[MOAB-dev] r3421 - in MOAB/trunk: . tools/dagmc
    bmsmith6 at wisc.edu
    Tue Dec 22 10:53:16 CST 2009
Author: bmsmith
Date: 2009-12-22 10:53:16 -0600 (Tue, 22 Dec 2009)
New Revision: 3421
Modified:
   MOAB/trunk/ReadNCDF.cpp
   MOAB/trunk/ReadNCDF.hpp
   MOAB/trunk/tools/dagmc/cub2h5m.cc
   MOAB/trunk/tools/dagmc/quads_to_tris.cpp
   MOAB/trunk/tools/dagmc/quads_to_tris.hpp
Log:
-ReacNCDF: Pass Cubit mesh file_set to update function. This helps to keep the meshed geometry from the cub file and faceted geometry from the acis file separate.
-quads_to_tris: Add extra function to convert a range of quads to tris.
-cub2h5m: Completely reworked this. Leaving asserts in for debugging purposes until changes to the workflow slow down.
  -Read the cub mesh file and acis geometry files
  -Fix the acis surfaces to have the same sense as the cub surfaces
  -Update the cub mesh with a deformed exodus file
     -Update cub file node position by node id
     -Remove dead elements from the cub file by element id
  -Print a histogram summarizing element volume change due to deformation
  -Add dead elements to the implicit complement volume
     -This includes adding new surfaces and modifying others that are adjacent to dead elems
  -Replace faceted acis surfaces with meshed, deformed, cub surfaces
  -Save the acis file for DagMC analysis
Modified: MOAB/trunk/ReadNCDF.cpp
--- MOAB/trunk/ReadNCDF.cpp	2009-12-22 15:45:06 UTC (rev 3420)
+++ MOAB/trunk/ReadNCDF.cpp	2009-12-22 16:53:16 UTC (rev 3421)
@@ -284,7 +284,7 @@
   std::string s;
   rval = opts.get_str_option("tdata", s );
   if(MB_SUCCESS == rval && !s.empty())
-    return update(exodus_file_name, opts, num_blocks, blocks_to_load);
+    return update(exodus_file_name, opts, num_blocks, blocks_to_load, *file_set);
   reset();
@@ -1582,9 +1582,14 @@
   return MB_SUCCESS;
+// The cub_file_set contains the mesh to be updated. There could exist other
+// file sets that should be kept separate, such as the geometry file set from
+// ReadCGM.
 MBErrorCode ReadNCDF::update(const char *exodus_file_name,
                              const FileOptions& opts,
-                             const int num_blocks, const int *blocks_to_load)
+                             const int num_blocks,
+                             const int *blocks_to_load,
+                             const MBEntityHandle cub_file_set)
   //Function : updating current database from new exodus_file.
   //Creator:   Jane Hu
@@ -1608,6 +1613,7 @@
   //3. In exodus file, get node_num_map
   //4. loop through the node_num_map, use it to find the node in the cub file.
   //5. Replace coord[0][n] with coordx[m]+vals_nod_var1(time_step, m) for all directions for matching nodes.
+  // Test: try to get hexes
   MBErrorCode rval;
   std::string s;
@@ -1676,7 +1682,7 @@
     return MB_FAILURE;
   const int max_time_steps = ncdim->size();
-  std::cout << "max_time_steps=" << max_time_steps << std::endl;
+  std::cout << "  Maximum time step=" << max_time_steps << std::endl;
   if(max_time_steps < time_step) {
     std::cout << "ReadNCDF: time step is greater than max_time_steps" << std::endl;
     return MB_FAILURE;
@@ -1796,16 +1802,17 @@
   // Place cub verts in a kdtree.
   MBRange cub_verts;
-  rval = mdbImpl->get_entities_by_type( 0, MBVERTEX, cub_verts );
+  rval = mdbImpl->get_entities_by_type( cub_file_set, MBVERTEX, cub_verts );
   if(MB_SUCCESS != rval) return rval;
-  std::cout << "found " << cub_verts.size() << " cub verts" << std::endl;
+  std::cout << "  cub_file_set contains " << cub_verts.size() << " nodes."
+            << std::endl;
   MBAdaptiveKDTree kdtree( mdbImpl, true );
   MBEntityHandle root;
   MBAdaptiveKDTree::Settings settings;
   settings.maxEntPerLeaf = 1;
   settings.candidateSplitsPerDir = 1;
-  settings.candidatePlaneSet = MBAdaptiveKDTree::SUBDIVISION;
-  rval = kdtree.build_tree( cub_verts, root, &settings );
+  settings.candidatePlaneSet = MBAdaptiveKDTree::SUBDIVISION;
+  rval = kdtree.build_tree( cub_verts, root, &settings );
   MBAdaptiveKDTreeIter tree_iter;
   rval = kdtree.get_tree_iterator( root, tree_iter );
@@ -1818,7 +1825,8 @@
   // search is O(logn) but MOAB tag search is O(n). For 150k nodes this
   // is 5 minutes faster.
   const double GEOMETRY_RESABS = 1e-6;
-  std::cout << "found " << numberNodes_loading << " exo verts" << std::endl;
+  std::cout << "  exodus file contains " << numberNodes_loading << " nodes."
+            << std::endl;
   for(int i=0; i<numberNodes_loading; ++i) {
     MBEntityHandle cub_vert = 0;
     std::vector<MBEntityHandle> leaves;
@@ -1865,9 +1873,14 @@
-  std::cout << "verts lost=" << lost << " verts found=" << found << std::endl;
-  std::cout << "max_magnitude=" << max_magnitude << " average_magnitude="
-          << average_magnitude/found << std::endl;
+  std::cout << "  " << found
+            << " nodes from the exodus file were matched by id in the cub_file_set."
+            << std::endl;
+  std::cout << "  " << lost << " nodes from the exodus file could not be matched."
+            << std::endl;
+  std::cout << "  maximum node displacement magnitude=" << max_magnitude << std::endl;
+  std::cout << "  average node displacement magnitude=" << average_magnitude/found
+            << std::endl;
   // How many element variables are in the file?
   ncdim = ncFile->get_dim("num_elem_var");
@@ -1966,7 +1979,10 @@
       readMeshIface->report_error("ReadNCDF:: Problem getting death_status array.");
       return MB_FAILURE;
-    // Look for dead elements
+    // Look for dead elements. If there is too many dead elements and this starts
+    // to take too long, I should put the elems in a kd-tree for more efficient
+    // searching. Alternatively I could get the exo connectivity and match nodes.
     int dead_elem_counter = 0;
     for (int j=0; j<i->numElements; ++j) {
       if (1 != death_status[j]) {
@@ -1975,13 +1991,19 @@
         void *id[] = {&elem_id};
         // assume hex elems!!!!!!!!
