[MOAB-dev] r3403 - MOAB/trunk/tools/dagmc
sjackson at cae.wisc.edu
Mon Dec 7 13:28:46 CST 2009
Author: sjackson
Date: 2009-12-07 13:28:46 -0600 (Mon, 07 Dec 2009)
New Revision: 3403
Modified:
MOAB/trunk/tools/dagmc/DagMC.cpp
MOAB/trunk/tools/dagmc/DagMC.hpp
Log:
Fix CAD-based ray tracing feature within DagMC.
* At runtime, check CGM for data to determine if this feature is
available.
* Clean up code that checks for presence of needed CGM functions.
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp 2009-12-06 06:18:10 UTC (rev 3402)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp 2009-12-07 19:28:46 UTC (rev 3403)
@@ -69,9 +69,27 @@
instance_ = new DagMC(mb_impl);
+void DagMC::set_useCAD( bool use_cad ){
+ useCAD = use_cad;
+ if( useCAD ){
+ if( !have_cgm_geom ){
+ std::cerr << "Warning: CAD-based ray tracing not avaiable, because CGM has no data." << std::endl;
+ std::cerr << " your input file was probably not a CAD format." << std::endl;
+ useCAD = false;
+#ifndef HAVE_CGM_FIRE_RAY
+ std::cerr << "Warning: use_cad = 1 not supported with this build of CGM/DagMC." << std:: endl;
+ std::cerr << " Required ray-fire query not available. (Cubit-based CGM?)" << std::endl;
+ useCAD = false;
+#endif
DagMC::DagMC(MBInterface *mb_impl)
- : mbImpl(mb_impl), obbTree(mb_impl), is_geom(false)
+ : mbImpl(mb_impl), obbTree(mb_impl), have_cgm_geom(false)
// This is the correct place to uniquely define default values for the dagmc settings
options[0] = Option( "source_cell", "source cell ID, or zero if unknown", "0" );
@@ -158,21 +176,14 @@
&len);
assert( MB_SUCCESS == rval );
-#ifdef CGM
+ // if useCAD is true at this point, then we know we can call CGM's ray casting function.
if (useCAD) {
-#ifndef HAVE_CGM_FIRE_RAY
- std::cout << "use_cad = 1 not supported with this build of CGM/DagMC."
- << std::endl
- << "Required ray-fire query not available. (Cubit-based CGM?)"
- << std::endl;
- return MB_NOT_IMPLEMENTED;
-#else
rval = CAD_ray_intersect(point, dir, huge_val,
distances, surfaces, len);
if (MB_SUCCESS != rval) return rval;
-#endif
-#endif
// Find smallest intersection
if (distances.empty()) {
@@ -311,15 +322,7 @@
useDistLimit = !!atoi( options[2].value.c_str() );
- useCAD = !!atoi( options[3].value.c_str() );
- if (useCAD) {
- std::cout << "Warning: use_cad = 1 not supported with this build of "
- << "CGM/DagMC;" << std:: endl
- << std::endl;
-#endif
+ set_useCAD( !!atoi( options[3].value.c_str() ) );
facetingTolerance = strtod( options[4].value.c_str(), 0 );
if (facetingTolerance <= 0) {
@@ -371,16 +374,9 @@
std::cout << "Turned " << (useDistLimit?"ON":"OFF") << " distance limit." << std::endl;
- useCAD = !!(use_cad);
+ set_useCAD( use_cad );
std::cout << "Turned " << (useCAD?"ON":"OFF") << " ray firing on full CAD model." << std::endl;
- if (useCAD) {
- << std::endl;
-#endif
@@ -888,6 +884,11 @@
MBErrorCode rval;
+#ifdef CGM
+ // cgm must be initialized so we can check it for CAD data after the load
+ InitCGMA::initialize_cgma();
+#endif
// override default value of facetingTolerance with passed value
if (facet_tolerance > 0 )
facetingTolerance = facet_tolerance;
@@ -899,7 +900,7 @@
// what if we are using default faceting tolerance???
char options[120] = "CGM_ATTRIBS=yes;FACET_DISTANCE_TOLERANCE=";
strcat(options,facetTolStr);
rval = MBI->load_file(cfile, 0, options, NULL, 0, 0);
if( MB_UNHANDLED_OPTION == rval ){
@@ -911,14 +912,17 @@
else if (MB_SUCCESS != rval) {
- std::cerr << "Couldn't read file " << cfile << std::endl;
+ std::cerr << "DagMC Couldn't read file " << cfile << std::endl;
return rval;
- // How do we know what type of file we read for downstream issues:
- // * useCad
- // * is_geom in build_indices
+#ifdef CGM
+ // check to see if CGM has data; if so, assume it corresponds to the data we loaded in.
+ if( GeometryQueryTool::instance()->num_ref_volumes() > 0 ){
+ std::cerr << "Setting have_cgm_geom = true" << std::endl;
+ have_cgm_geom = true;
+#endif
return MB_SUCCESS;
@@ -1564,7 +1568,10 @@
#ifdef CGM
- if (is_geom) {
+ if ( have_cgm_geom ) {
+ // TODO: this block should only execute if the user has explicitly requested useCAD for ray firing.
+ // however, this function curently executes before we know if useCAD will be specified, so do it every time.
geomEntities.resize(rootSets.size());
// get geometry entities by id and cache in this vector
std::vector<int> ids;
Modified: MOAB/trunk/tools/dagmc/DagMC.hpp
--- MOAB/trunk/tools/dagmc/DagMC.hpp 2009-12-06 06:18:10 UTC (rev 3402)
+++ MOAB/trunk/tools/dagmc/DagMC.hpp 2009-12-07 19:28:46 UTC (rev 3403)
@@ -206,6 +206,9 @@
MBErrorCode build_obbs(MBRange &surfs, MBRange &vols);
MBErrorCode build_obb_impl_compl(MBRange &surfs);
+ // attempt to set useCAD, first checking for availability
+ void set_useCAD( bool use_cad );
class Option {
public:
Option(){}
@@ -241,8 +244,8 @@
double facetingTolerance;
int sourceCell;
bool useDistLimit;
- bool useCAD;
- bool is_geom;
+ bool useCAD; /// true if user requested CAD-based ray firing
+ bool have_cgm_geom; /// true if CGM contains problem geometry; required for CAD-based ray firing.
double distanceLimit;
