[MOAB-dev] r3419 - MOAB/trunk/test/obb
bmsmith6 at wisc.edu
Fri Dec 18 15:11:40 CST 2009
Author: bmsmith
Date: 2009-12-18 15:11:40 -0600 (Fri, 18 Dec 2009)
New Revision: 3419
Modified:
MOAB/trunk/test/obb/obb_test.cpp
MOAB/trunk/test/obb/obb_time.cpp
Log:
Fix ray_intersect_sets calls from previous commit.
Modified: MOAB/trunk/test/obb/obb_test.cpp
--- MOAB/trunk/test/obb/obb_test.cpp 2009-12-18 20:20:06 UTC (rev 3418)
+++ MOAB/trunk/test/obb/obb_test.cpp 2009-12-18 21:11:40 UTC (rev 3419)
@@ -954,8 +954,8 @@
const int NUM_NON_TOL_INT = 1;
std::vector<double> intersections2;
- std::vector<MBEntityHandle> surf_handles;
- rval = tool.ray_intersect_sets( intersections2, surf_handles, root_set, tolerance, NUM_NON_TOL_INT, tests[i].point.array(), tests[i].direction.array(), 0 );
+ std::vector<MBEntityHandle> surf_handles, facet_handles;
+ rval = tool.ray_intersect_sets( intersections2, surf_handles, facet_handles, root_set, tolerance, NUM_NON_TOL_INT, tests[i].point.array(), tests[i].direction.array(), 0 );
if (MB_SUCCESS != rval) {
if (verbosity)
std::cout << " Call to MBOrientedBoxTreeTool::ray_intersect_sets failed." << std::endl;
@@ -1076,9 +1076,8 @@
else {
std::vector<double> intersections;
- std::vector<MBEntityHandle> surfaces;
- rval = tool.ray_intersect_sets( intersections, surfaces, root_set, tolerance, 1000, rays[i].array(), rays[i+1].array(), 0 );
+ std::vector<MBEntityHandle> surfaces, facets;
+ rval = tool.ray_intersect_sets( intersections, surfaces, facets, root_set, tolerance, 1000, rays[i].array(), rays[i+1].array(), 0 );
std::cout << "FAILED" << std::endl;
result = false;
Modified: MOAB/trunk/test/obb/obb_time.cpp
--- MOAB/trunk/test/obb/obb_time.cpp 2009-12-18 20:20:06 UTC (rev 3418)
+++ MOAB/trunk/test/obb/obb_time.cpp 2009-12-18 21:11:40 UTC (rev 3419)
@@ -163,7 +163,7 @@
const unsigned cached = 1000;
- std::vector<MBEntityHandle> sets;
+ std::vector<MBEntityHandle> sets, facets;
MBCartVect point, dir;
std::vector<MBCartVect> randrays;
randrays.reserve( cached );
@@ -197,7 +197,8 @@
intersections.clear();
if (do_sets) {
sets.clear();
- rval = tool.ray_intersect_sets( intersections, sets, root, 1e-6, 1, point.array(), dir.array() );
+ facets.clear();
+ rval = tool.ray_intersect_sets( intersections, sets, facets, root, 1e-6, 1, point.array(), dir.array() );
else {
rval = tool.ray_intersect_triangles( intersections, root, 1e-6, point.array(), dir.array() );
