[MOAB-dev] r3375 - MOAB/trunk
kraftche at cae.wisc.edu
Fri Nov 20 11:22:38 CST 2009
Author: kraftche
Date: 2009-11-20 11:22:38 -0600 (Fri, 20 Nov 2009)
New Revision: 3375
Modified:
MOAB/trunk/MBTest.cpp
Log:
more skinning tests
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp 2009-11-20 16:01:36 UTC (rev 3374)
+++ MOAB/trunk/MBTest.cpp 2009-11-20 17:22:38 UTC (rev 3375)
@@ -7653,6 +7653,228 @@
MBErrorCode mb_skin_adj_regions_reversed_test( MBInterface* )
{ return mb_skin_reversed_common( 3, true ); }
+MBErrorCode mb_skin_subset_common( int dimension, bool use_adj )
+ MBEntityType type;
+ switch (dimension) {
+ case 2: type = MBTRI; break;
+ case 3: type = MBPRISM; break;
+ default: assert(false); return MB_FAILURE;
+ /* 0
+ 5 | 1
+ | 6 |
+ 4 | 2
+ 3
+ MBErrorCode rval;
+ MBCore moab;
+ MBInterface& mb = moab;
+ MBRange expected_verts;
+ const double coords2D[7][2] = { {0,2}, {1,1}, {1,-1}, {0,-2}, {-1,-1}, {-1,1}, {0,0} };
+ MBEntityHandle verts[2][7] = { {0,0,0,0,0,0,0}, {0,0,0,0,0,0,0} };
+ for (int d = 1; d < dimension; ++d) {
+ for (int i = 0; i < 7; ++i) {
+ double coords[3] = { coords2D[i][0], coords2D[i][1], d-1 };
+ rval = mb.create_vertex( coords, verts[d-1][i] );
+ if (MB_SUCCESS != rval) return rval;
+ if (i != 4 && i != 5)
+ expected_verts.insert( verts[d-1][i] );
+ MBEntityHandle elems[6];
+ for (int i = 0; i < 6; ++i) {
+ MBEntityHandle conn[6] = { verts[0][6], verts[0][(i+1)%6], verts[0][i],
+ verts[1][6], verts[1][(i+1)%6], verts[1][i] };
+ rval = mb.create_element( type, conn, MBCN::VerticesPerEntity(type), elems[i] );
+ MBRange input;
+ input.insert( elems[0] );
+ input.insert( elems[1] );
+ input.insert( elems[2] );
+ MBRange skin;
+ MBSkinner tool(&mb);
+ rval = tool.find_skin( input, true, skin, 0, use_adj, false );
+ if (MB_SUCCESS != rval) {
+ std::cout << "Skinner failed to find skin vertices" << std::endl;
+ return MB_FAILURE;
+ if (skin != expected_verts) {
+ std::cout << "Skinner returned incorrect skin vertices" << std::endl;
+ int n = 0;
+ mb.get_number_entities_by_dimension( 0, dimension-1, n );
+ if (n > 0) {
+ std::cout << "Skinner created lower-dimension entities for vertex-only skinning" << std::endl;
+ std::vector<MBEntityHandle> sv( skin.begin(), skin.end() );
+ std::vector<int> counts( sv.size(), 0 );
+ skin.clear();
+ rval = tool.find_skin( input, false, skin, 0, use_adj, true );
+ std::cout << "Skinner failed to find skin elements" << std::endl;
+ for (MBRange::iterator i = skin.begin(); i != skin.end(); ++i) {
+ const MBEntityHandle *conn;
+ int len;
+ rval = mb.get_connectivity( *i, conn, len );
+ for (int j = 0; j < len; ++j) {
+ size_t idx = std::find(sv.begin(), sv.end(), conn[j]) - sv.begin();
+ if (idx == sv.size()) {
+ std::cout << "Skinner returned non-skin element" << std::endl;
+ counts[idx]++;
+ for (size_t i = 0; i < counts.size(); ++i) {
+ if (counts[i] < dimension) { // 2 for dim==2, {3,4,5} for dim==3
+ std::cout << "Skinner did not return all skin elements" << std::endl;
+ if ((size_t)n != skin.size()) {
+ std::cout << "Skinner created extra lower-dimension entities" << std::endl;
+ return MB_SUCCESS;