         MBRange cub_elem;
-        rval = mdbImpl->get_entities_by_type_and_tag(0, MBHEX, &mGlobalIdTag, id, 1, cub_elem);
+        rval = mdbImpl->get_entities_by_type_and_tag( cub_file_set, MBHEX,
+						      &mGlobalIdTag, id, 1, cub_elem,
+                                                      MBInterface::INTERSECT );
         if(1 != cub_elem.size()) {
 	  std::cout << "ReadNCDF: Should have found 1 element, but instead found "
                     << cub_elem.size() << std::endl;
           return MB_FAILURE;
+        // Delete the dead element from the cub file. It will be removed from sets
+        // ONLY if they are tracking meshsets.
+        rval = mdbImpl->remove_entities( cub_file_set, cub_elem );
+        if(MB_SUCCESS != rval) return rval;
         rval = mdbImpl->delete_entities( cub_elem );
         ++dead_elem_counter;
@@ -1990,8 +2012,8 @@
     // Print some statistics
     temp.str("");
     temp << i->blockId;
-    std::cout << "block " << temp.str() << " had " << dead_elem_counter << "/"
-              << i->numElements << " dead elements" << std::endl;
+    std::cout << "  Block " << temp.str() << " has " << dead_elem_counter << "/"
+              << i->numElements << " dead elements." << std::endl;
     // advance the pointers into element ids and block_count
     first_elem_id_in_block += i->numElements;
     ++block_count;
Modified: MOAB/trunk/ReadNCDF.hpp
--- MOAB/trunk/ReadNCDF.hpp	2009-12-22 15:45:06 UTC (rev 3420)
+++ MOAB/trunk/ReadNCDF.hpp	2009-12-22 16:53:16 UTC (rev 3421)
@@ -91,7 +91,8 @@
   //update the coords for deformed mesh according to FileOptions
   MBErrorCode update(const char *exodus_file_name, const FileOptions& opts,
-                     const int num_blocks, const int *blocks_to_load);
+                     const int num_blocks, const int *blocks_to_load,
+                     const MBEntityHandle file_set );
 private:
Modified: MOAB/trunk/tools/dagmc/cub2h5m.cc
--- MOAB/trunk/tools/dagmc/cub2h5m.cc	2009-12-22 15:45:06 UTC (rev 3420)
+++ MOAB/trunk/tools/dagmc/cub2h5m.cc	2009-12-22 16:53:16 UTC (rev 3421)
@@ -2,11 +2,14 @@
 #include "InitCGMA.hpp"
 #include "CGMApp.hpp"
 #include "MBCore.hpp"
+#include "MBCartVect.hpp"
 #include "cubfile.h"
 #include "Tqdcfr.hpp"
 #include "FileOptions.hpp"
 #include "ReadNCDF.hpp"
+#include "MBSkinner.hpp"
 #include "quads_to_tris.hpp"
+#include <limits>
 #define GF_CUBIT_FILE_TYPE    "CUBIT"
 #define GF_STEP_FILE_TYPE     "STEP"
@@ -15,9 +18,696 @@
 #define GF_ACIS_BIN_FILE_TYPE "ACIS_SAB"
 #define GF_OCC_BREP_FILE_TYPE "OCC"
+// Given parent volume senses, an id, and a set handle, this function creates a
+// new surface set with dimension, geometry category, id, and sense tags.
+MBErrorCode build_new_surface( MBInterface *MBI,
+                               MBEntityHandle &new_surf,
+                               const MBEntityHandle forward_parent_vol,
+                               const MBEntityHandle reverse_parent_vol,
+                               const int new_surf_id,
+                               const MBTag dimTag, const MBTag idTag,
+                               const MBTag categoryTag, const MBTag senseTag ) {
+  MBErrorCode result;
+  result = MBI->create_meshset( 0, new_surf );
+  assert(MB_SUCCESS == result);
+  if(0 != forward_parent_vol) {
+    result = MBI->add_parent_child( forward_parent_vol, new_surf );
+  if(0 != reverse_parent_vol) {
+    result = MBI->add_parent_child( reverse_parent_vol, new_surf );
+  const int two = 2;
+  result = MBI->tag_set_data( dimTag, &new_surf, 1, &two );
+  result = MBI->tag_set_data( idTag, &new_surf, 1, &new_surf_id );
+  const char geom_category[CATEGORY_TAG_SIZE] = {"Surface\0"};
+  result = MBI->tag_set_data( categoryTag, &new_surf, 1, &geom_category );
+  MBEntityHandle vols[2] = { forward_parent_vol, reverse_parent_vol };
+  result = MBI->tag_set_data( senseTag, &new_surf, 1, vols );
+  return MB_SUCCESS;
+// Given a face, orient it outward wrt its adjacent mesh element.
+// Each face must be adjacent to exactly one mesh element.
+MBErrorCode orient_faces_outward( MBInterface *MBI, const MBRange faces,
+                                  const bool debug ) {
+  for(MBRange::const_iterator i=faces.begin(); i!=faces.end(); ++i) {
+    MBRange adj_elem;
+    result = MBI->get_adjacencies( &(*i), 1, 3, false, adj_elem );
+    assert(1 == adj_elem.size());
+    // get center of element
+    const MBEntityHandle *elem_conn;
+    int n_nodes;
+    result = MBI->get_connectivity( adj_elem.front(), elem_conn, n_nodes );
+    MBCartVect elem_coords[n_nodes];
+    result = MBI->get_coords( elem_conn, n_nodes, elem_coords[0].array() );
+    MBCartVect elem_center(0.0);
+    for(int j=0; j<n_nodes; ++j) elem_center += elem_coords[j];
+    elem_center /= n_nodes;
+    // get the center of the face
+    const MBEntityHandle *face_conn;
+    result = MBI->get_connectivity( *i, face_conn, n_nodes );
+    MBCartVect face_coords[n_nodes];
+    result = MBI->get_coords( face_conn, n_nodes, face_coords[0].array() );
+    MBCartVect face_center(0.0);
+    for(int j=0; j<n_nodes; ++j) face_center += face_coords[j];
+    face_center /= n_nodes;
+    if(debug) std::cout << "      center of mesh face exposed by dead element="
+                        << face_center << std::endl;
+    // get the normal of the face
+    MBCartVect face_normal, a, b;
+    a = face_coords[2] - face_coords[1];
+    b = face_coords[0] - face_coords[1];
+    face_normal = a*b;
+    face_normal.normalize();
+    // get the direction into the element
+    MBCartVect elem_dir = elem_center - face_center;
+    elem_dir.normalize();
+    // the dot product of the face_normal and elem_dir should be ~-1 if the face
+    // is oriented outward wrt the elem.
