[MOAB-dev] r3300 - MOAB/trunk
kraftche at cae.wisc.edu
Fri Nov 6 17:39:18 CST 2009
Author: kraftche
Date: 2009-11-06 17:39:17 -0600 (Fri, 06 Nov 2009)
New Revision: 3300
Modified:
MOAB/trunk/MBRange.cpp
MOAB/trunk/MBRange.hpp
Log:
add operator-(iter,iter) that counts distance between MBRange iterators
Modified: MOAB/trunk/MBRange.cpp
--- MOAB/trunk/MBRange.cpp 2009-11-06 22:29:04 UTC (rev 3299)
+++ MOAB/trunk/MBRange.cpp 2009-11-06 23:39:17 UTC (rev 3300)
@@ -233,11 +233,11 @@
MBRange::iterator MBRange::insert( MBRange::iterator hint, MBEntityHandle val )
- // if this is empty, just add it and return an iterator to it
+ // don't allow zero-valued handles in MBRange
if(val == 0)
return end();
+ // if this is empty, just add it and return an iterator to it
if(&mHead == mHead.mNext)
mHead.mNext = mHead.mPrev = alloc_pair(&mHead, &mHead, val, val);
@@ -733,6 +733,24 @@
+MBEntityID
+operator-( const MBRange::const_iterator& it2, const MBRange::const_iterator& it1 )
+ assert( !it2.mValue || *it2 >= *it1 );
+ if (it2.mNode == it1.mNode) {
+ return *it2 - *it1;
+ MBEntityID result = it1.mNode->second - it1.mValue + 1;
+ for (MBRange::PairNode* n = it1.mNode->mNext; n != it2.mNode; n = n->mNext)
+ result += n->second - n->first + 1;
+ if (it2.mValue) // (it2.mNode != &mHead)
+ result += it2.mValue - it2.mNode->first;
+ return result;
MBRange::const_iterator MBRange::lower_bound(MBRange::const_iterator first,
MBRange::const_iterator last,
MBEntityHandle val)
Modified: MOAB/trunk/MBRange.hpp
--- MOAB/trunk/MBRange.hpp 2009-11-06 22:29:04 UTC (rev 3299)
+++ MOAB/trunk/MBRange.hpp 2009-11-06 23:39:17 UTC (rev 3300)
@@ -420,6 +420,7 @@
friend class MBRange;
friend class pair_iterator;
friend class const_pair_iterator;
+ friend MBEntityID operator-( const const_iterator&, const const_iterator& );
public:
//! default constructor - intialize base default constructor
const_iterator() : mNode(NULL), mValue(0) {}
@@ -685,6 +686,9 @@
inline MBRange::const_iterator
operator-( MBEntityID step, const MBRange::const_iterator& it )
{ MBRange::const_iterator tmp(it); return tmp -= step; }
+MBEntityID
+operator-( const MBRange::const_iterator& it1, const MBRange::const_iterator& it2 );
//! Use as you would an STL back_inserter
