jvporter/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -DSRCDIR=.  -Wall -pipe -O2 -DNDEBUG -MT MBTest.o -MD -MP -MF .deps/MBTest.Tpo -c -o MBTest.o MBTest.cpp
mv -f .deps/MBTest.Tpo .deps/MBTest.Po
gunzip -c ./test/mb_big_test.g.gz > test/mb_big_test.g
gunzip -c ./test/cell1.gen.gz > test/cell1.gen
gunzip -c ./test/cell2.gen.gz > test/cell2.gen
/bin/sh ./libtool --tag=CXX   --mode=link mpiCC  -Wall -pipe -O2 -DNDEBUG -L/home/jvporter/lib -L/home/jvporter/lib -o moab_test MBTest.o ./libMOAB.la -lm
mpiCC -Wall -pipe -O2 -DNDEBUG -o moab_test MBTest.o  -L/home/jvporter/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /homes/jvporter/lib/libhdf5.a -lz -lm
mpiCC -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DIS_BUILDING_MB -I. -I./parallel -I. -I./mhdf/include -I./parallel -I/home/jvporter/include -isystem /home/jvporter/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -DSRCDIR=. -DTEST -Wall -pipe -O2 -DNDEBUG -Wall -pipe -O2 -DNDEBUG -MT homxform_test-HomXform.o -MD -MP -MF .deps/homxform_test-HomXform.Tpo -c -o homxform_test-HomXform.o `test -f 'HomXform.cpp' || echo './'`HomXform.cpp
mv -f .deps/homxform_test-HomXform.Tpo .deps/homxform_test-HomXform.Po
/bin/sh ./libtool --tag=CXX   --mode=link mpiCC -DTEST -Wall -pipe -O2 -DNDEBUG -Wall -pipe -O2 -DNDEBUG -L/home/jvporter/lib -L/home/jvporter/lib -o homxform_test homxform_test-HomXform.o ./libMOAB.la -lm
mpiCC -DTEST -Wall -pipe -O2 -DNDEBUG -Wall -pipe -O2 -DNDEBUG -o homxform_test homxform_test-HomXform.o  -L/home/jvporter/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /homes/jvporter/lib/libhdf5.a -lz -lm
mpiCC -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DIS_BUILDING_MB -I. -I./parallel -I. -I./mhdf/include -I./parallel -I/home/jvporter/include -isystem /home/jvporter/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -DSRCDIR=.  -Wall -pipe -O2 -DNDEBUG -MT scdseq_test.o -MD -MP -MF .deps/scdseq_test.Tpo -c -o scdseq_test.o scdseq_test.cpp
mv -f .deps/scdseq_test.Tpo .deps/scdseq_test.Po
/bin/sh ./libtool --tag=CXX   --mode=link mpiCC  -Wall -pipe -O2 -DNDEBUG -L/home/jvporter/lib -L/home/jvporter/lib -o scdseq_test scdseq_test.o ./libMOAB.la -lm
mpiCC -Wall -pipe -O2 -DNDEBUG -o scdseq_test scdseq_test.o  -L/home/jvporter/lib ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /homes/jvporter/lib/libhdf5.a -lz -lm
mpiCC -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DIS_BUILDING_MB -I. -I./parallel -I. -I./mhdf/include -I./parallel -I/home/jvporter/include -isystem /home/jvporter/include  -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -DSRCDIR=. -DTEST_TQDCFR -Wall -pipe -O2 -DNDEBUG -Wall -pipe -O2 -DNDEBUG -MT tqdcfr-Tqdcfr.o -MD -MP -MF .deps/tqdcfr-Tqdcfr.Tpo -c -o tqdcfr-Tqdcfr.o `test -f 'Tqdcfr.cpp' || echo './'`Tqdcfr.cpp
Tqdcfr.cpp: In function 'int main(int, char**)':
Tqdcfr.cpp:2634: error: 'MPI_Init' was not declared in this scope
Tqdcfr.cpp:2636: error: 'MPI_COMM_WORLD' was not declared in this scope
Tqdcfr.cpp:2636: error: 'MPI_Comm_size' was not declared in this scope
Tqdcfr.cpp:2637: error: 'MPI_Comm_rank' was not declared in this scope
sincerely,
 -The Fathomatic
