[MOAB-dev] r3278 - MOAB/trunk/parallel
kraftche at cae.wisc.edu
Wed Nov 4 10:36:02 CST 2009
Author: kraftche
Date: 2009-11-04 10:36:02 -0600 (Wed, 04 Nov 2009)
New Revision: 3278
Modified:
MOAB/trunk/parallel/ReadParallel.cpp
Log:
don't fail if depricated PARTITION_DISTRIBUTE option is specified. fixes failing parallel tests
Modified: MOAB/trunk/parallel/ReadParallel.cpp
--- MOAB/trunk/parallel/ReadParallel.cpp 2009-11-04 16:23:04 UTC (rev 3277)
+++ MOAB/trunk/parallel/ReadParallel.cpp 2009-11-04 16:36:02 UTC (rev 3278)
@@ -85,6 +85,11 @@
distrib = true;
if (partition_tag_name.empty())
partition_tag_name = PARALLEL_PARTITION_TAG_NAME;
+ // also get depricated PARTITION_DISTRIBUTE option
+ // so that higher-level code doesn't return an error
+ // due to an unrecongized option
+ opts.get_null_option( "PARTITION_DISTRIBUTE" );
// Get partition tag value(s), if any, and whether they're to be
