[MOAB-dev] r3296 - MOAB/trunk/parallel
    tautges at mcs.anl.gov
    Fri Nov  6 12:37:20 CST 2009
Author: tautges
Date: 2009-11-06 12:37:19 -0600 (Fri, 06 Nov 2009)
New Revision: 3296
Added:
   MOAB/trunk/parallel/pcomm_serial.cpp
Modified:
   MOAB/trunk/parallel/MBParallelComm.cpp
   MOAB/trunk/parallel/Makefile.am
   MOAB/trunk/parallel/pcomm_unit.cpp
Log:
Couple of improvements and bug fixes to parallel ghost exchange code.
- add debug-only code to check for duplicate procs in proc list for entities
- add a little MPE stuff, commented out
- in build_shared_hps list, terminate list of procs/handles
- in a couple places, print error and return failure instead of asserting
- couple of improvements to print_buffer to make it more informative
- adding a pcomm_serial test, which does the equivalent of ghost exchange but
  completely in serial
Passes make check, except for iMeshP tests.
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp	2009-11-06 18:15:33 UTC (rev 3295)
+++ MOAB/trunk/parallel/MBParallelComm.cpp	2009-11-06 18:37:19 UTC (rev 3296)
@@ -47,14 +47,19 @@
 const int MAX_BCAST_SIZE = (1<<28);
 #undef DEBUG_MPE
+//#define DEBUG_MPE 1
 #ifdef DEBUG_MPE
 #include "mpe.h"
 int IFACE_START, IFACE_END;
 int GHOST_START, GHOST_END;
 int SHAREDV_START, SHAREDV_END;
 int RESOLVE_START, RESOLVE_END;
+int ENTITIES_START, ENTITIES_END;
+int RHANDLES_START, RHANDLES_END;
 #endif
 #undef DEBUG_COMM
+//#define DEBUG_COMM 1
 #undef DEBUG_PACKING
 #undef DEBUG_MSGS
 #ifdef DEBUG_PACKING
@@ -488,6 +493,7 @@
                         buff_size-INITIAL_BUFF_SIZE,
                         MPI_UNSIGNED_CHAR, to_proc,
                         mesg_tag+1, procConfig.proc_comm(), &send_req2);
+      // put this inside so we can stop on completion in the debugger
     if (success != MPI_SUCCESS) return MB_FAILURE;
@@ -867,6 +873,15 @@
       PACK_INT(buff_ptr, num_ents);
       PACK_INTS(buff_ptr, tmp_procs, num_ents);
       PACK_EH(buff_ptr, tmp_handles, num_ents);
+#ifndef NDEBUG
+        // check for duplicates in proc list
+      unsigned int dp = 0;
+      for (; dp < MAX_SHARING_PROCS && -1 != tmp_procs[dp]; dp++)
+        dumprocs.insert(tmp_procs[dp]);
+      assert(dumprocs.size() == dp);
+      dumprocs.clear();
+#endif
@@ -1015,6 +1030,12 @@
     num_ents++;
+    // put -1 after procs and 0 after handles
+  if (MAX_SHARING_PROCS > num_ents) {
+    tmp_procs[num_ents] = -1;
+    tmp_handles[num_ents] = 0;
   return MB_SUCCESS;
@@ -1311,7 +1332,11 @@
       // save place where remote handle info starts, then scan forward to ents
     for (i = 0; i < num_ents; i++) {
       UNPACK_INT(buff_ptr, j);
-      assert(j >= 0 && "Should be non-negative # proc/handles.");
+      if (j < 0) {
+        std::cout << "Should be non-negative # proc/handles.";
+        return MB_FAILURE;
       buff_ptr += j * (sizeof(int)+sizeof(MBEntityHandle));
@@ -1354,7 +1379,11 @@
       if (store_remote_handles) {
           // pointers to other procs/handles
         UNPACK_INT(buff_save, num_ps);