+    double dot_prod = face_normal % elem_dir;
+    // If the face is not oriented outward wrt the element, reverse it
+    if(0 < dot_prod) {
+      MBEntityHandle new_face_conn[4] = { face_conn[3], face_conn[2],
+                                          face_conn[1], face_conn[0] };
+      result = MBI->set_connectivity( *i, new_face_conn, 4 );
+/* qsort int comparison function */
+int handle_compare(const void *a, const void *b)
+  const MBEntityHandle *ia = (const MBEntityHandle *)a; // casting pointer types
+  const MBEntityHandle *ib = (const MBEntityHandle *)b;
+  return *ia  - *ib;
+  /* integer comparison: returns negative if b > a
+     and positive if a > b */
+// qsort face comparison function. assume each face has 4 nodes
+int compare_face(const void *a, const void *b) {
+  MBEntityHandle *ia = (MBEntityHandle *)a;
+  MBEntityHandle *ib = (MBEntityHandle *)b;
+  if(*ia == *ib) {
+    if(*(ia+1) == *(ib+1)) {
+      if(*(ia+2) == *(ib+2)) {
+        return (int)(*(ia+3) - *(ib+3));
+      } else {
+        return (int)(*(ia+2) - *(ib+2));
+    } else {
+      return (int)(*(ia+1) - *(ib+1));
+  } else {
+    return (int)(*ia - *ib);
+// Use this to get quad faces from hex elems. MBSkinner does not produce the
+// expected result.
+MBErrorCode skin_hex_elems(MBInterface *MBI, MBRange elems, const int dim,
+                           MBRange &faces ) {
+  // get faces of each hex
+  const int nodes_per_face = 4;
+  const unsigned int faces_per_elem = 6;
+  unsigned int n_faces = faces_per_elem*elems.size();
+  MBEntityHandle f[n_faces][nodes_per_face];
+  int counter = 0;
+  for(MBRange::iterator i=elems.begin(); i!=elems.end(); ++i) {
+    MBRange elem_faces;
+    result = MBI->get_adjacencies( &(*i), 1, 2, true, elem_faces );
+    assert(faces_per_elem == elem_faces.size());
+    for(MBRange::iterator j=elem_faces.begin(); j!=elem_faces.end(); ++j) {
+      const MBEntityHandle *conn;
+      int n_nodes;
+      MBErrorCode result = MBI->get_connectivity( *j, conn, n_nodes );
+      assert(nodes_per_face == n_nodes);
+      // Sort the node handles of the face
+      for(int k=0; k<nodes_per_face; ++k) f[counter][k] = conn[k];
+      qsort( &f[counter][0], nodes_per_face, sizeof(MBEntityHandle), handle_compare );
+      ++counter;
+  // Sort the faces by the first node handle, then second node, then third node...
+  qsort( &f[0][0], n_faces, nodes_per_face*sizeof(MBEntityHandle), compare_face );
+  // if a face has 1 or more duplicates, it is not on the skin
+  faces.clear();
+  for(unsigned int i=0; i<n_faces; ++i) {
+    // if the last face is tested, it must be on the skin
+    if(n_faces-1 == i) {
+      MBRange face_handle;
+      result = MBI->get_adjacencies( &(f[i][0]), nodes_per_face, 2, false, face_handle );
+      assert(1 == face_handle.size());
+      faces.insert( face_handle.front() );
+      // Due to sort, if a duplicate exists it must be next
+    } else if( f[i][0]==f[i+1][0] && f[i][1]==f[i+1][1] &&
+               f[i][2]==f[i+1][2] && f[i][3]==f[i+1][3] ) {
+      ++i;
+      while( f[i][0]==f[i+1][0] && f[i][1]==f[i+1][1] &&
+	std::cout << "    skin WARNING: non-manifold face" << std::endl;
+        ++i;
+      // otherwise it is on the skin
+    } else {
+// Given a 1D array of data, axis labels, title, and number of bins, create a
+// histogram.
+void plot_histogram( const std::string title,
+                     const std::string x_axis_label, const std::string y_axis_label,
+                     const int n_bins, const double data[], const int n_data ) {
+  // find max and min
+  double min = std::numeric_limits<double>::max();
+  double max = -std::numeric_limits<double>::max();
+  for(int i=0; i<n_data; ++i) {
+    if(min > data[i]) min = data[i];
+    if(max < data[i]) max = data[i];
+  // make bins for histogram
+  double bin_width = (max-min)/n_bins;
+  int bins[n_bins];
+  for(int i=0; i<n_bins; ++i) bins[i] = 0;
+  // fill the bins
+    double diff = data[i] - min;
+    int bin = diff/bin_width;
+    if(9<bin) bin = 9; // cheap fix for numerical precision error
+    if(0>bin) bin = 0; // cheap fix for numerical precision error
+    ++bins[bin];
+  // create bars
+  int max_bin = 0;
+  for(int i=0; i<n_bins; ++i) if(max_bin < bins[i]) max_bin = bins[i];
+  int bar_height;
+  int max_bar_chars = 72;
+  std::string bars[n_bins];
+  for(int i=0; i<n_bins; ++i) {
+    bar_height = (max_bar_chars*bins[i])/max_bin;
+    for(int j=0; j<bar_height; ++j) bars[i] += "*";
+  // print histogram header
+  std::cout << std::endl;
+  std::cout << "                                 " << title << std::endl;
+  // print results
+  std::cout.width(15);
+  std::cout << min << std::endl;
+    std::cout << min+((i+1)*bin_width);
+    std::cout.width(max_bar_chars);
+    std::cout << bars[i] << bins[i] << std::endl;
+  // print histogram footer
+  std::cout << y_axis_label;
+  std::cout << " " << x_axis_label << std::endl;
+// This is a helper function that creates data and labels for histograms.
+void generate_plots( const double orig[], const double defo[],
+                     const int n_elems, const std::string time_step ) {
+  // find volume ratio then max and min
+  double ratio[n_elems];
+  for(int i=0; i<n_elems; ++i) ratio[i] = (defo[i]-orig[i])/orig[i];
+  plot_histogram( "Predeformed Element Volume", "Num_Elems", "Volume", 10, orig, n_elems );
+  std::string title = "Element Volume Change Ratio at Time Step " + time_step;
+  plot_histogram( title, "Num_Elems", "Volume Ratio", 10, ratio, n_elems );
+// Given four nodes, calculate the tet volume.
