[MOAB-dev] buildbot failure in Fathom on moab-par
    donotreply at mcs.anl.gov
    Sun Jan  3 00:04:50 CST 2010
The Fathomatic has detected a failed build of moab-par on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/25
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
test_ghost_elements_3_2_2 : success
test_ghost_elements_3_0_1 : success
test_ghost_elements_2_0_1 : success
test_ghost_tag_exchange : success
regression_ghost_tag_exchange_no_default : success
test_interface_owners : success
regression_owners_with_ghosting : success
test_ghosted_entity_shared_data : success
All tests passed
PASS: parallel_unit_tests
test_read : success
test_read : success
test_read : success
test_read : success
test_read : success
test_read : success
test_read : success
test_read : success
PASS: uber_parallel_test
Run this with 2 or 4 processes
FAIL: scdtest
Warning: acis file has sequence numbers!
PASS: pcomm_serial
Running test_write_elements ...
Running test_write_shared_sets ...
Running test_var_length_parallel ...
Running test_read_elements ...
Running test_read_elements_by_rank ...
Running test_read_tags ...
Running test_read_global_tags ...
Running test_read_sets ...
PASS: parallel_hdf5_test
PASS: mhdf_parallel
Using default interval count: 2
00:   0.00: Generating mesh
00:   0.00: Resolving shared entities
00:   0.00: Beginning parallel write
Wrote 8 hexes in 0.01 seconds.
00:   0.01: Removing written file
Wall time: generate: 0, resovle shared: 0, write_file: 0.167969
00:   0.01: Finalizing MPI
PASS: parallel_write_test
1 of 8 tests failed
sincerely,
 -The Fathomatic
