[MOAB-dev] r3288 - MOAB/trunk
kraftche at cae.wisc.edu
Thu Nov 5 16:15:34 CST 2009
Author: kraftche
Date: 2009-11-05 16:15:34 -0600 (Thu, 05 Nov 2009)
New Revision: 3288
Modified:
MOAB/trunk/MBTest.cpp
Log:
add test that attempts to reproduce bug #28
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp 2009-11-05 20:46:54 UTC (rev 3287)
+++ MOAB/trunk/MBTest.cpp 2009-11-05 22:15:34 UTC (rev 3288)
@@ -891,7 +891,83 @@
return result;
+MBErrorCode mb_adjacencies_create_delete_test(MBInterface *mb)
+ MBCore moab;
+ mb = &moab;
+ MBErrorCode rval;
+ double coords[] = { 0, 0, 0, 2, 0, 0, 1, 2, 0 };
+ MBRange verts;
+ rval = mb->create_vertices( coords, 3, verts );
+ if (MB_SUCCESS != rval)
+ return rval;
+ if (verts.size() != 3)
+ return MB_FAILURE;
+ MBEntityHandle vert_arr[3];
+ MBEntityHandle tri;
+ std::copy( verts.begin(), verts.end(), vert_arr );
+ rval = mb->create_element( MBTRI, vert_arr, 3, tri );
+ return rval;
+ vert_arr[2] = vert_arr[0];
+ MBEntityHandle forward_edge, reverse_edge;
+ rval = mb->create_element( MBEDGE, vert_arr, 2, forward_edge );
+ return rval;
+ std::vector<MBEntityHandle> results;
+ rval = mb->get_adjacencies( &forward_edge, 1, 2, false, results );
+ if (results.size() != 1 || results.front() != tri) {
+ std::cerr << "Adjacency query from forward edge to tri failed at "
+ << __FILE__ << ":" << __LINE__ << std::endl;
+ results.clear();
+ rval = mb->get_adjacencies( &tri, 1, 1, false, results );
+ if (results.size() != 1 || results.front() != forward_edge) {
+ std::cerr << "Adjacency query from tri to forward edge failed at "
+ rval = mb->delete_entities( &forward_edge, 1 );
+ return rval;
+ results.clear();
+ if (!results.empty()) {
+ std::cerr << "Adjacency query from tri returned non-existent edge at "
+ rval = mb->create_element( MBEDGE, vert_arr+1, 2, reverse_edge );
+ return rval;
+ results.clear();
+ rval = mb->get_adjacencies( &reverse_edge, 1, 2, false, results );
+ std::cerr << "Adjacency query from reverse edge to tri failed at "
+ results.clear();
+ if (results.size() != 1 || results.front() != reverse_edge) {
+ std::cerr << "Adjacency query from tri to reverse edge failed at "
+ return MB_SUCCESS;
static MBErrorCode create_two_hex_full_mesh( MBInterface* mb,
MBEntityHandle vertices[12],
MBEntityHandle hexes[2],
@@ -6795,6 +6871,7 @@
RUN_TEST( mb_adjacent_vertex_test );
RUN_TEST( mb_adjacencies_test );
+ RUN_TEST( mb_adjacencies_create_delete_test );
RUN_TEST( mb_upward_adjacencies_test );
RUN_TEST( mb_vertex_coordinate_test );
RUN_TEST( mb_vertex_tag_test );