-        assert("Shouldn't ever be fewer than 1 procs here." && 0 < num_ps);
+        if (0 >= num_ps) {
+          std::cout << "Shouldn't ever be fewer than 1 procs here." << std::endl;
         UNPACK_INTS(buff_save, &ps[0], num_ps);
         UNPACK_EH(buff_save, &hs[0], num_ps);
@@ -1440,7 +1469,7 @@
                                     (is_iface ? PSTATUS_INTERFACE :
                                      (created_here ? (PSTATUS_GHOST | PSTATUS_NOT_OWNED) : 0)));
         RRA("");
           // need to send this new handle to all sharing procs
         if (!is_iface) {
           for (j = 0; j < num_ps; j++) {
@@ -1506,7 +1535,8 @@
   return MB_SUCCESS;
-MBErrorCode MBParallelComm::print_buffer(unsigned char *buff_ptr, int mesg_tag,
+MBErrorCode MBParallelComm::print_buffer(unsigned char *buff_ptr,
+                                         int mesg_tag,
                                          int from_proc, bool sent)
   std::cout << procConfig.proc_rank();
@@ -1515,10 +1545,12 @@
   std::cout << " message type " << mesg_tag
             << " to/from proc " << from_proc << "; contents:" << std::endl;
+  int msg_length;
+  unsigned char *orig_ptr = buff_ptr;
+  UNPACK_INT(buff_ptr, msg_length);
+  std::cout << msg_length << " bytes..." << std::endl;
   if (MB_MESG_ENTS == mesg_tag) {
-    int total_size;
-    UNPACK_INT(buff_ptr, total_size);
-    std::cout << total_size << " entities..." << std::endl;
       // 1. # entities = E
     int num_ents;
@@ -1532,9 +1564,10 @@
+      if (0 > j) return MB_FAILURE;
       ps.resize(j);
       hs.resize(j);
-      std::cout << "Entity " << i << ": # procs = " << j << std::endl;
+      std::cout << "Entity " << i << ", # procs = " << j << std::endl;
       UNPACK_INTS(buff_ptr, &ps[0], j);
       UNPACK_EH(buff_ptr, &hs[0], j);
       std::cout << "   Procs: ";
@@ -1543,12 +1576,17 @@
       std::cout << "   Handles: ";
       for (k = 0; k < j; k++) std::cout << hs[k] << " ";
       std::cout << std::endl;
+      if (buff_ptr-orig_ptr > msg_length) {
+        std::cout << "End of buffer..." << std::endl;
-  while (true) {
-    MBEntityType this_type = MBMAXTYPE;
-    UNPACK_TYPE(buff_ptr, this_type);
-    assert(this_type != MBENTITYSET);
+    while (true) {
+      MBEntityType this_type = MBMAXTYPE;
+      UNPACK_TYPE(buff_ptr, this_type);
+      assert(this_type != MBENTITYSET);
         // MBMAXTYPE signifies end of entities data
       if (MBMAXTYPE == this_type) break;
@@ -1587,11 +1625,19 @@
           for (k = 0; k < verts_per_entity; k++) std::cout << connect[k] << " ";
   else if (MB_MESG_REMOTE_HANDLES) {
+    int num_bytes;
+    UNPACK_INT(buff_ptr, num_bytes);
+    std::cout << num_bytes << " bytes..." << std::endl;
     int num_ents;
     UNPACK_INT(buff_ptr, num_ents);
     std::vector<MBEntityHandle> L1hloc(num_ents), L1hrem(num_ents);
@@ -1606,6 +1652,12 @@
                 << MBCN::EntityTypeName(etype) << ID_FROM_HANDLE(L1hloc[i])  << ", "
                 << L1p[i] << std::endl;
