[MOAB-dev] r3259 - in MOAB/trunk: . m4
kraftche at cae.wisc.edu
Mon Nov 2 16:11:06 CST 2009
Author: kraftche
Date: 2009-11-02 16:11:06 -0600 (Mon, 02 Nov 2009)
New Revision: 3259
Modified:
MOAB/trunk/configure.ac
MOAB/trunk/m4/acis.m4
MOAB/trunk/m4/boost.m4
MOAB/trunk/m4/compiler.m4
MOAB/trunk/m4/cplusplus.m4
MOAB/trunk/m4/hdf5.m4
MOAB/trunk/m4/makevar.m4
MOAB/trunk/m4/netcdf.m4
Log:
rename SNL_* macros to FATHOM_*
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac 2009-11-02 22:08:52 UTC (rev 3258)
+++ MOAB/trunk/configure.ac 2009-11-02 22:11:06 UTC (rev 3259)
@@ -46,7 +46,7 @@
EXTRA_GNU_FLAGS='-Wall -pipe'
-SNL_CHECK_COMPILERS([yes],[yes],[$CONFIGURE_FORTRAN])
+FATHOM_CHECK_COMPILERS([yes],[yes],[$CONFIGURE_FORTRAN])
AM_CONDITIONAL(PARALLEL,[test "x$WITH_MPI" != "xno"])
LIBS="-lm"
@@ -54,7 +54,7 @@
AC_PROG_MAKE_SET
AC_DISABLE_SHARED
AC_PROG_LIBTOOL
-SNL_COMPILER_FLAGS
+FATHOM_COMPILER_FLAGS
AC_CHECK_PROG([ZCAT],[gunzip],[gunzip -c],[])
AC_CHECK_PROG([ZCAT],[gzip],[gzip -cd],[])
@@ -65,8 +65,8 @@
AC_SUBST([ZCAT])
AM_CONDITIONAL([HAVE_ZCAT],[test "x" = "x$ZCAT"])
-SNL_TEMPLATE_SPECIALIZATION
-SNL_TEMPLATE_FUNC_SPECIALIZATION
+FATHOM_TEMPLATE_SPECIALIZATION
+FATHOM_TEMPLATE_FUNC_SPECIALIZATION
DEFINES="$DEFINES $TEMPLATE_SPECIALIZATION $TEMPLATE_FUNC_SPECIALIZATION"
if test "xno" != "x$CONFIGURE_FORTRAN"; then
@@ -151,7 +151,7 @@
# BOOST OPTIONS
-dnl SNL_CHECK_BOOST( [boost/pool/object_pool.hpp] )
+dnl FATHOM_CHECK_BOOST( [boost/pool/object_pool.hpp] )
MK_CHECK_UNORDERED_MAP([CPPFLAGS="$CPPFLAGS -DUNORDERED_MAP_NS=$result -DHAVE_UNORDERED_MAP=${incdir}unordered_map"])
@@ -300,7 +300,7 @@
# HDF5 OPTIONS
-SNL_CHECK_HDF5
+FATHOM_CHECK_HDF5
if test "xno" = "x$HAVE_HDF5"; then
AC_MSG_WARN([Support for native HDF5 file format disabled])
else
@@ -334,7 +334,7 @@
old_LDFLAGS="$LDFLAGS"
LDFLAGS="$LDFLAGS $HDF5_LDFLAGS"
-SNL_CHECK_NETCDF
+FATHOM_CHECK_NETCDF
LDFLAGS="$old_LDFLAGS"
if test "xno" = "x$HAVE_NETCDF"; then
AC_MSG_WARN([Support for ExodusII file format disabled])
@@ -750,7 +750,7 @@
dnl - The name of the variable to which to prepend the library link flag
dnl - List of extra libraries required for link test
dnl - Optional library path linker argument (e.g. -L/opt/foo)
- AC_DEFUN([SNL_CHECK_LIB_LIST],[
+ AC_DEFUN([FATHOM_CHECK_LIB_LIST],[
old_LIBS="$LIBS"
LIBS="$4 ${$2} $old_LIBS"
AC_HAVE_LIBRARY([$1],[$2="-l$1 ${$2}"],[],[$3])
