[MOAB-dev] r3359 - MOAB/trunk/tools/iMesh
kraftche at cae.wisc.edu
Tue Nov 17 11:07:43 CST 2009
Author: kraftche
Date: 2009-11-17 11:07:43 -0600 (Tue, 17 Nov 2009)
New Revision: 3359
Modified:
MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
fix bug: iMesh_getEntities does not preserve order for list-type entity sets
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2009-11-17 16:47:01 UTC (rev 3358)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2009-11-17 17:07:43 UTC (rev 3359)
@@ -2535,7 +2535,7 @@
bool use_type = false;
// initialize just to get rid of compiler warning
MBEntityType type = mb_topology_table[iMesh_ALL_TOPOLOGIES];
- MBRange out_entities;
+ std::vector<MBEntityHandle> out_entities;
if (entity_topology >= iMesh_POINT
&& entity_topology < iMesh_ALL_TOPOLOGIES) {
@@ -2572,24 +2572,27 @@
RETURN(iBase_ERROR_MAP[result]);
- int num_ents = out_entities.size() - out_entities.num_of_type(MBENTITYSET);
+ // remove entity sets from the result list
+ std::vector<MBEntityHandle>::iterator iter, end_iter;
+ if (iBase_ALL_TYPES == entity_type && iMesh_ALL_TOPOLOGIES == entity_topology) {
+ for (iter = out_entities.begin(); iter != out_entities.end() &&
+ TYPE_FROM_HANDLE(*iter) != MBENTITYSET; ++iter);
+ for (end_iter = iter; iter != out_entities.end(); ++iter)
+ if (TYPE_FROM_HANDLE(*iter) != MBENTITYSET)
+ *(end_iter++) = *iter;
+ out_entities.erase( end_iter, out_entities.end() );
+ int num_ents = out_entities.size();
CHECK_SIZE(*entity_handles, *entity_handles_allocated,
num_ents, iBase_EntityHandle, iBase_MEMORY_ALLOCATION_FAILED);
- MBRange::iterator iter = out_entities.begin();
- MBRange::iterator end_iter = out_entities.end();
int k = 0;
// filter out entity sets here
- if (iBase_ALL_TYPES == entity_type && iMesh_ALL_TOPOLOGIES == entity_topology) {
- for (; iter != end_iter && MBI->type_from_handle(*iter) != MBENTITYSET; iter++)
- (*entity_handles)[k++] = (iBase_EntityHandle)*iter;
- else {
- for (; iter != end_iter; iter++)
+ for (iter = out_entities.begin(); iter != out_entities.end(); iter++)
+ (*entity_handles)[k++] = (iBase_EntityHandle)*iter;
// now it's safe to set the size; set it to k, not out_entities.size(), to
// account for sets which might have been removed