   else if (MB_MESG_TAGS) {
     assert(false);
@@ -1705,6 +1757,17 @@
   MBErrorCode result = get_sharing_data(new_h, tag_ps, tag_hs, pstat, num_exist);
   RRA("");
+#ifndef NDEBUG
+    std::set<unsigned int> dumprocs;
+    for (; (int) dp < num_ps && -1 != ps[dp]; dp++)
+      dumprocs.insert(ps[dp]);
+    assert(dp == dumprocs.size());
+#endif
     // add any new sharing data
   bool changed = false;
   int idx;
@@ -1811,10 +1874,21 @@
     result = mbImpl->tag_set_data(sharedhs_tag(), &new_h, 1, tag_hs);
     RRA("Couldn't set sharedhs tag.");
     pstat |= (PSTATUS_MULTISHARED | PSTATUS_SHARED);
+#ifndef NDEBUG
+      for (; dp < num_exist && -1 != tag_ps[dp]; dp++)
+        dumprocs.insert(tag_ps[dp]);
+#endif
   else if (num_exist == 2 || num_exist == 1) {
     if (tag_ps[0] == (int) procConfig.proc_rank()) {
-      assert(2 == num_exist);
+      assert(2 == num_exist && tag_ps[1] != (int) procConfig.proc_rank());
       tag_ps[0] = tag_ps[1];
       tag_hs[0] = tag_hs[1];
@@ -2930,10 +3004,14 @@
   MPE_Log_get_state_eventIDs( &GHOST_START, &GHOST_END);
   MPE_Log_get_state_eventIDs( &SHAREDV_START, &SHAREDV_END);
   MPE_Log_get_state_eventIDs( &RESOLVE_START, &RESOLVE_END);
+  MPE_Log_get_state_eventIDs( &ENTITIES_START, &ENTITIES_END);
+  MPE_Log_get_state_eventIDs( &RHANDLES_START, &RHANDLES_END);
   success = MPE_Describe_state(IFACE_START, IFACE_END, "Resolve interface ents", "green");
   success = MPE_Describe_state(GHOST_START, GHOST_END, "Exchange ghost ents", "red");
   success = MPE_Describe_state(SHAREDV_START, SHAREDV_END, "Resolve interface vertices", "blue");
   success = MPE_Describe_state(RESOLVE_START, RESOLVE_END, "Resolve shared ents", "purple");
+  success = MPE_Describe_state(ENTITIES_START, ENTITIES_END, "Exchange shared ents", "yellow");
+  success = MPE_Describe_state(RHANDLES_START, RHANDLES_END, "Remote handles", "cyan");
 #endif
@@ -3708,6 +3786,9 @@
     // post ghost irecv's for ghost entities from all communicating procs
+#ifdef DEBUG_MPE
+    MPE_Log_event(ENTITIES_START, procConfig.proc_rank(), "Starting entity exchange.");
+#endif
     // index reqs the same as buffer/sharing procs indices
   std::vector<MPI_Request> recv_reqs(buffProcs.size(), MPI_REQUEST_NULL);
   std::vector<unsigned int>::iterator proc_it;
@@ -3763,6 +3844,9 @@
                          buff_ptr-&ownerSBuffs[ind][0], MB_MESG_ENTS,
                          sendReqs[ind], sendReqs[ind+buffProcs.size()]);
     RRA("Failed to Isend in ghost exchange.");
+//    if (1 == num_layers)
+//      print_buffer(&ownerSBuffs[ind][0], MB_MESG_ENTS, *proc_it, true);
@@ -3794,7 +3878,7 @@
       if (MPI_SUCCESS != success) this_count = -1;
       std::cerr << "Received from " << status[0].MPI_SOURCE
-                << ": count = " << this_count << ", tag = " << status[0].MPI_TAG;
+                << ", count = " << this_count << ", tag = " << status[0].MPI_TAG;
       if (MB_MESG_ENTS+1 == status[0].MPI_TAG) std::cerr << " (second)";
       std::cerr << std::endl;