@@ -759,40 +759,40 @@
# These are ordered such that a given library depends only on those libraries
# that preceed it in the list.
- SNL_CHECK_LIB_LIST([pthread],[vtk_sys_libs])
- SNL_CHECK_LIB_LIST([dl], [vtk_sys_libs])
- SNL_CHECK_LIB_LIST([m], [vtk_sys_libs])
- SNL_CHECK_LIB_LIST([gcc], [vtk_sys_libs])
+ FATHOM_CHECK_LIB_LIST([pthread],[vtk_sys_libs])
+ FATHOM_CHECK_LIB_LIST([dl], [vtk_sys_libs])
+ FATHOM_CHECK_LIB_LIST([m], [vtk_sys_libs])
+ FATHOM_CHECK_LIB_LIST([gcc], [vtk_sys_libs])
x_libs_arg="$X_EXTRA_LIBS -lX11 $X_PRE_LIBS"
- SNL_CHECK_LIB_LIST([Xext],[vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
- SNL_CHECK_LIB_LIST([ICE], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
- SNL_CHECK_LIB_LIST([SM], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
- SNL_CHECK_LIB_LIST([Xt], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
- SNL_CHECK_LIB_LIST([GL], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
- SNL_CHECK_LIB_LIST([GLU], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
+ FATHOM_CHECK_LIB_LIST([Xext],[vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
+ FATHOM_CHECK_LIB_LIST([ICE], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
+ FATHOM_CHECK_LIB_LIST([SM], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
+ FATHOM_CHECK_LIB_LIST([Xt], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
+ FATHOM_CHECK_LIB_LIST([GL], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
+ FATHOM_CHECK_LIB_LIST([GLU], [vtk_x_libs],[$x_libs_arg],[-L$x_libraries])
vtk_libs_arg="-L$x_libraries $vtk_x_libs $X_EXTRA_LIBS -lX11 $X_PRE_LIBS $vtk_sys_libs"
- SNL_CHECK_LIB_LIST([vtksys], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkCommon], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkDICOMParser],[vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkfreetype], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkexpat], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkzlib], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkpng], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkjpeg], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtktiff], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkftgl], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkFiltering], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkImaging], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([verdict], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkGraphics], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkNetCDF], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkexoIIc], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkmetaio], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkIO], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkRendering], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkParallel], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([vtkHybrid], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
- SNL_CHECK_LIB_LIST([QVTK], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtksys], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkCommon], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkDICOMParser],[vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkfreetype], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkexpat], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkzlib], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkpng], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkjpeg], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtktiff], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkftgl], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkFiltering], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkImaging], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([verdict], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkGraphics], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkNetCDF], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkexoIIc], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkmetaio], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkIO], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkRendering], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkParallel], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([vtkHybrid], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
+ FATHOM_CHECK_LIB_LIST([QVTK], [vtk_libs],[$vtk_libs_arg],[-L$VTK_LIB_DIR])
# Make sure we found at least vtkCommon and vtkRendering
if ! echo "x $vtk_libs" | grep lvtkCommon >/dev/null; then
@@ -879,7 +879,7 @@
dnl - name of output variable
dnl - first list
dnl - second list
- AC_DEFUN([SNL_MERGE_LISTS],[
+ AC_DEFUN([FATHOM_MERGE_LISTS],[
$1="$2"
# Reverse list two
for item3 in $3; do
@@ -891,8 +891,8 @@
done
$1="${$1} $2"
- SNL_MERGE_LISTS([XLIBS_tmp],[$X_EXTRA_LIBS -lX11 $X_PRE_LIBS],[$vtk_x_libs])
- SNL_MERGE_LISTS([XLIBS],[$vtk_sys_libs],[$XLIBS_tmp])
+ FATHOM_MERGE_LISTS([XLIBS_tmp],[$X_EXTRA_LIBS -lX11 $X_PRE_LIBS],[$vtk_x_libs])
+ FATHOM_MERGE_LISTS([XLIBS],[$vtk_sys_libs],[$XLIBS_tmp])
QVDUAL_LIBS="$LIBS $GRAPH_LIBS -L$VTK_LIB_DIR $vtk_libs $QT_LIBS $XLIBS"
QVDUAL_INCLUDES="$GRAPH_INC_DIR $VTK_INCLUDES $QT_INCLUDES"
AC_SUBST(VTK_LIB_DIR)
@@ -938,11 +938,11 @@
CGM_CONFIG_OPTIONS="include $CGM_MAKE"
AC_MSG_CHECKING([Checking for GeometryQueryTool::ray_fire(RefFace*,...)])
- SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_DEFINES], [CGM_CPPFLAGS="$make_val"])
- SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_INCLUDES],[CGM_CPPFLAGS="$CGM_CPPFLAGS $make_val"])
- SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_LTFLAGS], [CGM_LTFLAGS="$make_val"])
- SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_LDFLAGS], [CGM_LDFLAGS="$make_val"])
- SNL_MAKE_INC_VAR([$CGM_MAKE],[CGM_LIBS], [CGM_LIBS="$make_val"])
+ FATHOM_MAKE_INC_VAR([$CGM_MAKE],[CGM_DEFINES], [CGM_CPPFLAGS="$make_val"])
+ FATHOM_MAKE_INC_VAR([$CGM_MAKE],[CGM_INCLUDES],[CGM_CPPFLAGS="$CGM_CPPFLAGS $make_val"])
+ FATHOM_MAKE_INC_VAR([$CGM_MAKE],[CGM_LTFLAGS], [CGM_LTFLAGS="$make_val"])
+ FATHOM_MAKE_INC_VAR([$CGM_MAKE],[CGM_LDFLAGS], [CGM_LDFLAGS="$make_val"])
+ FATHOM_MAKE_INC_VAR([$CGM_MAKE],[CGM_LIBS], [CGM_LIBS="$make_val"])
AC_LANG_PUSH([C++])
old_CPPFLAGS="$CPPFLAGS"
Modified: MOAB/trunk/m4/acis.m4
--- MOAB/trunk/m4/acis.m4 2009-11-02 22:08:52 UTC (rev 3258)
+++ MOAB/trunk/m4/acis.m4 2009-11-02 22:11:06 UTC (rev 3259)
@@ -11,7 +11,7 @@
# If ACIS_VERSION is set, the corresponding test
# will be skipped.
-AC_DEFUN([SNL_ACIS_ENV], [
+AC_DEFUN([FATHOM_ACIS_ENV], [
AC_CHECK_FILE([$ACIS_DIR/include/acis.hxx], [], [AC_MSG_ERROR("Invalid ACIS path")])
@@ -28,7 +28,7 @@
if ! test "$ACIS_VERSION" -gt "600"; then
- SNL_ACIS_VERSION( [$dir] )
+ FATHOM_ACIS_VERSION( [$dir] )
ACIS_LIB_DIR="$dir"
fi
@@ -37,7 +37,7 @@
case "$dir" in
*_debug)
ACIS_DEBUG_LIB_DIR="$dir"
fi
@@ -92,8 +92,8 @@
# Macro to check for ACIS translators.
-AC_DEFUN([SNL_ACIS_TRANSLATOR], [
-AC_REQUIRE([SNL_ACIS_ENV])
+AC_DEFUN([FATHOM_ACIS_TRANSLATOR], [
+AC_REQUIRE([FATHOM_ACIS_ENV])
case "$ACIS_VERSION" in
11??)
ACIS_XLATE_LIBS='-lxacis2k -lxcore2k -lxutil'
@@ -126,7 +126,7 @@
# Macro to get ACIS_VERSION
# Expected arguments: ACIS library path
-AC_DEFUN([SNL_ACIS_VERSION], [
+AC_DEFUN([FATHOM_ACIS_VERSION], [
AC_REQUIRE([AC_PROG_LIBTOOL])
AC_LANG_SAVE
AC_LANG_CPLUSPLUS
@@ -134,7 +134,7 @@
src=conftest.cc
exe=conftest
-cat <<END_SNL_ACIS_VERSION_SRC >$src
+cat <<END_FATHOM_ACIS_VERSION_SRC >$src
#include <stdio.h>
int get_major_version();
int get_minor_version();
@@ -145,7 +145,7 @@
get_point_version());
return 0;}
-END_SNL_ACIS_VERSION_SRC
+END_FATHOM_ACIS_VERSION_SRC
FLAGS="$CXXFLAGS $LDFLAGS -L$1 -R$1"
if ./libtool --mode=link $CXX $FLAGS $src -lSpaBase -o $exe >/dev/null 2>/dev/null; then
@@ -158,4 +158,4 @@
#rm -f $src $exe
AC_LANG_RESTORE
-]) # SNL_ACIS_VERSION
+]) # FATHOM_ACIS_VERSION
Modified: MOAB/trunk/m4/boost.m4
--- MOAB/trunk/m4/boost.m4 2009-11-02 22:08:52 UTC (rev 3258)
+++ MOAB/trunk/m4/boost.m4 2009-11-02 22:11:06 UTC (rev 3259)
