[MOAB-dev] Problems with mixed-language linking [Was: Re:	[Fathom] Problems building Lasso]
    Robert Smith
    smithrm at mcs.anl.gov
    Mon Jan 18 10:19:12 CST 2010
I agree.  The shared library approach seem to be the most current and
will not be as error prone for the user.
--Bob
On Jan 17, 2010, at 1:31 AM, James Porter wrote:
> My inclination is to use #3 (shared libraries). Aside from the fact
> that
> it makes the default configuration work with the Python bindings,
> which
> makes me happy, it also eliminates most of the problems without
> requiring user intervention. Forcing people to use a C++-aware linker
> seems prone to confusion and would also probably have the side
> effect of
> making it harder to use other linkers (e.g. gold). Trying to hard-code
> the C++ standard libraries is brittle and that solution almost
> certainly
> doesn't work everywhere; I think the main reason it works on Linux is
> because GCC shares a lot of code for its C and C++ compilers.
> - Jim
