[MOAB-dev] r3299 - MOAB/trunk
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Fri Nov 6 16:29:05 CST 2009
Author: kraftche
Date: 2009-11-06 16:29:04 -0600 (Fri, 06 Nov 2009)
New Revision: 3299
Modified:
   MOAB/trunk/MBCore.cpp
Log:
o Fix very broken vector-vector get_connectivity:
  assumed that all entities in array had the same type as the first entity.
o Change vector-range get_connectivity such that it is worst-case
  O(n ln n) instead of O(n^2)
o Rewrite vector-vector get_adjacencies with specialized code instead
  of call to range-range get_adjacencies
o Templatize implementation of range-range get_adjacencies such that
  it can be shared by range-range get_adjacencies and vetor-range
  get_adjacencies w/out converting the input list.
o Fix bug in some forms of get_adjancies when input list contains
  only one entity and target type is vertex: still need to handle
  INTERSECT/UNION flag if 'output' container is not empty.
o Fix inconsistent behavior for different versions and special
  cases of get_adjacencies: all should return input entities if
  asked for adjacent entities of the same dimension (not returning
  such entities would be more consistent with iMesh, but that broke
  other code in MOAB.)
Time required to skin a mesh using vertex->element adjacencies
was reduced from 9.32 seconds to 7.88 seconds with these changes.
Passes all tests.
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp	2009-11-06 22:19:42 UTC (rev 3298)
+++ MOAB/trunk/MBCore.cpp	2009-11-06 22:29:04 UTC (rev 3299)
@@ -946,7 +946,8 @@
                                         topological_connectivity);
   if (MB_SUCCESS != result) return result;
-  std::copy(tmp_connect.begin(), tmp_connect.end(), mb_range_inserter(connectivity));
+  std::sort( tmp_connect.begin(), tmp_connect.end() );
+  std::copy(tmp_connect.rbegin(), tmp_connect.rend(), mb_range_inserter(connectivity));
   return result;
@@ -956,55 +957,21 @@
                                       std::vector<MBEntityHandle> &connectivity,
                                       bool topological_connectivity) const
-  if (num_handles == 0) return MB_FAILURE;
+  connectivity.clear(); // this seems wrong as compared to other API functions,
+                        // but changing it breaks lost of code, so I'm leaving
+                        // it in.  - j.kraftcheck 2009-11-06
-    // Make sure the entity should have a connectivity.
-  MBEntityType type = TYPE_FROM_HANDLE(entity_handles[0]);
-  int i;
-  connectivity.clear();
-  // handle the special case where someone asks for the connectivity
-  // of a vertex.  This actually kind of makes sense for a sphere element.
-  if (type == MBVERTEX)
-    connectivity.reserve(num_handles);
-    std::copy(entity_handles, entity_handles+num_handles,
-              std::back_inserter(connectivity));
-    return MB_SUCCESS;
+  MBErrorCode rval;
+  std::vector<MBEntityHandle> tmp_storage; // used only for structured mesh
+  const MBEntityHandle* conn;
+  int len;
+  for (int i = 0; i < num_handles; ++i) {
+    rval = get_connectivity( entity_handles[i], conn, len, topological_connectivity, &tmp_storage );
+    if (MB_SUCCESS != rval)
+      return rval;
+    connectivity.insert( connectivity.end(), conn, conn + len );
-    // WARNING: This is very dependent on the ordering of the MBEntityType enum
-  if(type <= MBVERTEX || type >= MBENTITYSET)
-    return MB_TYPE_OUT_OF_RANGE;
-  MBErrorCode result = MB_SUCCESS, temp_result;
-  for (i = 0; i < num_handles; i++) {
-    const EntitySequence* seq = 0;
-      // We know that connectivity is stored in an EntitySequence so jump straight
-      // to the entity sequence
-    temp_result = sequence_manager()->find(entity_handles[i], seq);
-    if (seq == NULL) {
-      result = MB_ENTITY_NOT_FOUND;
-      continue;
-    else if (temp_result != MB_SUCCESS) {
-      result = temp_result;
-      continue;
-    const ElementSequence *elem_seq = static_cast<const ElementSequence*>(seq);
-      // let's be smart about this...
