[MOAB-dev] r3301 - MOAB/trunk
Jason Kraftcheck kraftche at cae.wisc.edu
Fri Nov 6 20:51:22 CST 2009
kraftche at cae.wisc.edu wrote:
> Author: kraftche
> Date: 2009-11-06 20:05:35 -0600 (Fri, 06 Nov 2009)
> New Revision: 3301
> Modified:
>    MOAB/trunk/MBCore.cpp
> Log:
> More refactoring of get_adjacencies code:
>  o split common template code into separate union and intersect versions
>  o combine vector->vector with other cases for intersect
>  o copy blocked optimziation from specialized vertex case to general
>     union case
> Reduces skin time for 100x100x100 hex mesh form 7.88s to 5.01s
I meant 7.01s, not 5.01.
- jason
