[MOAB-dev] r3341 - MOAB/trunk
kraftche at cae.wisc.edu
Thu Nov 12 16:24:50 CST 2009
Author: kraftche
Date: 2009-11-12 16:24:50 -0600 (Thu, 12 Nov 2009)
New Revision: 3341
Modified:
MOAB/trunk/MBTest.cpp
Log:
add test for correct behavior for read of either invalid or non-existant files
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp 2009-11-12 22:24:21 UTC (rev 3340)
+++ MOAB/trunk/MBTest.cpp 2009-11-12 22:24:50 UTC (rev 3341)
@@ -6784,6 +6784,34 @@
return MB_SUCCESS;
+// It is a common problem for readers to incorrectly
+// handle invalid/unknown file types and non-existant
+// files. For either case, MOAB will try all readers
+// (assuming it doesn't recongnize the file extension),
+// so we can test all the readers w/out knowing which
+// readers we have.
+const char* argv0 = 0;
+MBErrorCode mb_read_fail_test(MBInterface* mb)
+ MBEntityHandle set;
+ MBErrorCode rval;
+ // try reading a non-existant file
+ rval = mb->load_file( tmpnam(0), set );
+ if (MB_FILE_DOES_NOT_EXIST != rval)
+ return MB_FAILURE;
+ // try reading an invalid file
+ if (!argv0) // not set by main, oops!
+ rval = mb->load_file( argv0, set );
+ if (MB_SUCCESS == rval)
+ return MB_SUCCESS;
int number_tests = 0;
int number_tests_failed = 0;
#define RUN_TEST( A ) _run_test( (A), #A )
@@ -6841,6 +6869,7 @@
int main(int argc, char* argv[])
+ argv0 = argv[0];
// Check command line arg to see if we should avoid doing the stress test
bool stress_test = true;
@@ -6915,6 +6944,7 @@
RUN_TEST( mb_skin_surface_adj_test );
RUN_TEST( mb_skin_volume_test );
RUN_TEST( mb_skin_volume_adj_test );
+ RUN_TEST( mb_read_fail_test );
RUN_TEST( mb_merge_update_test );
RUN_TEST( mb_merge_test );
if (stress_test) RUN_TEST( mb_stress_test );
