[MOAB-dev] Detecting file types
Tim Tautges
tautges at mcs.anl.gov
Tue Dec 1 08:57:46 CST 2009
It would help if we documented the following:
- given an extension name or file name, get the name or actual reader/writer which can handle it
- get the extensions a given reader/writer handles and possibly all the readers/writers registered
After looking again at MBReaderWriterSet and MBCore::query_interface, I think all this is already possible, it's just
not always clear how they're used. I'll put in a documentation ticket on this.
- tim
Jason Kraftcheck wrote:
> Steve Jackson wrote:
>> On Nov 30, 2009, at 15:36 , Jason Kraftcheck wrote:
>>> So you don't need to know the file type. You need to know whether or
>>> not
>>> the file contained geometry that was read into CGM. Why not just
>>> query CGM
>>> to see if it has any geometry?
>> Fair enough. That seemed to me like a roundabout way of coming at the
>> problem, but it sounds like the simplest fix.
> Well, the direct solution would be to determine whether or not MOAB used
> the ReadCGM class to read the file. But asking about the file type is
> equally indirect, as CGM can read a variety of file formats as well. If
> we do want to proved the string name of the reader, then I think the way
> to do this is to use a file set. The MOAB load_file function allows an
> optional EntitySet handle to be passed. If that handle is provided, the
> contents of the file will be added to the set. MOAB should hang
> pertinent data in tags on that set (file name, file reader name/file
> type, etc.)
> - jason
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
