[MOAB-dev] buildbot failure in Fathom on moab-par
donotreply at mcs.anl.gov donotreply at mcs.anl.gov
Mon Dec 14 00:05:03 CST 2009
The Fathomatic has detected a failed build of moab-par on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/5
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
00:   0.00: Resolving shared entities
00:   0.00: Beginning parallel write
Wrote 8 hexes in 0.02 seconds.
00:   0.02: Removing written file
Wall time: generate: 0, resovle shared: 0.0078125, write_file: 0.132812
00:   0.02: Finalizing MPI
PASS: parallel_write_test
1 of 8 tests failed
make[5]: *** [check-TESTS] Error 1
make[5]: Leaving directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-par/build/parallel'
make[4]: *** [check-am] Error 2
make[4]: Leaving directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-par/build/parallel'
make[3]: *** [check-recursive] Error 1
make[3]: Leaving directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-par/build/parallel'
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-par/build'
make[1]: *** [check] Error 2
make[1]: Leaving directory `/nfs/mcs-homes15/jvporter/buildslave1/moab-par/build'
sincerely,
 -The Fathomatic
