[MOAB-dev] r3349 - MOAB/trunk/tools/iMesh
    kraftche at cae.wisc.edu
    Mon Nov 16 08:28:20 CST 2009
Author: kraftche
Date: 2009-11-16 08:28:20 -0600 (Mon, 16 Nov 2009)
New Revision: 3349
Modified:
   MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
patch from Jed Brown: convert ITAPS format option string to MOAB format for write_file call
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2009-11-16 14:27:49 UTC (rev 3348)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2009-11-16 14:28:20 UTC (rev 3349)
@@ -354,9 +354,10 @@
     eatwhitespace(tmp_filename);
     eatwhitespace(tmp_options);
+    std::string opts = ";"; opts += tmp_options;
     MBEntityHandle set = ENTITY_HANDLE(handle);
-    MBErrorCode result = MBI->write_file(tmp_filename.c_str(), NULL, tmp_options.c_str(),
+    MBErrorCode result = MBI->write_file(tmp_filename.c_str(), NULL, opts.c_str(),
                                          &set, 1);
     if (MB_SUCCESS != result) {