@@ -4,9 +4,9 @@
# Unless user specified --without-boost, will check for any passed headers.
# For any found headers, -DHAVE_[header] will be added to DEFINES
-AC_DEFUN([SNL_CHECK_BOOST],[
+AC_DEFUN([FATHOM_CHECK_BOOST],[
AC_MSG_CHECKING([if boost library is enabled])
-SNL_BOOST_OPT_HEADER_LIST="$1"
+FATHOM_BOOST_OPT_HEADER_LIST="$1"
AC_ARG_WITH(boost,
[AC_HELP_STRING([--with-boost=DIR], [Specify directory where boost is installed])
AC_HELP_STRING([--without-boost], [Disable support for boost libraries])],
@@ -24,7 +24,7 @@
fi
AC_LANG_SAVE
AC_LANG_CPLUSPLUS
- AC_CHECK_HEADERS( [$SNL_BOOST_OPT_HEADER_LIST],[def=`echo "$ac_header" | $as_tr_cpp`; DEFINES="$DEFINES -DHAVE_$def"] )
+ AC_CHECK_HEADERS( [$FATHOM_BOOST_OPT_HEADER_LIST],[def=`echo "$ac_header" | $as_tr_cpp`; DEFINES="$DEFINES -DHAVE_$def"] )
AC_LANG_RESTORE
fi
-]) # SNL_CHECK_BOOST
+]) # FATHOM_CHECK_BOOST
Modified: MOAB/trunk/m4/compiler.m4
--- MOAB/trunk/m4/compiler.m4 2009-11-02 22:08:52 UTC (rev 3258)
+++ MOAB/trunk/m4/compiler.m4 2009-11-02 22:11:06 UTC (rev 3259)
@@ -30,7 +30,7 @@
# - test for C++ compiler
# - test for Fortran compiler
-AC_DEFUN([SNL_CHECK_COMPILERS], [
+AC_DEFUN([FATHOM_CHECK_COMPILERS], [
CHECK_CC="$1"
CHECK_CXX="$2"
@@ -123,7 +123,7 @@
AC_PROG_F77( [$F77_LIST] )
fi
-]) # SNL_CHECK_COMPILERS
+]) # FATHOM_CHECK_COMPILERS
@@ -134,21 +134,21 @@
# CXXFLAGS - C++ compiler flags
-AC_DEFUN([SNL_COMPILER_FLAGS], [
+AC_DEFUN([FATHOM_COMPILER_FLAGS], [
if test "xno" != "x$CHECK_CC"; then
- SNL_CC_FLAGS
+ FATHOM_CC_FLAGS
fi
if test "xno" != "x$CHECK_CXX"; then
- SNL_CXX_FLAGS
+ FATHOM_CXX_FLAGS
fi
# Try to determine compiler-specific flags. This must be done
# before setting up libtool so that it can override libtool settings.
-CFLAGS="$USER_CFLAGS $SNL_CC_SPECIAL"
-CXXFLAGS="$USER_CXXFLAGS $SNL_CXX_SPECIAL"
+CFLAGS="$USER_CFLAGS $FATHOM_CC_SPECIAL"
+CXXFLAGS="$USER_CXXFLAGS $FATHOM_CXX_SPECIAL"
# On IBM/AIX, the check for OBJEXT fails for the mpcc compiler.
# (Comment out this hack, it should be fixed correctly now)
@@ -206,37 +206,37 @@
fi
# Check for 32/64 bit.
- # This requires SNL_CXX_FLAGS and SNL_CC_FLAGS to have been called first
+ # This requires FATHOM_CXX_FLAGS and FATHOM_CC_FLAGS to have been called first
AC_ARG_ENABLE( 32bit, AC_HELP_STRING([--enable-32bit],[Force 32-bit objects]),
if test "xyes" != "x$enableval"; then
AC_MSG_ERROR([Unknown argument --enable-32bit=$enableval])
- elif test "x" = "x$SNL_CXX_32BIT"; then
+ elif test "x" = "x$FATHOM_CXX_32BIT"; then
AC_MSG_ERROR([Don't know how to force 32-bit C++ on this platform. Try setting CXXFLAGS manually])
- elif test "x" = "x$SNL_CC_32BIT"; then
+ elif test "x" = "x$FATHOM_CC_32BIT"; then
AC_MSG_ERROR([Don't know how to force 32-bit C on this platform. Try setting CFLAGS manually])
fi
- CXXFLAGS="$CXXFLAGS $SNL_CXX_32BIT"
- CFLAGS="$CFLAGS $SNL_CC_32BIT"
+ CXXFLAGS="$CXXFLAGS $FATHOM_CXX_32BIT"
+ CFLAGS="$CFLAGS $FATHOM_CC_32BIT"
enable_32bit=yes
-# This requires SNL_CXX_FLAGS and SNL_CC_FLAGS to have been called first
+# This requires FATHOM_CXX_FLAGS and FATHOM_CC_FLAGS to have been called first
AC_ARG_ENABLE( 64bit, AC_HELP_STRING([--enable-64bit],[Force 64-bit objects]),
AC_MSG_ERROR([Unknown argument --enable-64bit=$enableval])
- elif test "x" = "x$SNL_CXX_64BIT"; then
+ elif test "x" = "x$FATHOM_CXX_64BIT"; then
AC_MSG_ERROR([Don't know how to force 64-bit C++ on this platform. Try setting CXXFLAGS manually])
- elif test "x" = "x$SNL_CC_64BIT"; then
+ elif test "x" = "x$FATHOM_CC_64BIT"; then
AC_MSG_ERROR([Don't know how to force 64-bit C on this platform. Try setting CFLAGS manually])
elif test "xyes" = "x$enable_32bit"; then
AC_MSG_ERROR([Cannot do both --enable-32bit and --enable-64bit])
fi
- CXXFLAGS="$CXXFLAGS $SNL_CXX_64BIT"
- CFLAGS="$CFLAGS $SNL_CC_64BIT"
+ CXXFLAGS="$CXXFLAGS $FATHOM_CXX_64BIT"
+ CFLAGS="$CFLAGS $FATHOM_CC_64BIT"
