[MOAB-dev] Error configuring MOAB
Robert Smith robert.smith109 at comcast.net
Fri Nov 13 17:10:05 CST 2009
I'm having trouble configuring MOAB for parallel support and giving it
locations of netcdf, hdf5, zlib and szip.
While checking for netcdf_c++ on configure line 27906 it fails the
conftest compile.  But it's really due to the libraries being listed
in the wrong order.
The build command is:
configure:27938: /homes/sharp/3rdparty/mpich2/mpich2-1.1.1p1/gcc/bin/
mpicxx -o conftest  -Wall -pipe -I/homes/sharp/3rdparty/netcdf/
netcdf-4.0.1/parallel/gcc/include  -DUNORDERED_MAP_NS=std::tr1 -
DHAVE_UNORDERED_MAP=tr1/unordered_map -L/homes/sharp/3rdparty/netcdf/
netcdf-4.0.1/parallel/gcc/lib   -L/homes/sharp/3rdparty/zlib/
zlib-1.2.3/gcc/lib -L/homes/sharp/3rdparty/szip/szip-2.1/gcc/lib  -L/
homes/sharp/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc/lib conftest.cpp -lm
-lnetcdf_c++ -lnetcdf -lhdf5_hl  -lsz -lz -lhdf5 >&5
but this will fail the compilation.
However if the -lhdf5 is moved before the -lsz and -lz but still after
the -lhdf5_hl it works.
The configure line is below.
Is this a bug?  If so I'll enter it.
./configure --prefix=/homes/sharp/libs/MOAB/beta/parallel/gcc_opt --
with-mpi=/homes/sharp/3rdparty/mpich2/mpich2-1.1.1p1/gcc/bin --with-
netcdf=/homes/sharp/3rdparty/netcdf/netcdf-4.0.1/parallel/gcc --with-
hdf5=/homes/sharp/3rdparty/hdf5/hdf5-1.8.3/parallel/gcc --with-zlib=/
homes/sharp/3rdparty/zlib/zlib-1.2.3/gcc --with-szip=/homes/sharp/
3rdparty/szip/szip-2.1/gcc --disable-debug --enable-production
--Bob
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20091113/38a2cdc5/attachment.htm>