+inline static double tet_volume( const MBCartVect& v0,
+                                 const MBCartVect& v1,
+                                 const MBCartVect& v2,
+                                 const MBCartVect& v3 )
+  return 1./6. * ( ((v1 - v0) * (v2 - v0)) % (v3 - v0) );
+// Measure and tet volume are taken from measure.cpp
+double measure(MBInterface *MBI, const MBEntityHandle element) {
+  MBEntityType type = MBI->type_from_handle( element );
+  int num_vertices;
+  MBErrorCode result = MBI->get_connectivity( element, conn, num_vertices );
+  MBCartVect coords[num_vertices];
+  result = MBI->get_coords( conn, num_vertices, coords[0].array() );
+  switch( type )
+    case MBEDGE:
+      return (coords[0] - coords[1]).length();
+    case MBTRI:
+      return 0.5 * ((coords[1] - coords[0]) * (coords[2] - coords[0])).length();
+    case MBQUAD:
+      num_vertices = 4;
+    case MBPOLYGON:
+	MBCartVect mid(0,0,0);
+	for (int i = 0; i < num_vertices; ++i)
+	  mid += coords[i];
+	mid /= num_vertices;
+	double sum = 0.0;
+	    int j = (i+1)%num_vertices;
+	    sum += ((mid - coords[i]) * (mid - coords[j])).length();
+	return 0.5 * sum;
+    case MBTET:
+      return tet_volume( coords[0], coords[1], coords[2], coords[3] ) ;
+    case MBPYRAMID:
+      return tet_volume( coords[0], coords[1], coords[2], coords[4] ) +
+	tet_volume( coords[0], coords[2], coords[3], coords[4] ) ;
+    case MBPRISM:
+      return tet_volume( coords[0], coords[1], coords[2], coords[5] ) +
+	tet_volume( coords[3], coords[5], coords[4], coords[0] ) +
+	tet_volume( coords[1], coords[4], coords[5], coords[0] ) ;
+    case MBHEX:
+      return tet_volume( coords[0], coords[1], coords[3], coords[4] ) +
+	tet_volume( coords[7], coords[3], coords[6], coords[4] ) +
+	tet_volume( coords[4], coords[5], coords[1], coords[6] ) +
+	tet_volume( coords[1], coords[6], coords[3], coords[4] ) +
+	tet_volume( coords[2], coords[6], coords[3], coords[1] ) ;
+    default:
+      return 0.0;
+/* Calculate the signed volumes beneath the surface (x 6.0). Use the triangle's
+   cannonical sense. Do not take sense tags into account. Code taken from
+   DagMC::measure_volume. */
+MBErrorCode get_signed_volume( MBInterface *MBI,
+                               const MBEntityHandle surf_set,
+                               double &signed_volume) {
+  MBErrorCode rval;
+  MBRange tris;
+  rval = MBI->get_entities_by_type( surf_set, MBTRI, tris );
+  signed_volume = 0.0;
+  int len;
+  MBCartVect coords[3];
+  for (MBRange::iterator j = tris.begin(); j != tris.end(); ++j) {
+    rval = MBI->get_connectivity( *j, conn, len, true );
+    if (MB_SUCCESS != rval) return rval;
+    assert(3 == len);
+    rval = MBI->get_coords( conn, 3, coords[0].array() );
+    coords[1] -= coords[0];
+    coords[2] -= coords[0];
+    signed_volume += (coords[0] % (coords[1] * coords[2]));
+// The cgm and cub surfaces may not have the same sense. Create triangles that
+// represent the quads in the cub surface. Calculate the signed volume of both
+// the cgm and cub surface. If they are different, change the cgm sense so that
+// it matches the sense of the cub surface.
+MBErrorCode fix_surface_senses( MBInterface *MBI,
+                                const MBEntityHandle cgm_file_set,
+                                const MBEntityHandle cub_file_set,
+                                const MBTag idTag, const MBTag dimTag, const MBTag senseTag,
+  const void* const two_val[] = {&two};
+  MBRange cgm_surfs;
+  result = MBI->get_entities_by_type_and_tag(cgm_file_set, MBENTITYSET, &dimTag,
+						 two_val, 1, cgm_surfs );
+  if(MB_SUCCESS != result) return result;
+  for(MBRange::iterator i=cgm_surfs.begin(); i!=cgm_surfs.end(); i++) {
+    int surf_id;
+    result = MBI->tag_get_data(idTag, &(*i), 1, &surf_id);
+    // Find the meshed surface set with the same id
+    MBRange cub_surf;
+    const MBTag tags[] = {idTag, dimTag};
+    const void* const tag_vals[] = { &surf_id, &two };
+    result = MBI->get_entities_by_type_and_tag(cub_file_set, MBENTITYSET, tags,
+						   tag_vals, 2, cub_surf );
+    if(1 != cub_surf.size()) {
+      std::cout << "  surf_id=" << surf_id << " no meshed surface found"
+                << std::endl;
+      continue;
+    // Get tris that represent the quads of the cub surf
+    MBRange quads;
+    result = MBI->get_entities_by_type( cub_surf.front(), MBQUAD, quads );
+    MBRange cub_tris;
+    result = make_tris_from_quads( MBI, quads, cub_tris );
+    // Add the tris to the same surface meshset as the quads are inside.
+    result = MBI->add_entities( cub_surf.front(), cub_tris );
+    assert( MB_SUCCESS == result);
+    // get the signed volume for each surface representation
+    double cgm_signed_vol, cub_signed_vol;
+    result = get_signed_volume( MBI,               *i, cgm_signed_vol );
+    result = get_signed_volume( MBI, cub_surf.front(), cub_signed_vol );
+    if(debug) std::cout << "  surf_id=" << surf_id << " cgm_signed_vol="
+      << cgm_signed_vol << " cub_signed_vol=" << cub_signed_vol << std::endl;
+    // If the sign is different, reverse the cgm senses so that both
+    // representations have the same signed volume.