-]) # SNL_COMPILER_FLAGS
+]) # FATHOM_COMPILER_FLAGS
@@ -251,7 +251,7 @@
# - action upon success
# - action upon failure
-AC_DEFUN([SNL_TRY_COMPILER_DEFINE], [
+AC_DEFUN([FATHOM_TRY_COMPILER_DEFINE], [
AC_COMPILE_IFELSE([
AC_LANG_PROGRAM( [[#ifndef $1
choke me
@@ -263,11 +263,11 @@
# Check for compiler-specific flags.
# Sets the following environmental variables:
-# SNL_CXX_SPECIAL : Any compiler-specific flags which must be specified
-# SNL_CXX_32BIT : Flag to force compilation of 32-bit code
-# SNL_CXX_64BIT : Flag to force compilation of 64-bit code
+# FATHOM_CXX_SPECIAL : Any compiler-specific flags which must be specified
+# FATHOM_CXX_32BIT : Flag to force compilation of 32-bit code
+# FATHOM_CXX_64BIT : Flag to force compilation of 64-bit code
-AC_DEFUN([SNL_CXX_FLAGS], [
+AC_DEFUN([FATHOM_CXX_FLAGS], [
AC_LANG_PUSH([C++])
# Detect compiler
@@ -276,41 +276,41 @@
if test x$GXX = xyes; then
cxx_compiler=GNU
# Intel claims to be GCC, check for it here
- SNL_TRY_COMPILER_DEFINE([__INTEL_COMPILER],[cxx_compiler=Intel])
+ FATHOM_TRY_COMPILER_DEFINE([__INTEL_COMPILER],[cxx_compiler=Intel])
# Search for other compiler types
# For efficiency, limit checks to relevant OSs
else
cxx_compiler=unknown
case "$target_os" in
aix*)
- SNL_TRY_COMPILER_DEFINE([__IBMCPP__],[cxx_compiler=VisualAge])
+ FATHOM_TRY_COMPILER_DEFINE([__IBMCPP__],[cxx_compiler=VisualAge])
solaris*|sunos*)
- SNL_TRY_COMPILER_DEFINE([__SUNPRO_CC],[cxx_compiler=SunWorkshop])
+ FATHOM_TRY_COMPILER_DEFINE([__SUNPRO_CC],[cxx_compiler=SunWorkshop])
irix*)
- SNL_TRY_COMPILER_DEFINE([__sgi],[cxx_compiler=MIPSpro])
+ FATHOM_TRY_COMPILER_DEFINE([__sgi],[cxx_compiler=MIPSpro])
linux*)
- SNL_TRY_COMPILER_DEFINE([__DECCXX_VER],[cxx_compiler=Compaq])
- SNL_TRY_COMPILER_DEFINE([__PGI],[cxx_cmopiler=PortlandGroup])
+ FATHOM_TRY_COMPILER_DEFINE([__DECCXX_VER],[cxx_compiler=Compaq])
+ FATHOM_TRY_COMPILER_DEFINE([__PGI],[cxx_cmopiler=PortlandGroup])
hpux*)
- SNL_TRY_COMPILER_DEFINE([__HP_aCC],[cxx_compiler=HP])
+ FATHOM_TRY_COMPILER_DEFINE([__HP_aCC],[cxx_compiler=HP])
windows*)
- SNL_TRY_COMPILER_DEFINE([__MSC_VER],[cxx_compiler=VisualStudio])
- SNL_TRY_COMPILER_DEFINE([__BORLANDC__],[cxx_compiler=Borland])
- SNL_TRY_COMPILER_DEFINE([__CYGWIN__],[cxx_compiler=Cygwin])
- SNL_TRY_COMPILER_DEFINE([__MINGW32__],[cxx_compiler=MinGW])
+ FATHOM_TRY_COMPILER_DEFINE([__MSC_VER],[cxx_compiler=VisualStudio])
+ FATHOM_TRY_COMPILER_DEFINE([__BORLANDC__],[cxx_compiler=Borland])
+ FATHOM_TRY_COMPILER_DEFINE([__CYGWIN__],[cxx_compiler=Cygwin])
+ FATHOM_TRY_COMPILER_DEFINE([__MINGW32__],[cxx_compiler=MinGW])
