[MOAB-dev] buildbot failure in Fathom on moab-par
Tim Tautges tautges at mcs.anl.gov
Wed Dec 16 07:56:33 CST 2009
Hi all,
   FYI, this is because of a known issue (mpiexec not installed on the buildbot machine), and it's being worked on.
- tim
donotreply at mcs.anl.gov wrote:
> The Fathomatic has detected a failed build of moab-par on Fathom.
> Full details are available at:
>  http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/7
> Buildbot URL: http://gnep.mcs.anl.gov:8010/
> Buildslave for this Build: gnep
> Build Reason: The Nightly scheduler named 'nightly' triggered this build
> Build Source Stamp: None
> Blamelist:
> BUILD FAILED: failed test
> LOG EXCERPT:
> test_ghost_elements_3_2_2 : success
> test_ghost_elements_3_0_1 : success
> test_ghost_elements_2_0_1 : success
> test_ghost_tag_exchange : success
> regression_ghost_tag_exchange_no_default : success
> test_interface_owners : success
> regression_owners_with_ghosting : success
> test_ghosted_entity_shared_data : success
> All tests passed
> PASS: parallel_unit_tests
> test_read : success
> test_read : success
> test_read : success
> test_read : success
> test_read : success
> test_read : success
> test_read : success
> test_read : success
> PASS: uber_parallel_test
> Run this with 2 or 4 processes
> FAIL: scdtest
> Warning: acis file has sequence numbers!
> PASS: pcomm_serial
> Running test_write_elements ...
> Running test_write_shared_sets ...
> Running test_var_length_parallel ...
> Running test_read_elements ...
> Running test_read_elements_by_rank ...
> Running test_read_tags ...
> Running test_read_global_tags ...
> Running test_read_sets ...
> PASS: parallel_hdf5_test
> PASS: mhdf_parallel
> Using default interval count: 2
> 00:   0.00: Generating mesh
> 00:   0.00: Resolving shared entities
> 00:   0.00: Beginning parallel write
> Wrote 8 hexes in 0.01 seconds.
> 00:   0.01: Removing written file
> Wall time: generate: 0, resovle shared: 0.00390625, write_file: 0.144531
> 00:   0.01: Finalizing MPI
> PASS: parallel_write_test
> 1 of 8 tests failed
> sincerely,
>  -The Fathomatic
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