+    if( (cgm_signed_vol<0 && cub_signed_vol>0) ||
+	(cgm_signed_vol>0 && cub_signed_vol<0) ) {
+      MBEntityHandle cgm_surf_volumes[2], reversed_cgm_surf_volumes[2];
+      result = MBI->tag_get_data( senseTag, &(*i), 1, cgm_surf_volumes );
+      reversed_cgm_surf_volumes[0] = cgm_surf_volumes[1];
+      reversed_cgm_surf_volumes[1] = cgm_surf_volumes[0];
+      result = MBI->tag_set_data( senseTag, &(*i), 1, reversed_cgm_surf_volumes );
+  // The quads in the cub_file_set have been updated for dead elements. For each
+  // cgm_surf, if there exists a cub_surf with the same id, replace the cgm tris
+  // with cub_tris (created from the quads). Note the a surface that is not
+  // meshed (in cub file) will not be effected.
+MBErrorCode replace_faceted_cgm_surfs( MBInterface *MBI,
+  for(MBRange::iterator i=cgm_surfs.begin(); i!=cgm_surfs.end(); ++i) {
+    int surf_id;
+    if(debug) std::cout << "surf_id=" << surf_id << std::endl;
+    MBRange cub_surf;
+      std::cout << " Surface " << surf_id << ": no meshed representation found" << std::endl;
+      continue;
+    MBRange quads;
+    MBRange cub_tris;
+    // Remove the tris from the cgm surf. Don't forget to remove them from the
+    // cgm_file_set because it is not TRACKING.
+    MBRange cgm_tris;
+    result = MBI->get_entities_by_type( *i, MBTRI, cgm_tris );
+    result = MBI->remove_entities( *i, cgm_tris );
+    result = MBI->remove_entities( cgm_file_set, cgm_tris );
+    result = MBI->delete_entities( cgm_tris );
+    // Add the cub_tris to the cgm_surf
+    result = MBI->add_entities( *i, cub_tris );
+// Dead elements need removed from the simulation. This is done by removing them
+// from their volume set and adding them to the implicit complement. New surfaces
+// must be created for this.
+// IF MODIFYING THIS CODE, BE AWARE THAT DEAD ELEMENTS CAN BE ADJACENT TO MORE
+// THAN ONE SURFACE, MAKING THE ASSOCIATION BETWEEN NEWLY EXPOSED AND EXISTING
+// SURFACES AMBIGUOUS.
+MBErrorCode add_dead_elems_to_impl_compl( MBInterface *MBI,
+                                          const MBTag categoryTag, const MBTag senseTag,
+  // Get the cgm surfaces
+  // Get the maximum surface id. This is so that new surfaces to do have
+  // duplicate ids.
+  int max_surf_id = -1;
+  for(MBRange::const_iterator i=cgm_surfs.begin(); i!=cgm_surfs.end(); ++i) {
+    int surf_id;
+    result = MBI->tag_get_data( idTag, &(*i), 1, &surf_id );
+    if(max_surf_id < surf_id) max_surf_id = surf_id;
+  std::cout << "  Maximum surface id=" << max_surf_id << std::endl;
+  // For each cgm volume, does a cub volume with the same id exist?
+  const int three = 3;
+  const void* const three_val[] = {&three};
+  MBRange cgm_vols;
+					     three_val, 1, cgm_vols );
+  // get the corresponding cub volume
+  for(MBRange::iterator i=cgm_vols.begin(); i!=cgm_vols.end(); i++) {
+    int vol_id;
+    result = MBI->tag_get_data(idTag, &(*i), 1, &vol_id);
+    std::cout << "  Volume " << vol_id << std::endl;
+    // Find the meshed vol set with the same id
+    MBRange cub_vol;
+    const void* const tag_vals[] = { &vol_id, &three };
+					       tag_vals, 2, cub_vol );
+    if(1 != cub_vol.size()) {
+      std::cout << "    no meshed volume found" << std::endl;
+      continue;
+    // get the mesh elements of the volume.
+    MBRange elems;
+    result = MBI->get_entities_by_type( cub_vol.front(), MBHEX, elems );
+    if(debug) std::cout << "    found " << elems.size() << " hex elems" << std::endl;
+    // skin the volumes
+    // BEWARE: THE MBSKINNER DOES NOT PRODUCE THE EXPECTED RESULT. CONFIRMED IN VISIT.
+    MBSkinner tool(MBI);
+    MBRange moab_faces, my_faces;
+    result = tool.find_skin( elems, 2, moab_faces, true );
+    skin_hex_elems( MBI, elems, 2, my_faces );
+    if(debug) std::cout << "    moab_faces=" << moab_faces.size() << " my_faces="
+	      << my_faces.size() << std::endl;
+    // get cub child surfaces.
+    MBRange cub_surfs;
+    result = MBI->get_child_meshsets( cub_vol.front(), cub_surfs );
+    for(MBRange::iterator j=cub_surfs.begin(); j!=cub_surfs.end(); ++j) {
+      // get the quads on each surface
+      MBRange cub_faces;
+      result = MBI->get_entities_by_type( *j, MBQUAD, cub_faces );
+      // Meshed volumes must have meshed surfaces
+      assert(!cub_faces.empty());
+      // get the faces common to both the skin and this surface
+      MBRange common_faces = intersect( cub_faces, my_faces );
+      // find the surfaces faces not on the skin - these are orphaned and need removed
+      MBRange orphaned_faces = subtract( cub_faces, common_faces );
+      result = MBI->remove_entities( *j, orphaned_faces );
+      int surf_id;
+      result = MBI->tag_get_data( idTag, &(*j), 1, &surf_id );
+      // remove the common faces from the skin faces
+      my_faces = subtract( my_faces, common_faces );
+      // If no orphaned faces exist we are done
+      if(orphaned_faces.empty()) continue;
+      std::cout << "    Surface " << surf_id << " had " << orphaned_faces.size()
+		<< " orphaned faces removed" << std::endl;
+      // place the orphaned faces in a new surface. Get the parent vols of the
+      // surf.
+      MBRange cgm_surf;
+      result = MBI->get_entities_by_type_and_tag(cgm_file_set, MBENTITYSET, tags,
+						 tag_vals, 2, cgm_surf );
+      assert(1 == cgm_surf.size());
+      MBEntityHandle cgm_vols[2], cub_vols[2];
+      result = MBI->tag_get_data( senseTag, cgm_surf, &cgm_vols );
+      result = MBI->tag_get_data( senseTag, &(*j), 1, &cub_vols );
+      // for the new surf, replace the current volume with the impl compl vol.
+      // This is because the faces that no longer exist will become adjacent to
+      // the impl compl
+      if(*i == cgm_vols[0]) {
+	cgm_vols[0] = 0;
+	cub_vols[0] = 0;
+      if(*i == cgm_vols[1]) {
+	cgm_vols[1] = 0;
+	cub_vols[1] = 0;
+      // If both sides of the surface are the impl comp, do not create the surface.
