[MOAB-dev] MOAB check for *AMD64-32* failed.
    Nightly Test
    kraftche at cae.wisc.edu
    Fri Nov  6 03:06:10 CST 2009
make  check-recursive
make[1]: Entering directory `/home/jason/moab/test/AMD64-32'
Making check in mhdf
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/mhdf'
make[2]: Nothing to be done for `check'.
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/mhdf'
Making check in .
make[2]: Entering directory `/home/jason/moab/test/AMD64-32'
make  moab_test homxform_test scdseq_test tqdcfr test_adj seq_man_test geom_util_test xform_test obb_test vtk_test adaptive_kd_tree_tests bsp_tree_test file_options_test kd_tree_test var_len_test var_len_test_no_template tag_test mesh_set_test cub_file_test exodus_test gmsh_test stl_test mbcn_test bsp_tree_poly_test kd_tree_tool kd_tree_time
make[3]: Entering directory `/home/jason/moab/test/AMD64-32'
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g   -o moab_test MBTest.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o moab_test MBTest.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: `homxform_test' is up to date.
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g   -o scdseq_test scdseq_test.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o scdseq_test scdseq_test.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++ -DTEST_TQDCFR -Wall -pipe -g -Wall -pipe -g   -o tqdcfr tqdcfr-Tqdcfr.o ./libMOAB.la -lm
c++ -DTEST_TQDCFR -Wall -pipe -g -Wall -pipe -g -o tqdcfr tqdcfr-Tqdcfr.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: `test_adj' is up to date.
make[3]: `seq_man_test' is up to date.
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g   -o geom_util_test GeomUtilTests.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o geom_util_test GeomUtilTests.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++ -DTEST -Wall -pipe -g -Wall -pipe -g   -o xform_test xform_test-MBAffineXform.o ./libMOAB.la -lm
c++ -DTEST -Wall -pipe -g -Wall -pipe -g -o xform_test xform_test-MBAffineXform.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g   -o obb_test OBBTest.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o obb_test OBBTest.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g   -o vtk_test VtkTest.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o vtk_test VtkTest.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g   -o adaptive_kd_tree_tests adaptive_kd_tree_tests.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o adaptive_kd_tree_tests adaptive_kd_tree_tests.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g   -o bsp_tree_test bsp_tree_test.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o bsp_tree_test bsp_tree_test.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: `file_options_test' is up to date.
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g   -o kd_tree_test kd_tree_test.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o kd_tree_test kd_tree_test.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g   -o var_len_test VarLenTagTest.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o var_len_test VarLenTagTest.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -g   -o var_len_test_no_template var_len_test_no_template-VarLenTagTest.o ./libMOAB.la -lm
c++ -Wall -pipe -g -o var_len_test_no_template var_len_test_no_template-VarLenTagTest.o  ./.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I./parallel -I. -I../src/mhdf/include   -DVALGRIND -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map  -DSRCDIR=../src  -Wall -pipe -g -MT TagTest.o -MD -MP -MF .deps/TagTest.Tpo -c -o TagTest.o ../src/TagTest.cpp
../src/TagTest.cpp: In function âvoid test_get_ents_with_default_value()â:
../src/TagTest.cpp:1602: error: call of overloaded âcheck_equal(long unsigned int, MBEntityHandle, const char [16], const char [13], int, const char [19])â is ambiguous
../src/TestUtil.hpp:332: note: candidates are: void check_equal(int, int, const char*, const char*, int, const char*)
../src/TestUtil.hpp:335: note:                 void check_equal(unsigned int, unsigned int, const char*, const char*, int, const char*)
../src/TestUtil.hpp:338: note:                 void check_equal(long int, long int, const char*, const char*, int, const char*)
../src/TestUtil.hpp:341: note:                 void check_equal(long unsigned int, long unsigned int, const char*, const char*, int, const char*)
../src/TestUtil.hpp:344: note:                 void check_equal(void*, void*, const char*, const char*, int, const char*) <near match>
../src/TestUtil.hpp:347: note:                 void check_equal(const char*, const char*, const char*, const char*, int, const char*) <near match>
../src/TestUtil.hpp:350: note:                 void check_equal(const std::string&, const std::string&, const char*, const char*, int, const char*) <near match>
../src/TestUtil.hpp:384: note:                 void check_equal(MBErrorCode, MBErrorCode, const char*, const char*, int, const char*) <near match>
../src/TagTest.cpp:1665: error: call of overloaded âcheck_equal(size_t, MBEntityHandle, const char [10], const char [14], int, const char [19])â is ambiguous
make[3]: *** [TagTest.o] Error 1
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32'
make[2]: *** [check-am] Error 2
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32'
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/home/jason/moab/test/AMD64-32'
make: *** [check] Error 2
