[MOAB-dev] mbchaco default arguments
Roman Putanowicz
putanowr at l5.pk.edu.pl
Sun Dec 13 21:51:10 CST 2009
I have tried to use mbchaco (more exactly ComputePartition class).
The method
MBErrorCode compute_partition(const int nprocs, const char *filename = NULL,
const bool write_file = false, const char
*out_file = NULL);
when used with default parameters fails immediately because of the
check in the code:
// check input
if (NULL == filename && NULL == out_file) return MB_FAILURE;
It seems that this method is written having in mind only the input from
file. It is easy to fix it however I got puzzling output from chaco
when trying to use mbchaco standalne:
putanowr at tomi:~/work/MOABUtils/tests$ mbchaco data/lshape.vtk y ala 4
Chaco 2.0
(MOAB-based version)
Sandia National Laboratories
Parameter file `User_Params' not found; using default parameters.
No graph input. Only allowed for inertial or simple methods without KL.
goal[0] is -0.25, but should be nonnegative.
goal[1] is -0.25, but should be nonnegative.
goal[2] is -0.25, but should be nonnegative.
goal[3] is -0.25, but should be nonnegative.
Sum of values in goal (-1) not equal to sum of vertex weights (-1).
ERROR IN INPUT.
Could someone please comment what is going on?
If I need need a special User_Params setting for mbchaco
could somebody provide a sample one? (ComputePartition class
takes arbitrary decision to make the global_method=1,
but even if I change the code and take for instance global_method=4
then there is this business of "Sum of values in goal (-1) not equal to sum of
vertex weights (-1)."
The sample mesh file I tried to partition is in attachment.
Roman
Roman Putanowicz < putanowr at l5.pk.edu.pl >
Institute for Computational Civil Engng (L-5)
Dept. of Civil Engng, Cracow Univ. of Technology
www.l5.pk.edu.pl, tel. +48 12 628 2569, fax 2034