- SNL_TRY_COMPILER_DEFINE([__PGI],[cc_cmopiler=PortlandGroup])
+ FATHOM_TRY_COMPILER_DEFINE([__PGI],[cc_cmopiler=PortlandGroup])
esac
fi
@@ -325,80 +325,80 @@
AC_MSG_CHECKING([for known compiler/OS combinations])
case "$cxx_compiler:$host_cpu" in
GNU:sparc*)
- SNL_CXX_32BIT=-m32
- SNL_CXX_64BIT=-m64
- SNL_CXX_SPECIAL="$EXTRA_GNU_FLAGS"
+ FATHOM_CXX_32BIT=-m32
+ FATHOM_CXX_64BIT=-m64
+ FATHOM_CXX_SPECIAL="$EXTRA_GNU_FLAGS"
GNU:powerpc*)
GNU:i?86|GNU:x86_64)
GNU:mips*)
- SNL_CXX_32BIT="-mips32 -mabi=32"
- SNL_CXX_64BIT="-mips64 -mabi=64"
+ FATHOM_CXX_32BIT="-mips32 -mabi=32"
+ FATHOM_CXX_64BIT="-mips64 -mabi=64"
GNU:*)
Intel:*)
- SNL_CXX_SPECIAL="$EXTRA_GNU_FLAGS -wd981 -wd383"
+ FATHOM_CXX_SPECIAL="$EXTRA_GNU_FLAGS -wd981 -wd383"
VisualAge:*)
- SNL_CXX_32BIT=-q32
- SNL_CXX_64BIT=-q64
+ FATHOM_CXX_32BIT=-q32
+ FATHOM_CXX_64BIT=-q64
# Do V5.0 namemangling for compatibility with ACIS, and enable RTTI
case "$target_vendor" in
bgp)
- SNL_CXX_SPECIAL=""
+ FATHOM_CXX_SPECIAL=""
AR="ar"
NM="nm -B"
- SNL_CXX_SPECIAL="-qrtti=all -qnamemangling=v5"
+ FATHOM_CXX_SPECIAL="-qrtti=all -qnamemangling=v5"
AR="ar"
NM="nm -B -X 32_64"
esac
MIPSpro:mips)
- SNL_CXX_32BIT=-n32
- SNL_CXX_64BIT=-64
- SNL_CXX_SPECIAL=-LANG:std
+ FATHOM_CXX_32BIT=-n32
+ FATHOM_CXX_64BIT=-64
+ FATHOM_CXX_SPECIAL=-LANG:std
MIPSpro:*)
SunWorkshop:sparc*)
- SNL_CXX_32BIT=-xarch=generic
- SNL_CXX_64BIT=-xarch=generic64
+ FATHOM_CXX_32BIT=-xarch=generic
+ FATHOM_CXX_64BIT=-xarch=generic64
SunWorkshop:i?86|SunWorkshop:x86_64)
esac
AC_MSG_RESULT([$cxx_compiler:$host_cpu])
-]) # end SNL_CXX_FLAGS
+]) # end FATHOM_CXX_FLAGS
-# SNL_CC_SPECIAL : Any compiler-specific flags which must be specified
-# SNL_CC_32BIT : Flag to force compilation of 32-bit code
-# SNL_CC_64BIT : Flag to force compilation of 64-bit code
+# FATHOM_CC_SPECIAL : Any compiler-specific flags which must be specified
+# FATHOM_CC_32BIT : Flag to force compilation of 32-bit code
+# FATHOM_CC_64BIT : Flag to force compilation of 64-bit code
-AC_DEFUN([SNL_CC_FLAGS], [
+AC_DEFUN([FATHOM_CC_FLAGS], [
AC_LANG_PUSH([C])
# Detect compiler
@@ -408,42 +408,42 @@
if test x$GCC = xyes; then
cc_compiler=GNU
- SNL_TRY_COMPILER_DEFINE([__INTEL_COMPILER],[cc_compiler=Intel])
+ FATHOM_TRY_COMPILER_DEFINE([__INTEL_COMPILER],[cc_compiler=Intel])
else
cc_compiler=unknown
aix*)
- SNL_TRY_COMPILER_DEFINE([__IBMC__],[cc_compiler=VisualAge])
+ FATHOM_TRY_COMPILER_DEFINE([__IBMC__],[cc_compiler=VisualAge])
solaris*|sunos*)
- SNL_TRY_COMPILER_DEFINE([__SUNPRO_C],[cc_compiler=SunWorkshop])
