[MOAB-dev] r3303 - MOAB/trunk/tools/iMesh
kraftche at cae.wisc.edu
Fri Nov 6 20:44:41 CST 2009
Author: kraftche
Date: 2009-11-06 20:44:41 -0600 (Fri, 06 Nov 2009)
New Revision: 3303
Modified:
MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
MOAB/trunk/tools/iMesh/testc_cbind.c
Log:
add test case from Jim demonstrating but in adjacencey query for iBase_ALL_TYPEs, and fix bug
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2009-11-07 02:33:00 UTC (rev 3302)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2009-11-07 02:44:41 UTC (rev 3303)
@@ -716,7 +716,7 @@
for (int dim = 0; dim < 4; ++dim) {
if (MBCN::Dimension(TYPE_FROM_HANDLE(*entity_iter)) == dim)
continue;
- result = MBI->get_adjacencies( entity_iter, 1, dim, false, adj_ents );
+ result = MBI->get_adjacencies( entity_iter, 1, dim, false, adj_ents, MBInterface::UNION );
if (MB_SUCCESS != result) {
iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getEntArrAdj: trouble getting adjacency list.");
RETURN(iBase_ERROR_MAP[result]);
Modified: MOAB/trunk/tools/iMesh/testc_cbind.c
--- MOAB/trunk/tools/iMesh/testc_cbind.c 2009-11-07 02:33:00 UTC (rev 3302)
+++ MOAB/trunk/tools/iMesh/testc_cbind.c 2009-11-07 02:44:41 UTC (rev 3303)
@@ -2098,6 +2098,54 @@
return 1;
+int all_adjacency_regression( iMesh_Instance mesh )
+ int err;
+ double coords[] = { 0,0,0, 1,1,1 };
+ iBase_EntityHandle *verts = NULL;
+ int verts_alloc = 0,verts_size;
+ iBase_EntityHandle line;
+ int status;
+ iBase_EntityHandle *adj = NULL;
+ int adj_alloc = 0,adj_size;
+ iMesh_newMesh("",&mesh,&err,0);
+ if (iBase_SUCCESS != err) return 0;
+ iMesh_createVtxArr(mesh,2,iBase_INTERLEAVED,coords,6,&verts,&verts_alloc,
+ &verts_size,&err);
+ iMesh_createEnt(mesh,iMesh_LINE_SEGMENT,verts,2,&line,&status,&err);
+ if (iBase_SUCCESS != err || status != iBase_NEW) return 0;
+ iMesh_getEntAdj(mesh,verts[0],iBase_ALL_TYPES,&adj,&adj_alloc,&adj_size,
+ &err);
+ if(adj_size != 1 || adj[0] != line) {
+ printf("Bad: couldn't find adjacency for vertex\n");
+ return 0;
+ free(adj);
+ adj_alloc = adj = 0;
+ iMesh_getEntAdj(mesh,line,iBase_ALL_TYPES,&adj,&adj_alloc,&adj_size,
+ &err);
+ if(adj_size != 2 || ((adj[0] != verts[0] || adj[1] != verts[1]) &&
+ (adj[0] != verts[1] || adj[1] != verts[0])) ) {
+ printf("Bad: couldn't find adjacencies for line\n");
+ return 0;
+ free(adj);
+ return 1;
int main( int argc, char *argv[] )
/* Check command line arg */
@@ -2226,6 +2274,15 @@
number_tests++;
printf("\n");
+ /* regression test for adjacencies with iBase_ALL_TYPES bug */
+ printf(" all_adjacency_regression: ");
+ result = all_adjacency_regression(mesh);
+ handle_error_code(result, &number_tests_failed,
+ &number_tests_not_implemented,
+ &number_tests_successful);
+ number_tests++;
+ printf("\n");
/* summary */
printf("\nTSTT TEST SUMMARY: \n");