@@ -3810,14 +3894,18 @@
     RRA("Failed to receive entities.");
     if (done) {
-      unsigned char *buff_ptr = &ghostRBuffs[ind][sizeof(int)];
 #ifdef DEBUG_MSGS
-      print_buffer(buff_ptr-sizeof(int), MB_MESG_ENTS, buffProcs[ind], false);
+      print_buffer(&ghostRBuffs[ind][0], MB_MESG_ENTS, buffProcs[ind], false);
 #endif
+      unsigned char *buff_ptr = &ghostRBuffs[ind][sizeof(int)];
       result = unpack_entities(buff_ptr,
                                store_remote_handles, ind, is_iface,
                                L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, new_ents);
-      RRA("Failed to unpack entities.");
+      if (MB_SUCCESS != result) {
+        std::cout << "Failed to unpack entities.  Buffer contents:" << std::endl;
+        return result;
       if (recv_reqs.size() != buffProcs.size()) {
         recv_reqs.resize(buffProcs.size(), MPI_REQUEST_NULL);
@@ -3834,6 +3922,10 @@
+#ifdef DEBUG_MPE
+    MPE_Log_event(ENTITIES_END, procConfig.proc_rank(), "Ending entity exchange.");
+#endif
   if (is_iface) {
       // need to check over entities I sent and make sure I received
       // handles for them from all expected procs; if not, need to clean
@@ -3879,6 +3971,9 @@
     // post recvs for remote handles of my sent ents
+#ifdef DEBUG_MPE
+    MPE_Log_event(RHANDLES_START, procConfig.proc_rank(), "Starting remote handles.");
+#endif
   for (ind = 0, proc_it = buffProcs.begin();
        proc_it != buffProcs.end(); proc_it++, ind++) {
       // skip if iface layer and lower-rank proc
@@ -3941,7 +4036,7 @@
       if (MB_MESG_REMOTE_HANDLES_SECOND == status[0].MPI_TAG)
@@ -3954,10 +4049,10 @@
     RRA("Failed to resize recv buffer.");
     if (done) {
         // incoming remote handles
-      buff_ptr = &ghostRBuffs[ind][sizeof(int)];
 #ifdef DEBUG_MSGS
-      print_buffer(buff_ptr, MB_MESG_REMOTE_HANDLES, buffProcs[ind], false);
+      print_buffer(&ghostRBuffs[ind][0], MB_MESG_REMOTE_HANDLES, buffProcs[ind], false);
 #endif
+      buff_ptr = &ghostRBuffs[ind][sizeof(int)];
       result = unpack_remote_handles(buffProcs[ind], buff_ptr,
                                      L2hloc, L2hrem, L2p);
       RRA("Failed to unpack remote handles.");
@@ -3969,6 +4064,9 @@
 #ifdef DEBUG_MPE
+    MPE_Log_event(RHANDLES_END, procConfig.proc_rank(), "Ending remote handles.");
+#endif
+#ifdef DEBUG_MPE
       MPE_Log_event(GHOST_END, procConfig.proc_rank(),
                     "Ending ghost exchange (still doing checks).");
 #endif
@@ -4417,7 +4515,7 @@
       if (dum_h) hpair[0] = dum_h;
       else hpair[0] = 0;
-    assert(hpair[0] && hpair[1]);
+    if (!(hpair[0] && hpair[1])) return MB_FAILURE;
     int this_proc = from_proc;
     result = update_remote_data(hpair[0], &this_proc, hpair+1, 1, 0);
     RRA("Trouble setting remote data range on sent entities in ghost exchange.");
@@ -5709,7 +5807,8 @@
   if (!bad_ents.empty()) {
-    std::cout << "Found bad entities in check_local_shared:" << std::endl;
