[MOAB-dev] r3339 - MOAB/trunk
    kraftche at cae.wisc.edu
    Thu Nov 12 16:02:52 CST 2009
Author: kraftche
Date: 2009-11-12 16:02:52 -0600 (Thu, 12 Nov 2009)
New Revision: 3339
Modified:
   MOAB/trunk/ReadABAQUS.cpp
Log:
return failure (rather than success w/ no entities) if input file does not exist, and change all error reporting to a) go to MOAB's error reporting rather than std::err and b) to print the offending line number rather thn echoing the entire line
Modified: MOAB/trunk/ReadABAQUS.cpp
--- MOAB/trunk/ReadABAQUS.cpp	2009-11-12 22:01:46 UTC (rev 3338)
+++ MOAB/trunk/ReadABAQUS.cpp	2009-11-12 22:02:52 UTC (rev 3339)
@@ -141,7 +141,10 @@
   MBErrorCode status;
   // open file
+  lineNo = 0;
   abFile.open(abaqus_file_name);
+  if (!abFile)
+    return MB_FILE_DOES_NOT_EXIST;
   bool in_unsupported = false;
@@ -182,14 +185,12 @@
 	case abq_data_line:
 	  if (!in_unsupported)
-	      std::cerr << "Internal Error: found ABAQUS data line outside a keyword block."
-			<< std::endl << readline << std::endl;
+	      report_error( "Expected Keyword" );
 	      return MB_FAILURE;
 	  break;
 	default:
-	  std::cerr << "Internal Error: found unrecognized ABAQUS line."
+          report_error( "Invalid/unreconginzed line" );
 	  return MB_FAILURE;
       next_line_type = get_next_line_type();
@@ -505,8 +506,7 @@
 		  if (tokens.size() != 3)
-		      std::cerr << "Wrong number of entries on INSTANCE translation line:"
+                      report_error( "Wrong number of entries on INSTANCE translation line" );
 		      return MB_FAILURE;
@@ -520,8 +520,7 @@
 		    if (tokens.size() != 7)
-			std::cerr << "Wrong number of entries on INSTANCE rotation line:"
+			report_error( "Wrong number of entries on INSTANCE rotation line" );
 			return MB_FAILURE;
 		    for (unsigned int i=0;i<7;i++)
@@ -531,17 +530,17 @@
 		else
-		    std::cerr << "Too many data lines for this INSTANCE: " << instance_name << std::endl;
+		    report_error( "Too many data lines for this INSTANCE" );
 		    return MB_FAILURE;
 	  break;
 	case abq_blank_line:
-	  std::cerr << "Error: Blank lines are not allowed." << std::endl;
+	  report_error( "Error: Blank lines are not allowed." );
 	  return MB_FAILURE;
 	default:
-	  std::cerr << "Error reading INSTANCE " << instance_name << std::endl;
+	  report_error( "Error reading INSTANCE " );
 	  return MB_FAILURE;
@@ -594,7 +593,7 @@
 	  // std::cout << "Adding PART with name: " << part_name << std::endl; // REMOVE
 	  break;
 	default:
-	  std::cerr << "Missing required PART parameter " << (*thisParam).first << std::endl;
+	  report_error( "Missing required PART parameter" );
 	  return MB_FAILURE;
@@ -670,17 +669,16 @@
 	case abq_data_line:
-	      std::cerr << "Internal Error: Data lines not allowed in PART keyword."