+MBErrorCode mb_skin_faces_subset_test( MBInterface* )
+ { return mb_skin_subset_common( 2, false ); }
+MBErrorCode mb_skin_adj_faces_subset_test( MBInterface* )
+ { return mb_skin_subset_common( 2, true ); }
+MBErrorCode mb_skin_regions_subset_test( MBInterface* )
+ { return mb_skin_subset_common( 3, false ); }
+MBErrorCode mb_skin_adj_regions_subset_test( MBInterface* )
+ { return mb_skin_subset_common( 3, true ); }
+MBErrorCode mb_skin_full_common( int dimension, bool use_adj )
+ case 2: type = MBQUAD; break;
+ case 3: type = MBHEX; break;
+ 3----4----5
+ 0----1----2
+ MBErrorCode rval;
+ MBCore moab;
+ // create vertices
+ const double coords2D[6][2] = { {0,0}, {1,0}, {2,0}, {0,1}, {1,1}, {2,1} };
+ MBEntityHandle v[2][6] = { {0,0,0,0,0,0}, {0,0,0,0,0,0} };
+ rval = mb.create_vertex( coords, v[d-1][i] );
+ // create elements
+ MBRange input;
+ MBEntityHandle elems[2], econn[2][8];;
+ for (int i = 0; i < 2; ++i) {
+ MBEntityHandle conn[8] = { v[0][i], v[0][i+1], v[0][i+4], v[0][i+3],
+ v[1][i], v[1][i+1], v[1][i+4], v[1][i+3] };
+ memcpy( econn[i], conn, sizeof(conn) );
+ input.insert( elems[i] );
+ // create sides
+ // NOTE: Shared side is element 0 side 1 and element 1 side 3
+ MBRange expected;
+ for (int i = 0; i < MBCN::NumSubEntities( type, dimension-1 ); ++i) {
+ MBEntityType subtype;
+ int len;
+ const short* indices = MBCN::SubEntityVertexIndices( type, dimension-1,
+ i, subtype, len );
+ MBEntityHandle conn[4];
+ assert((size_t)len <= sizeof(conn)/sizeof(conn[0]));
+ for (int j = 0; j < 2; ++j) {
+ if (j == 1 && i == 3) // don't create shared face twice
+ continue;
+ for (int k = 0; k < len; ++k)
+ conn[k] = econn[j][indices[k]];
+ MBEntityHandle h;
+ rval = mb.create_element( subtype, conn, len, h );
+ if (j != 0 || i != 1) // don't insert shared face
+ expected.insert(h);
+ MBRange skin;
+ if (skin != expected) {
+ std::cout << "Skinner returned incorrect skin elements" << std::endl;
+ int n = 0;
+ if ((size_t)n != expected.size()+1) {
+MBErrorCode mb_skin_faces_full_test( MBInterface* )
+ { return mb_skin_full_common( 2, false ); }
+MBErrorCode mb_skin_adj_faces_full_test( MBInterface* )
+ { return mb_skin_full_common( 2, true ); }
+MBErrorCode mb_skin_regions_full_test( MBInterface* )
+ { return mb_skin_full_common( 3, false ); }
+MBErrorCode mb_skin_adj_regions_full_test( MBInterface* )
+ { return mb_skin_full_common( 3, true ); }
static void usage(const char* exe) {
cerr << "Usage: " << exe << " [-nostress] [-d input_file_dir]\n";
exit (1);
@@ -7754,6 +7976,14 @@
RUN_TEST( mb_skin_adj_faces_reversed_test );
RUN_TEST( mb_skin_regions_reversed_test );
RUN_TEST( mb_skin_adj_regions_reversed_test );
+ RUN_TEST( mb_skin_faces_subset_test );
+ RUN_TEST( mb_skin_adj_faces_subset_test );
+ RUN_TEST( mb_skin_regions_subset_test );
+ RUN_TEST( mb_skin_adj_regions_subset_test );
+ RUN_TEST( mb_skin_faces_full_test );
+ RUN_TEST( mb_skin_adj_faces_full_test );
+ RUN_TEST( mb_skin_regions_full_test );
+ RUN_TEST( mb_skin_adj_regions_full_test );
RUN_TEST( mb_read_fail_test );
RUN_TEST( mb_enum_string_test );
RUN_TEST( mb_merge_update_test );