+    std::cout << "Found bad entities in check_local_shared, proc rank "
+              << procConfig.proc_rank() << "," << std::endl;
     std::vector<std::string>::iterator vit;
     for (rit = bad_ents.begin(), vit = errors.begin(); rit != bad_ents.end(); rit++, vit++) {
       list_entities(&(*rit), 1);
Modified: MOAB/trunk/parallel/Makefile.am
--- MOAB/trunk/parallel/Makefile.am	2009-11-06 18:15:33 UTC (rev 3295)
+++ MOAB/trunk/parallel/Makefile.am	2009-11-06 18:37:19 UTC (rev 3296)
@@ -46,7 +46,7 @@
      ReadParallel.hpp \
      crystal.h errmem.h types.h
-  MOAB_PARALLEL_TEST += pcomm_unit parallel_unit_tests uber_parallel_test scdtest
+  MOAB_PARALLEL_TEST += pcomm_unit parallel_unit_tests uber_parallel_test scdtest pcomm_serial
 if PARALLEL_HDF5
 #  libMOABpar_la_LIBADD = $(top_builddir)/mhdf/libmhdf.la
@@ -88,6 +88,8 @@
 parallel_write_test_LDADD = ../libMOAB.la
 uber_parallel_test_SOURCES = uber_parallel_test.cpp
 uber_parallel_test_LDADD = ../libMOAB.la
+pcomm_serial_SOURCES = pcomm_serial.cpp
+pcomm_serial_LDADD = ../libMOAB.la
 scdtest_SOURCES = scdtest.cpp
 scdtest_LDADD = ../libMOAB.la
Added: MOAB/trunk/parallel/pcomm_serial.cpp
--- MOAB/trunk/parallel/pcomm_serial.cpp	                        (rev 0)
+++ MOAB/trunk/parallel/pcomm_serial.cpp	2009-11-06 18:37:19 UTC (rev 3296)
@@ -0,0 +1,91 @@
+#include "MBParallelComm.hpp"
+#include "MBParallelConventions.h"
+#include "MBTagConventions.hpp"
+#include "MBCore.hpp"
+#include "FileOptions.hpp"
+#include "ReadParallel.hpp"
+#include "TestUtil.hpp"
+#include <vector>
+int main( int argc, char* argv[] )
+#ifdef USE_MPI
+  MPI_Init( &argc, &argv );
+#endif
+  if (1 < argc && !strcmp(argv[1], "-h")) {
+    std::cout << "Usage: " << argv[0] << " nprocs filename" << std::endl;
+    return 0;
+  int nprocs = 2;
+  std::string ptag_name("GEOM_DIMENSION");
+  std::vector<int> partition_tag_vals;
+#ifdef SRCDIR
+  const char *fnames[] = {STRINGIFY(SRCDIR) "/ptest.cub"};
+#else
+  const char *fnames[] = {"./ptest.cub"};
+#endif
+  if (argc > 1)
+    nprocs = atoi(argv[1]);
+  if (argc > 2)
+    fnames[0] = argv[2];
+  if (argc > 3) {
+    ptag_name = argv[3];
+    if (argc > 4) partition_tag_vals.push_back(atoi(argv[4]));
+  else partition_tag_vals.push_back(3);
+  MBErrorCode rval;
+  MBCore *moab = new MBCore[nprocs]();
+  std::vector<MBParallelComm *> pc(nprocs);
+  for (int i = 0; i < nprocs; i++) {
+    pc[i] = new MBParallelComm(&moab[i]);
+    pc[i]->set_rank(i);
+    pc[i]->set_size(nprocs);
+  std::vector<int> pa_vec;
+  pa_vec.push_back(ReadParallel::PA_READ);
+  pa_vec.push_back(ReadParallel::PA_GET_FILESET_ENTS);
+  pa_vec.push_back(ReadParallel::PA_DELETE_NONLOCAL);
+  bool partition_distrib = false;
+  partition_distrib = true;
+    //std::string ptag_name("MATERIAL_SET");
+    //partition_distrib = true;
+  FileOptions fopts(NULL);
+    ReadParallel rp(moab+i, pc[i]);
+    MBEntityHandle tmp_set = 0;
+    rval = rp.load_file(fnames, 1, tmp_set, ReadParallel::POPT_READ_DELETE,
+                        ptag_name,