+ FATHOM_TRY_COMPILER_DEFINE([__SUNPRO_C],[cc_compiler=SunWorkshop])
irix*)
- SNL_TRY_COMPILER_DEFINE([__sgi],[cc_compiler=MIPSpro])
+ FATHOM_TRY_COMPILER_DEFINE([__sgi],[cc_compiler=MIPSpro])
linux*)
- SNL_TRY_COMPILER_DEFINE([__DECC_VER],[cc_compiler=Compaq])
+ FATHOM_TRY_COMPILER_DEFINE([__DECC_VER],[cc_compiler=Compaq])
hpux*)
- SNL_TRY_COMPILER_DEFINE([__HP_cc],[cc_compiler=HP])
+ FATHOM_TRY_COMPILER_DEFINE([__HP_cc],[cc_compiler=HP])
windows*)
- SNL_TRY_COMPILER_DEFINE([__MSC_VER],[cc_compiler=VisualStudio])
- SNL_TRY_COMPILER_DEFINE([__BORLANDC__],[cc_compiler=Borland])
- SNL_TRY_COMPILER_DEFINE([__TURBOC__],[cc_compiler=TurboC])
- SNL_TRY_COMPILER_DEFINE([__CYGWIN__],[cc_compiler=Cygwin])
- SNL_TRY_COMPILER_DEFINE([__MINGW32__],[cc_compiler=MinGW])
+ FATHOM_TRY_COMPILER_DEFINE([__MSC_VER],[cc_compiler=VisualStudio])
+ FATHOM_TRY_COMPILER_DEFINE([__BORLANDC__],[cc_compiler=Borland])
+ FATHOM_TRY_COMPILER_DEFINE([__TURBOC__],[cc_compiler=TurboC])
+ FATHOM_TRY_COMPILER_DEFINE([__CYGWIN__],[cc_compiler=Cygwin])
+ FATHOM_TRY_COMPILER_DEFINE([__MINGW32__],[cc_compiler=MinGW])
esac
fi
@@ -457,67 +457,67 @@
case "$cc_compiler:$host_cpu" in
GNU:sparc*)
- SNL_CC_32BIT=-m32
- SNL_CC_64BIT=-m64
- SNL_CC_SPECIAL="$EXTRA_GNU_FLAGS"
+ FATHOM_CC_32BIT=-m32
+ FATHOM_CC_64BIT=-m64
+ FATHOM_CC_SPECIAL="$EXTRA_GNU_FLAGS"
GNU:powerpc*)
- SNL_CC_32BIT=-m32
- SNL_CC_64BIT=-m64
- SNL_CC_32BIT=-m32
- SNL_CC_64BIT=-m64
Intel:*)
- SNL_CC_32BIT=-m32
- SNL_CC_64BIT=-m64
- SNL_CC_SPECIAL="$EXTRA_GNU_FLAGS -wd981 -wd383"
+ FATHOM_CC_SPECIAL="$EXTRA_GNU_FLAGS -wd981 -wd383"
GNU:mips*)
- SNL_CC_32BIT="-mips32 -mabi=32"
- SNL_CC_64BIT="-mips64 -mabi=64"
+ FATHOM_CC_32BIT="-mips32 -mabi=32"
+ FATHOM_CC_64BIT="-mips64 -mabi=64"
GNU:*)
VisualAge:*)
bgp)
- SNL_CC_32BIT=-q32
- SNL_CC_64BIT=-q64
+ FATHOM_CC_32BIT=-q32
+ FATHOM_CC_64BIT=-q64
AR="ar"
NM="nm -B"
- SNL_CC_32BIT=-q32
- SNL_CC_64BIT=-q64
AR="ar -X 32_64"
NM="nm -B -X 32_64"
esac
MIPSpro:mips)
- SNL_CC_32BIT=-n32
- SNL_CC_64BIT=-64
- SNL_CC_SPECIAL=-LANG:std
+ FATHOM_CC_32BIT=-n32
+ FATHOM_CC_64BIT=-64
+ FATHOM_CC_SPECIAL=-LANG:std
MIPSpro:*)
SunWorkshop:sparc*)
- SNL_CC_32BIT=-xarch=generic
- SNL_CC_64BIT=-xarch=generic64
+ FATHOM_CC_32BIT=-xarch=generic
+ FATHOM_CC_64BIT=-xarch=generic64
- SNL_CC_32BIT=-m32
- SNL_CC_64BIT=-m64
esac
AC_MSG_RESULT([$cc_compiler:$host_cpu])
-]) # end SNL_CC_FLAGS
+]) # end FATHOM_CC_FLAGS
Modified: MOAB/trunk/m4/cplusplus.m4
--- MOAB/trunk/m4/cplusplus.m4 2009-11-02 22:08:52 UTC (rev 3258)
+++ MOAB/trunk/m4/cplusplus.m4 2009-11-02 22:11:06 UTC (rev 3259)