-    temp_result = elem_seq->get_connectivity(entity_handles[i], connectivity,
-                                             topological_connectivity);
-    if (MB_SUCCESS != temp_result) {
-      continue;
-  return result;
+  return MB_SUCCESS;
 //! get the connectivity for element handles.  For non-element handles, return an error
@@ -1079,59 +1046,162 @@
   return status;
-MBErrorCode MBCore::get_adjacencies(const MBEntityHandle *from_entities,
-                                      const int num_entities,
-                                      const int to_dimension,
-                                      const bool create_if_missing,
-                                      std::vector<MBEntityHandle> &adj_entities,
-                                      const int operation_type)
+MBErrorCode MBCore::get_adjacencies( const MBEntityHandle *from_entities,
+                                     const int num_entities,
+                                     const int to_dimension,
+                                     const bool create_if_missing,
+                                     std::vector<MBEntityHandle> &adj_entities,
+                                     const int operation_type )
   MBErrorCode result;
-  if (num_entities == 1) {
+  if (num_entities == 1 && adj_entities.empty()) {
     if(to_dimension == 0 && TYPE_FROM_HANDLE(from_entities[0]) != MBPOLYHEDRON)
       result = get_connectivity(&from_entities[0], 1, adj_entities);
     else
       result = aEntityFactory->get_adjacencies(from_entities[0], to_dimension,
-                                               create_if_missing, adj_entities);
-    std::vector<MBEntityHandle>::iterator iter =
-      std::remove(adj_entities.begin(), adj_entities.end(), MBEntityHandle(0));
-    if(iter != adj_entities.end())
-      adj_entities.erase(iter, adj_entities.end());
+                                             create_if_missing, adj_entities);
+    //adj_entities.erase( std::remove( adj_entities.begin(), adj_entities.end(), 0 ), adj_entities.end() );
     return result;
-  MBRange temp_range, temp_range2;
-  std::copy(from_entities, from_entities+num_entities,
-            mb_range_inserter(temp_range));
+  if (operation_type == MBInterface::UNION) {
+    int len;
+    for (int i = 0; i < num_entities; ++i) {
+      if(to_dimension == 0 && TYPE_FROM_HANDLE(from_entities[0]) != MBPOLYHEDRON) {
+        result = get_connectivity(from_entities[i], conn, len, false, &tmp_storage);
+        adj_entities.insert( adj_entities.end(), conn, conn+len );
+        if (MB_SUCCESS != result)
+          return result;
+      else {
+        result = aEntityFactory->get_adjacencies(from_entities[i], to_dimension,
+          return result;
+    std::sort( adj_entities.begin(), adj_entities.end() );
+    adj_entities.erase( std::unique( adj_entities.begin(), adj_entities.end() ), adj_entities.end() );
-  result = get_adjacencies(temp_range, to_dimension, create_if_missing, temp_range2,
-                           operation_type);
-  if (MB_SUCCESS != result)
-    return result;
-  adj_entities.clear();
-  adj_entities.reserve(temp_range2.size());
-  for (MBRange::const_iterator it = temp_range2.begin();
-       it != temp_range2.end();
-       ++it)
-    adj_entities.push_back(*it);
+  std::vector<MBEntityHandle> tmp_adj;
+    tmp_adj.clear();
+    if(to_dimension == 0 && TYPE_FROM_HANDLE(from_entities[i]) != MBPOLYHEDRON)
+      result = get_connectivity(&from_entities[i], 1, tmp_adj);
+    else
+                                               create_if_missing, tmp_adj);
+      return result;
+    if (tmp_adj.empty()) {
+      adj_entities.clear();
+    else if (i == 0 && adj_entities.empty())
+      adj_entities.swap(tmp_adj);
+    else {
+      std::sort( tmp_adj.begin(), tmp_adj.end() );
+      std::vector<MBEntityHandle>::iterator it, w;
+      for( it = w = adj_entities.begin(); it != adj_entities.end(); ++it ) {
+        if (std::binary_search( tmp_adj.begin(), tmp_adj.end(), *it ))
+          { *w = *it; ++w; }
+      adj_entities.erase( w, adj_entities.end() );
   return MB_SUCCESS;
-                                      MBRange &adj_entities,
+template <typename ITER> static inline
+MBErrorCode get_adjacencies_common( MBCore* mb,
+                             ITER begin, ITER end,
+                             MBRange &adj_entities,
-  MBRange tmp_from_entities;
-  std::copy(from_entities, from_entities+num_entities, mb_range_inserter(tmp_from_entities));
-  return get_adjacencies(tmp_from_entities, to_dimension, create_if_missing,
-                         adj_entities, operation_type);
+  MBRange temp_range;
+  std::vector<MBEntityHandle> temp_vec;
+  std::vector<MBEntityHandle>::const_iterator adj_it;
+  MBErrorCode result = MB_SUCCESS, tmp_result;