+                        partition_tag_vals, partition_distrib, false, pa_vec,
+                        fopts, NULL, 0, NULL, i, false, -1, -1, -1, -1, 0);
+    CHECK_ERR(rval);
+  rval = MBParallelComm::resolve_shared_ents(&pc[0], nprocs, 3);
+  CHECK_ERR(rval);
+    // exchange interface cells
+  rval = MBParallelComm::exchange_ghost_cells(&pc[0], nprocs, -1, -1, 0, true);
+  CHECK_ERR(rval);
+    // now 1 layer of hex ghosts
+  rval = MBParallelComm::exchange_ghost_cells(&pc[0], nprocs, 3, 0, 1, true);
+  CHECK_ERR(rval);
+    delete pc[i];
+  delete [] moab;
+#ifdef USE_MPI
+  MPI_Finalize();
+#endif
+  return 0;
Modified: MOAB/trunk/parallel/pcomm_unit.cpp
--- MOAB/trunk/parallel/pcomm_unit.cpp	2009-11-06 18:15:33 UTC (rev 3295)
+++ MOAB/trunk/parallel/pcomm_unit.cpp	2009-11-06 18:37:19 UTC (rev 3296)
@@ -48,8 +48,6 @@
 void test_pack_shared_entities_2d();
 /** Test pack/unpack of shared entities in 3d*/
 void test_pack_shared_entities_3d();
-/** Test pack/unpack of arbitrary mesh file */
-void test_pack_shared_arbitrary();
 /** Test filter_pstatus function*/
 void test_filter_pstatus();
@@ -76,7 +74,6 @@
   num_err += RUN_TEST( test_pack_tag_handle_data );
   num_err += RUN_TEST( test_pack_shared_entities_2d );
   num_err += RUN_TEST( test_pack_shared_entities_3d );
-  num_err += RUN_TEST( test_pack_shared_arbitrary );
   num_err += RUN_TEST( test_filter_pstatus );
 #ifdef USE_MPI
@@ -1865,65 +1862,6 @@
     delete pc[i];
-#define NP 3
-  MBCore moab[NP];
-  MBParallelComm *pc[NP];
-  for (unsigned int i = 0; i < NP; i++) {
-    pc[i] = new MBParallelComm(&moab[i]);
-    pc[i]->set_rank(i);
-    pc[i]->set_size(NP);
-  std::vector<int> pa_vec;
-  pa_vec.push_back(ReadParallel::PA_READ);
-  pa_vec.push_back(ReadParallel::PA_GET_FILESET_ENTS);
-  pa_vec.push_back(ReadParallel::PA_DELETE_NONLOCAL);
-  MBErrorCode rval;
-  std::vector<int> partition_tag_vals;
-  bool partition_distrib = false;
-#ifdef SRCDIR
-  const char *fnames[] = {STRINGIFY(SRCDIR) "/ptest.cub"};
-#else
-  const char *fnames[] = {"./ptest.cub"};
-#endif
-  std::string ptag_name("GEOM_DIMENSION");
-  partition_tag_vals.push_back(3);
-  partition_distrib = true;
-    //std::string ptag_name("MATERIAL_SET");
-    //partition_distrib = true;
-  FileOptions fopts(NULL);
-    ReadParallel rp(moab+i, pc[i]);
-    MBEntityHandle tmp_set = 0;
-    rval = rp.load_file(fnames, 1, tmp_set, ReadParallel::POPT_READ_DELETE,
-                        ptag_name,
-                        partition_tag_vals, partition_distrib, false, pa_vec,
-                        fopts, NULL, 0, NULL, i, false, -1, -1, -1, -1, 0);
-    CHECK_ERR(rval);
-  rval = MBParallelComm::resolve_shared_ents(pc, NP, 3);
-  CHECK_ERR(rval);
-    // exchange interface cells
-  rval = MBParallelComm::exchange_ghost_cells(pc, NP, -1, -1, 0, true);
-  CHECK_ERR(rval);
-    // now 1 layer of hex ghosts
-  rval = MBParallelComm::exchange_ghost_cells(pc, NP, 3, 0, 1, true);
-  CHECK_ERR(rval);
-    delete pc[i];
   MBRange::iterator i;