+	      report_error ("Data lines not allowed in PART keyword.");
 	      return MB_FAILURE;
 	  break;
+	  report_error( "Blank lines are not allowed." );
 	  return MB_FAILURE;
 	default:
-	  std::cerr << "Error reading PART " << part_name << std::endl;
+	  report_error( "Error reading PART." );
 	  return MB_FAILURE;
@@ -730,7 +728,7 @@
 	  params.erase(param_key);
 	  break;
 	default:
-	  std::cerr << "Missing required SOLID SECTION parameter " << (*thisParam).first << std::endl;
+	  report_error( "Missing required SOLID SECTION parameter." );
 	  return MB_FAILURE;
@@ -820,7 +818,7 @@
 	  // std::cout << "\tAdding ELSET with name: " << elset_name << std::endl; // REMOVE
 	  break;
 	default:
-	  std::cerr << "Missing required ELSET parameter " << (*thisParam).first << std::endl;
+	  report_error( "Missing required ELSET parameter." );
 	  return MB_FAILURE;
@@ -869,8 +867,7 @@
-		  std::cerr << "Wrong number (" << tokens.size() << ") of entries on GENERATE element set data line:"
+		  report_error( "Wrong number of entries on GENERATE element set data line ");
 		  return MB_FAILURE;
 	      int e1 = atoi(tokens[0].c_str());
@@ -878,8 +875,7 @@
 	      int incr = atoi(tokens[2].c_str());
 	      if ( ( (e2-e1)%incr ) != 0)
-		  std::cerr << "Invalid data on GENERATE element set data line:"
+		  report_error( "Invalid data on GENERATE element set data line:" );
 		  return MB_FAILURE;
 	      for (int element_id=e1; element_id<=e2;element_id+=incr)
@@ -983,7 +979,7 @@
 	  // std::cout << "\tAdding NSET with name: " << nset_name << std::endl; // REMOVE
 	  break;
 	default:
-	  std::cerr << "Missing required NSET parameter " << (*thisParam).first << std::endl;
+	  report_error( "Missing required NSET parameter" );
 	  return MB_FAILURE;
@@ -1022,7 +1018,7 @@
   if (make_from_elset && generate_nset)
-      std::cerr << "Incompatible NSET parameters ELSET & GENERATE " << std::endl;
+      report_error( "Incompatible NSET parameters ELSET & GENERATE" );
       return MB_FAILURE;
@@ -1048,8 +1044,7 @@
-		      std::cerr << "Wrong number of entries on GENERATE node set data line:"
+		      report_error( "Wrong number of entries on GENERATE node set data line" );
 		      return MB_FAILURE;
 		  int n1 = atoi(tokens[0].c_str());
@@ -1057,8 +1052,7 @@
 		  if ( ( (n2-n1) % incr ) != 0)
-		      std::cerr << "Invalid data on GENERATE node set data line:"
+		      report_error( "Invalid data on GENERATE node set data line" );
 		      return MB_FAILURE;
 		  for (int node_id=n1; node_id<=n2;node_id+=incr)
@@ -1177,16 +1171,14 @@
 	  element_type = elementTypes[ params[param_key]];
 	  if (abq_eletype_unsupported == element_type)
-	      std::cerr << "MOAB doesn't currently support this element type: "
-			<< (*thisParam).second << std::endl;
+	      report_error( "MOAB doesn't currently support this element type" );
 	      return MB_FAILURE;
 	  // std::cout << "\tAdding ELEMENTS of type: " << params[param_key] << std::endl; // REMOVE
 	  break;
 	case abq_element_undefined:
-	  std::cerr << "Missing required ELEMENT parameter " << (*thisParam).first << std::endl
-		    << readline << std::endl;
+	  report_error( "Missing required ELEMENT parameter" );
 	  return MB_FAILURE;
 	default:
 	  break;
@@ -1229,8 +1221,7 @@
 	  tokenize(readline,tokens,", \n");
 	  if (tokens.size() < nodes_per_element[element_type]+1)
-	      std::cerr << "Not enough data on node data line:"
+	      report_error( "Not enough data on node data line" );
 	      return MB_FAILURE;
 	  element_ids.push_back(atoi(tokens[0].c_str()));
@@ -1374,8 +1365,7 @@
 	  if (tokens.size() < 4)
 	      return MB_FAILURE;
 	  node_ids.push_back(atoi(tokens[0].c_str()));
@@ -1532,7 +1522,7 @@
 						 tag_data, 1, sets);
   if (MB_SUCCESS != status)
-      std::cerr << "Did not find any sets of that type" << std::endl;
+      report_error( "Did not find any sets of that type" );
       return status;
@@ -1550,8 +1540,7 @@
   if (0 == set_handle)
-      std::cerr << "Did not find requested set: " << set_name
-		<< std::endl;
+      report_error( "Did not find requested set" );
       return MB_FAILURE;
@@ -1936,7 +1925,7 @@
       status = add_entity_set(instance_set,ABQ_ELEMENT_SET,element_set_name,instance_element_set);
       MB_RETURN_IF_FAIL;
-      std::cerr << instance_set << "\t" << instance_element_set << std::endl;
+      //std::cerr << instance_set << "\t" << instance_element_set << std::endl;
       status = mdbImpl->add_entities(instance_element_set,instance_element_set_list);
       MB_RETURN_IF_FAIL;
@@ -2058,6 +2047,7 @@
   readline.clear();
   std::getline(abFile,readline);
+  ++lineNo;
   if (abFile.eof())
     return abq_eof;
@@ -2219,3 +2209,7 @@
+void ReadABAQUS::report_error( const char* message )
+  readMeshIface->report_error( "Error at line %d: %s\n", lineNo, message );