+      if(0==cgm_vols[0] && 0==cgm_vols[1]) {
+	std::cout << "    New surface was not created for orphaned faces because both parents are impl_compl volume " << std::endl;
+	continue;
+      // build the new surface, convert quads to tris, and add the faces.
+      MBEntityHandle new_cgm_surf, new_cub_surf;
+      ++max_surf_id;
+      result = build_new_surface( MBI, new_cgm_surf,
+				  cgm_vols[0], cgm_vols[1], max_surf_id,
+				  dimTag, idTag,
+				  categoryTag, senseTag );
+      result = build_new_surface( MBI, new_cub_surf,
+				  cub_vols[0], cub_vols[1], max_surf_id,
+				  dimTag, idTag,
+      // add the new surface to the file set and populate it with faces
+      result = MBI->add_entities( cgm_file_set, &new_cgm_surf, 1 );
+      result = MBI->add_entities( cub_file_set, &new_cub_surf, 1 );
+      result = MBI->add_entities( new_cub_surf, orphaned_faces );
+      std::cout << "    Surface " << max_surf_id << " was created for "
+		<< orphaned_faces.size() << " orphaned faces" << std::endl;
+    // remaining skin faces must be assigned to a surface
+    if(my_faces.empty()) continue;
+    std::cout << "    Surface " << max_surf_id+1 << " will be created for "
+	      << my_faces.size() << " dead skin faces" << std::endl;
+    // Ensure that faces are oriented outwards
+    result = orient_faces_outward( MBI, my_faces, debug );
+    // Create the new surface.
+    ++max_surf_id;
+				*i, 0, max_surf_id,
+				dimTag, idTag,
+				cub_vol.front(), 0, max_surf_id,
+				dimTag, idTag,
+    // Insert the new surf into file sets and populate it with faces.
+    result = MBI->add_entities( new_cub_surf, my_faces );
 /* Get the type of a file.
    Return value is one of the above constants
 const char* get_geom_file_type( const char* filename );
 const char* get_geom_fptr_type( FILE* file );
@@ -28,144 +718,254 @@
 int is_acis_bin_file( FILE* file );
 int is_occ_brep_file( FILE* file );
-void usage(char *name);
-void print_usage(char *name);
-void help(char *name);
 double DEFAULT_DISTANCE = 0.001;
 double DEFAULT_LEN = 0.0;
 int DEFAULT_NORM = 5;
+// load cub file
+// load cgm file
+// for each surface
+//   convert cub surf quads to tris
+//   get signed volume from cgm and cub surf         MUST COME BEFORE COORD UPDATE, NEEDS TRIS
+//   reverse cgm surface sense if needed
+//   replace cgm surf tris with cub surf tris
+//   X remove quads from cub surf
+// measure volume of predeformed cub elements
+// convert cub volumes sets to tracking so that dead elems are removed from vol sets
+// update coordinates and delete dead elems
+// measure volume of deformed cub elems
+// print histogram of volume change
+// for each cub volume
+//   skin volume elems to get faces
+//   for each child cub surface
+//     remove surface faces that are not in skin
+//   orient each skin face outward
+//   assign new (leftover) skin faces to a surface
+//   remove existing tris (from before the update)
+//   convert quads to tris
 int main( int argc, char* argv[] )
-  char *name = argv[0];
+  const bool debug = false;
   const char *file_type = NULL;
-  const char* input_name = 0;
-  const char* update_name = 0;
-  const char* output_name = 0;
+  const char* cub_name = 0;
+  const char* exo_name = 0;
+  const char* out_name = 0;
   const char* time_step = 0;
+  const char* sat_name = 0;
   double dist_tol = 0.001, len_tol = 0.0;
   int norm_tol = 5;
-  bool actuate_attribs = true;
-    // Process CL args
-  bool process_options = true;
-  if(argc < 5)
-    std::cerr << "Need a cub file, an update exodus file, an export h5m file and a time step." <<std::endl;
-    exit(4);
+  if(4!=argc && 6!=argc && 7!=argc)
+      std::cerr << "To read meshed geometry for DagMC:" << std::endl;
+      std::cerr << "$> cub_file acis_file output_file" << std::endl;
+      std::cerr << "To read meshed geometry for DagMC and update node coordinates:" << std::endl;
+      std::cerr << "$> <cub_file.cub> <acis_file.sat> <output_file.h5m> <deformed_exo_file.e> time_step<int> check_vol_change<bool>"
+		<< std::endl;
+      exit(4);
+  // check filenames for proper suffix
+  std::string temp;
+  cub_name = argv[1];
+  temp.assign(cub_name);
+  if(std::string::npos == temp.find(".cub")) {
+    std::cerr << "cub_file does not have correct suffix" << std::endl;
+    return 1;
+  sat_name = argv[2]; // needed because the cub file's embedded sat file does not have groups
+  temp.assign(sat_name);
+  if(std::string::npos == temp.find(".sat")) {
+    std::cerr << "sat_file does not have correct suffix" << std::endl;
+    return 1;
+  out_name = argv[3];
+  temp.assign(out_name);
+  if(std::string::npos == temp.find(".h5m")) {
+    std::cerr << "out_file does not have correct suffix" << std::endl;
+    return 1;
-  for (int i = 1; i < argc; ++i) {
-    if (!process_options || argv[i][0] != '-') {
-      if(input_name && update_name && output_name)
-        time_step = argv[i];
-      else if (input_name && update_name)
-        output_name = argv[i];
-      else if(input_name)
-        update_name = argv[i];
-      else
-        input_name = argv[i];
-      continue;
+  // Should the nodes be updated?
+  bool update_coords = false;
+  if(6 <= argc) {
+    exo_name = argv[4];
+    temp.assign(exo_name);
+    if(std::string::npos == temp.find(".e")) {
+      std::cerr << "e_file does not have correct suffix" << std::endl;
+      return 1;
+    time_step= argv[5];
+    update_coords = true;
-    // Initialize CGM
-  InitCGMA::initialize_cgma();
-  if (actuate_attribs) {
-    CGMApp::instance()->attrib_manager()->set_all_auto_read_flags( actuate_attribs );
-    CGMApp::instance()->attrib_manager()->set_all_auto_actuate_flags( actuate_attribs );
+  // Should the volume change be determined?