@@ -44,7 +44,7 @@
# exist or do not define symbols to be in the "std" namespace.
# For example: if this is defined, #include <iostrea.h> rather than <iostream>
-AC_DEFUN([SNL_CANT_USE_STD], [
+AC_DEFUN([FATHOM_CANT_USE_STD], [
AC_CACHE_CHECK([for C++-standard library in std:: namespace],
[snl_cv_cxx_stl_in_std],
@@ -85,7 +85,7 @@
CANT_USE_STD_IO=
fi
-]) # SNL_CANT_USE_STD
+]) # FATHOM_CANT_USE_STD
@@ -95,7 +95,7 @@
# included (in the .hpp files).
# Sets TEMPLATE_DEFS_INCLUDED=-DTEMPLATE_DEFS_INCLUDED
-AC_DEFUN([SNL_TEMPLATE_DEFS_INCLUDED], [
+AC_DEFUN([FATHOM_TEMPLATE_DEFS_INCLUDED], [
AC_CACHE_CHECK([if C++ template definitions should be included],
[snl_cv_cxx_template_defs_included],
@@ -125,13 +125,13 @@
fi
-]) # SNL_TEMPLATE_DEFS_INCLUDED
+]) # FATHOM_TEMPLATE_DEFS_INCLUDED
# Check if compiler supports template class specialization.
# Sets TEMPLATE_SPECIALIZATION=-DTEMPLATE_SPECIALIZATION
-AC_DEFUN([SNL_TEMPLATE_SPECIALIZATION], [
+AC_DEFUN([FATHOM_TEMPLATE_SPECIALIZATION], [
AC_CACHE_CHECK([if C++ compiler supports template class specialization],
[snl_cv_template_specialization],
[AC_LANG_SAVE
@@ -148,13 +148,13 @@
fi
-]) # SNL_TEMPLATE_SPECIALIZATION
+]) # FATHOM_TEMPLATE_SPECIALIZATION
# Check if compiler supports template function specialization.
# Sets TEMPLATE_FUNC_SPECIALIZATION=-DTEMPLATE_FUNC_SPECIALIZATION
-AC_DEFUN([SNL_TEMPLATE_FUNC_SPECIALIZATION], [
+AC_DEFUN([FATHOM_TEMPLATE_FUNC_SPECIALIZATION], [
AC_CACHE_CHECK([if C++ compiler supports template function specialization],
[snl_cv_template_func_specialization],
[AC_LANG_SAVE
@@ -172,4 +172,4 @@
fi
-]) # SNL_TEMPLATE_FUNC_SPECIALIZATION
+]) # FATHOM_TEMPLATE_FUNC_SPECIALIZATION
Modified: MOAB/trunk/m4/hdf5.m4
--- MOAB/trunk/m4/hdf5.m4 2009-11-02 22:08:52 UTC (rev 3258)
+++ MOAB/trunk/m4/hdf5.m4 2009-11-02 22:11:06 UTC (rev 3259)
@@ -6,7 +6,7 @@
# HDF5_LDFLAGS
# HDF5_LIBS
-AC_DEFUN([SNL_CHECK_HDF5],[
+AC_DEFUN([FATHOM_CHECK_HDF5],[
# CLI option for linking zlib
AC_ARG_WITH(zlib,
@@ -184,4 +184,4 @@
fi
-]) # SNL_CHECK_HDF5
+]) # FATHOM_CHECK_HDF5
Modified: MOAB/trunk/m4/makevar.m4
--- MOAB/trunk/m4/makevar.m4 2009-11-02 22:08:52 UTC (rev 3258)
+++ MOAB/trunk/m4/makevar.m4 2009-11-02 22:11:06 UTC (rev 3259)
@@ -7,7 +7,7 @@
# of the variable)
# - Action on failure
-AC_DEFUN([SNL_MAKE_INC_VAR], [
+AC_DEFUN([FATHOM_MAKE_INC_VAR], [
make_val=
snl_makefile="snl_check.mak"
rm -f $snl_makefile
@@ -16,12 +16,12 @@
AC_MSG_WARN([File not found: $1])
$4
else
-cat >$snl_makefile <<SNL_END_OF_MAKEFILE
+cat >$snl_makefile <<FATHOM_END_OF_MAKEFILE
default:
@echo "\$($2)"
include $1
-SNL_END_OF_MAKEFILE
+FATHOM_END_OF_MAKEFILE
if make -f $snl_makefile > /dev/null 2>&1; then
make_val=`make -s -f $snl_makefile`
rm -f $snl_makefile
Modified: MOAB/trunk/m4/netcdf.m4
--- MOAB/trunk/m4/netcdf.m4 2009-11-02 22:08:52 UTC (rev 3258)
+++ MOAB/trunk/m4/netcdf.m4 2009-11-02 22:11:06 UTC (rev 3259)
@@ -6,7 +6,7 @@
# NETCDF_LDFLAGS
# NETCDF_LIBS
-AC_DEFUN([SNL_CHECK_NETCDF],[
+AC_DEFUN([FATHOM_CHECK_NETCDF],[
AC_MSG_CHECKING([if NetCDF support is enabled])
AC_ARG_WITH(netcdf,
@@ -110,4 +110,4 @@
fi
fi
-]) # SNL_HAVE_NETCDF
+]) # FATHOM_HAVE_NETCDF