+  for (ITER from_it = begin; from_it != end; from_it++)
+      // running results kept in adj_entities; clear temp_vec and temp_range, which are working space
+    temp_vec.clear();
+    temp_range.clear();
+      // get the next set of adjacencies
+    MBEntityType type = TYPE_FROM_HANDLE(*from_it);
+    if (to_dimension == MBCN::Dimension(type))
+      { temp_vec.push_back(*from_it); tmp_result = MB_SUCCESS; }
+    else if(to_dimension == 0 && type != MBPOLYHEDRON)
+      tmp_result = mb->get_connectivity(&(*from_it), 1, temp_vec);
+    else
+      tmp_result = mb->a_entity_factory()->get_adjacencies(*from_it, to_dimension,
+                                                   create_if_missing, temp_vec);
+    if (MB_SUCCESS != tmp_result) result = tmp_result;
+    std::sort( temp_vec.begin(), temp_vec.end() );
+      // if we're on the first iteration and we didn't come in with entities,
+      // just get the first results and move on
+    if (adj_entities.empty() && from_it == begin) {
+      std::copy(temp_vec.rbegin(), temp_vec.rend(), mb_range_inserter(adj_entities));
+      continue;
+      // operate on the vectors
+    MBRange::iterator hint = adj_entities.begin();
+    if (operation_type == MBInterface::INTERSECT) {
+      adj_it = temp_vec.begin();
+      while (hint != adj_entities.end()) {
+        while (adj_it != temp_vec.end() && *adj_it < *hint)
+          ++adj_it;
+        if (adj_it == temp_vec.end()) {
+          adj_entities.erase( hint, adj_entities.end() );
+          break;
+        if (*adj_it == *hint)
+          ++hint;
+        else
+          hint = adj_entities.erase(hint);
+        // If doing INTERSECT and the current results are the empty set,
+        // then the final result must also be the empty set.
+      if (adj_entities.empty())
+    else if (operation_type == MBInterface::UNION) {
+      for (adj_it = temp_vec.begin(); adj_it != temp_vec.end(); ++adj_it)
+        hint = adj_entities.insert( hint, *adj_it );
+  return result;
+  return get_adjacencies_common( this, from_entities, from_entities + num_entities,
+                          to_dimension, create_if_missing, adj_entities, operation_type );
 MBErrorCode MBCore::get_vertices( const MBRange& from_entities,
                                   MBRange& adj_entities )
@@ -1214,68 +1284,11 @@
     return get_vertices( from_entities, adj_entities );
-  MBRange temp_range;
-  std::vector<MBEntityHandle> temp_vec;
-  std::vector<MBEntityHandle>::const_iterator adj_it;
-  MBErrorCode result = MB_SUCCESS, tmp_result;
+  return get_adjacencies_common( this, from_entities.begin(), from_entities.end(),
-  for (MBRange::const_iterator from_it = from_entities.begin();
-       from_it != from_entities.end(); from_it++)
-      // running results kept in adj_entities; clear temp_vec and temp_range, which are working space
-    temp_vec.clear();
-    temp_range.clear();
-      // get the next set of adjacencies
-    if(to_dimension == 0 && TYPE_FROM_HANDLE(*from_it) != MBPOLYHEDRON)
-      tmp_result = get_connectivity(&(*from_it), 1, temp_vec);
-    else
-      tmp_result = aEntityFactory->get_adjacencies(*from_it, to_dimension,
-                                                   create_if_missing, temp_vec);
-    if (MB_SUCCESS != tmp_result) result = tmp_result;
-    std::sort( temp_vec.begin(), temp_vec.end() );
-      // if we're on the first iteration and we didn't come in with entities,
-      // just get the first results and move on
-    if (adj_entities.empty() && from_it == from_entities.begin()) {
-      std::copy(temp_vec.rbegin(), temp_vec.rend(), mb_range_inserter(adj_entities));
-      continue;
-      // operate on the vectors
-    MBRange::iterator hint = adj_entities.begin();
-    if (operation_type == MBInterface::INTERSECT) {
-      adj_it = temp_vec.begin();
-      while (hint != adj_entities.end()) {
-        while (adj_it != temp_vec.end() && *adj_it < *hint)
-          ++adj_it;
-        if (adj_it == temp_vec.end()) {
-          adj_entities.erase( hint, adj_entities.end() );
-          break;
-        if (*adj_it == *hint)
-          ++hint;
-        else
-          hint = adj_entities.erase(hint);
-        // If doing INTERSECT and the current results are the empty set,
-        // then the final result must also be the empty set.
-      if (adj_entities.empty())
-    else if (operation_type == MBInterface::UNION) {
-      for (adj_it = temp_vec.begin(); adj_it != temp_vec.end(); ++adj_it)
-        hint = adj_entities.insert( hint, *adj_it );
-  return result;
 MBErrorCode MBCore::add_adjacencies(const MBEntityHandle entity_handle,
                                     const MBEntityHandle *adjacencies,
                                     const int num_handles,