+  bool determine_volume_change = false;
+  if(7 == argc) {
+    temp.assign(argv[6]);
+    if(std::string::npos != temp.find("true")) determine_volume_change = true;
-    // Get CGM file type
+  // Get CGM file type
   if (!file_type) {
-    file_type = get_geom_file_type( input_name );
+    file_type = get_geom_file_type( cub_name );
     if (!file_type) {
-      std::cerr << input_name << " : unknown file type, try '-t'" << std::endl;
+      std::cerr << cub_name << " : unknown file type, try '-t'" << std::endl;
       exit(1);
-    // If CUB file, extract ACIS geometry
-  CubitStatus s;
-  if (!strcmp( file_type, "CUBIT" )) {
-    char* temp_name = tempnam( 0, "cgm" );
-    if (!temp_name) {
-      perror(name);
-      exit(2);
+  // Read the mesh from the cub file with Tqcdfr
+  MBCore *MBI = new MBCore();
+  MBEntityHandle cub_file_set;
+  result = MBI->create_meshset( 0, cub_file_set );
+  //char cub_options[256] = "120";
+  //result = MBI->load_file(cub_name, cub_file_set, cub_options, NULL, 0, 0);
+  result = MBI->load_file(cub_name, &cub_file_set, 0, NULL, 0, 0);
+  std::cout << "Mesh file read." << std::endl;
+  // Read the ACIS file with ReadCGM
+  char cgm_options[256];
+  sprintf(cgm_options,
+	  "CGM_ATTRIBS=yes;FACET_DISTANCE_TOLERANCE=%g;FACET_NORMAL_TOLERANCE=%d;MAX_FACET_EDGE_LENGTH=%g;",
+	  dist_tol,norm_tol,len_tol);
+  MBEntityHandle cgm_file_set;
+  result = MBI->create_meshset( 0, cgm_file_set );
+  result = MBI->load_file(sat_name, &cgm_file_set, cgm_options,NULL,0,0);
+  std::cout << "Geometry file read." << std::endl;
-    FILE* cub_file = fopen( input_name, "r" );
-    if (!cub_file) {
-      free(temp_name);
-      perror(input_name);
-      exit(2);
+  // Create tags
+  MBTag dimTag, idTag, categoryTag, senseTag;
+  result = MBI->tag_create(GEOM_DIMENSION_TAG_NAME, sizeof(int), MB_TAG_DENSE,
+			       MB_TYPE_INTEGER, dimTag, NULL, true );
+  result = MBI->tag_create(GLOBAL_ID_TAG_NAME, sizeof(int), MB_TAG_DENSE,
+			       MB_TYPE_INTEGER, idTag, NULL, true );
+  result = MBI->tag_create(CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE, MB_TAG_SPARSE,
+			       MB_TYPE_OPAQUE, categoryTag, NULL, true );
+  result = MBI->tag_create("GEOM_SENSE_2", 2*sizeof(MBEntityHandle), MB_TAG_DENSE,
+			       MB_TYPE_HANDLE, senseTag, NULL, true );
-    FILE* tmp_file = fopen( temp_name, "w" );
-    if (!tmp_file) {
-      free(temp_name);
-      perror(temp_name);
-      exit(2);
+  // Create triangles from the quads of the cub surface sets and add them to the
+  // cub surface sets. Get the signed volume of each surface for both cgm and
+  // cub representations. Change the sense of the cgm representation to match
+  // the cub representation.
+  result = fix_surface_senses( MBI, cgm_file_set, cub_file_set, idTag, dimTag, senseTag, debug );
+  std::cout << "Fixed geometry surface senses to match meshed surface senses." << std::endl;
+  // Get the 3D elements in the cub file and measure their volume.
+  MBRange orig_elems;
+  std::vector<double> orig_size;
+  if(determine_volume_change) {
+    result = MBI->get_entities_by_dimension( 0, 3, orig_elems );
+    orig_size.resize(orig_elems.size());
+    for(unsigned int i=0; i<orig_elems.size(); ++i) {
+      orig_size[i] = measure( MBI, orig_elems[i] );
-    MBCore *my_impl = new MBCore();
-    Tqdcfr *my_tqd = new Tqdcfr(my_impl);
-    ReadNCDF my_ex_reader(my_impl);
-    char options[120] = "tdata=coord,";
-    strcat(options, time_step);
-    strcat(options,",set");
-    FileOptions opts(options)  ;
-    MBErrorCode result = my_tqd->load_file(input_name, 0, opts, NULL, 0, 0);
+  // Before updating the nodes and removing dead elements, force the cub volume
+  // sets to track ownership so that dead elements will be deleted from the sets.
+  MBRange cub_vols;
+  result = MBI->get_entities_by_type_and_tag(cub_file_set, MBENTITYSET, &dimTag,
+						 three_val, 1, cub_vols );
+  for(MBRange::const_iterator i=cub_vols.begin(); i!=cub_vols.end(); ++i) {
+    result = MBI->set_meshset_options( *i, MESHSET_TRACK_OWNER );
+  // Update the coordinates if needed. Do not do this before checking surface
+  // sense, because the coordinate update could deform the surfaces too much
+  // to make an accurate comparison.
+  // The cub node ids are unique because cgm vertex ids are tagged on the vertex
+  // meshset and not the vertex itself.
+  //result = MBI->delete_entities( &cub_file_set, 1 );
+  //assert(MB_SUCCESS == result);
+  // Assume dead elements exist until I think of something better.
+  bool dead_elements_exist = true;
+  if(update_coords) {
+    ReadNCDF my_ex_reader(MBI);
+    char exo_options[120] = "tdata=coord,";
+    strcat(exo_options, time_step);
+    strcat(exo_options,",set");
+    FileOptions exo_opts(exo_options)  ;
     //opts = "tdata=coord, 100, sum, temp.exo";
-    result =  my_ex_reader.load_file(update_name, 0, opts, NULL, 0 , 0);
+    //result =  my_ex_reader.load_file(exo_name, cgm_file_set, exo_opts, NULL, 0 , 0);
+    //result =  my_ex_reader.load_file(exo_name, cub_file_set, exo_opts, NULL, 0 , 0);
+    result = my_ex_reader.load_file(exo_name, &cub_file_set, exo_opts, NULL, 0 , 0);
+    if(MB_SUCCESS != result) {
+      std::cout << "coordinate update failed" << std::endl;
+      return result;
+    std::cout << "Updated mesh nodes with deformed coordinates from exodus file." << std::endl;
-    // convert the quads to tris
-    quads_to_tris( my_impl, 0 );
+    // Dead elements have been removed by the deformation. Get the elements that
+    // still exist.
+    MBRange defo_elems;
+    result = MBI->get_entities_by_dimension( 0, 3, defo_elems );
+    // Determine the volume of the elements now that a deformation has been
+    // applied. Condense the original array by removing dead elements.
+    double orig_size_condensed[defo_elems.size()];
+    double defo_size_condensed[defo_elems.size()];
+    int j=0;
+      if(orig_elems[i] == defo_elems[j]) {
+	orig_size_condensed[j] = orig_size[i];
+	defo_size_condensed[j] = measure( MBI, defo_elems[j] );
+	++j;
+    generate_plots( orig_size_condensed, defo_size_condensed,
+		    defo_elems.size(), std::string(time_step) );
-    result = my_impl->write_mesh( output_name );
-    assert(!result);
+  // Deal with dead elements. For now, add them to the impl_compl volume.
+  // Extra surfaces are created to do this.
+  if(update_coords && dead_elements_exist) {
+    result = add_dead_elems_to_impl_compl( MBI, cgm_file_set, cub_file_set,
+                                           idTag, dimTag, categoryTag, senseTag, debug );
+    std::cout << "Placed dead elements to implicit complement volume and added required surfaces." << std::endl;
-  return 0;
-  std::cout << "Usage: " << std::endl;
-  std::cout << name <<
-      " [-d <tol>|-D] [-n <tol>|-N] [-l <tol>|-L] [-A|-a] [-t <type>] <input_file> <outupt_file>" <<
-      std::endl;
-  std::cout << name << " -h" << std::endl;
+  result = replace_faceted_cgm_surfs( MBI, cgm_file_set, cub_file_set, idTag, dimTag, debug );
+  std::cout << "Replaced faceted geometry surfaces with meshed surfaces of triangles." << std::endl;
-  print_usage(name);
-  exit(1);
+  result = MBI->write_mesh( out_name, &cgm_file_set, 1 );
+    std::cout << "write mesh failed" << std::endl;
+    return result;
+  std::cout << "Saved output file for mesh-based analysis." << std::endl;
+  return 0;
-  std::cout << "\t-d  max. distance deviation between facet and geometry" << std::endl
-            << "\t-D  no distance tolerance" << std::endl
-            << "\t    (default:" << DEFAULT_DISTANCE << ")" <<std::endl
-            << "\t-n  max. normal angle deviation (degrees) between facet and geometry" << std::endl
-            << "\t    (default:" << DEFAULT_NORM << ")" <<std::endl
-            << "\t-N  no normal tolerance" << std::endl
-            << "\t-l  max. facet edge length" << std::endl
-            << "\t-L  no facet edge length maximum" << std::endl
-            << "\t    (default:" << DEFAULT_LEN << ")" << std::endl
-            << "\t-a  force actuation of all CGM attributes" << std::endl
-            << "\t-A  disable all CGM attributes" << std::endl
-            << "\t-t  specify input file type (default is autodetect)" << std::endl
-            << std::endl;
-  exit(0);
 const char* get_geom_file_type( const char* name )
   FILE* file;
@@ -209,32 +1009,32 @@
   unsigned char buffer[4];
   return !fseek(file, 0, SEEK_SET) &&
-         fread(buffer, 4, 1, file) &&
-         !memcmp(buffer, "CUBE", 4);
+    fread(buffer, 4, 1, file) &&
+    !memcmp(buffer, "CUBE", 4);
 int is_step_file( FILE* file )
   unsigned char buffer[9];
-         fread(buffer, 9, 1, file) &&
-         !memcmp(buffer, "ISO-10303", 9);
+    fread(buffer, 9, 1, file) &&
+    !memcmp(buffer, "ISO-10303", 9);
 int is_iges_file( FILE* file )
   unsigned char buffer[10];
   return !fseek(file, 72, SEEK_SET) &&
-         fread(buffer, 10, 1, file) &&
-         !memcmp(buffer, "S      1\r\n", 10);
+    fread(buffer, 10, 1, file) &&
+    !memcmp(buffer, "S      1\r\n", 10);
   char buffer[15];
-         fread(buffer, 15, 1, file) &&
-         !memcmp(buffer, "ACIS BinaryFile", 9);
+    fread(buffer, 15, 1, file) &&
+    !memcmp(buffer, "ACIS BinaryFile", 9);
 int is_acis_txt_file( FILE* file )
@@ -249,11 +1049,11 @@
   if (version < 1 || version >0xFFFF)
     return 0;
-    // Skip appliation name
+  // Skip appliation name
   if (fseek(file, length, SEEK_CUR))
     return 0;
-    // Read length of version string followed by first 5 characters
+  // Read length of version string followed by first 5 characters
   if (2 != fscanf(file, "%d %4s", &length, buffer))
     return 0;
@@ -264,6 +1064,6 @@
   unsigned char buffer[6];
-         fread(buffer, 6, 1, file) &&
-         !memcmp(buffer, "DBRep_", 6);
+    fread(buffer, 6, 1, file) &&
+    !memcmp(buffer, "DBRep_", 6);
Modified: MOAB/trunk/tools/dagmc/quads_to_tris.cpp
--- MOAB/trunk/tools/dagmc/quads_to_tris.cpp	2009-12-22 15:45:06 UTC (rev 3420)
+++ MOAB/trunk/tools/dagmc/quads_to_tris.cpp	2009-12-22 16:53:16 UTC (rev 3421)
@@ -40,6 +40,21 @@
   return MB_SUCCESS;
+MBErrorCode make_tris_from_quads( MBInterface *MBI,
+                                  const MBRange quads,
+                                  MBRange &tris ) {
+  tris.clear();
+  for(MBRange::const_iterator i=quads.begin(); i!=quads.end(); ++i) {
+    MBEntityHandle tri0, tri1;
+    result = make_tris_from_quad( MBI, *i, tri0, tri1 );
+    tris.insert( tri0 );
+    tris.insert( tri1 );
 MBErrorCode quads_to_tris( MBInterface *MBI, MBEntityHandle input_meshset ) {
   // create a geometry tag to find the surfaces with
Modified: MOAB/trunk/tools/dagmc/quads_to_tris.hpp
--- MOAB/trunk/tools/dagmc/quads_to_tris.hpp	2009-12-22 15:45:06 UTC (rev 3420)
+++ MOAB/trunk/tools/dagmc/quads_to_tris.hpp	2009-12-22 16:53:16 UTC (rev 3421)
@@ -15,4 +15,6 @@
                                  MBEntityHandle &tri0, /* output */
 				 MBEntityHandle &tri1  /* output */);
+MBErrorCode make_tris_from_quads( MBInterface *MBI, const MBRange quads, MBRange &tris ) ;
 MBErrorCode quads_to_tris( MBInterface *MBI, MBEntityHandle input_meshset );
