[MOAB-dev] r3255 - in MOAB/trunk: . m4 parallel refiner tools tools/iMesh tools/mbcoupler tools/mbzoltan
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Mon Nov 2 13:55:20 CST 2009
Author: kraftche
Date: 2009-11-02 13:55:16 -0600 (Mon, 02 Nov 2009)
New Revision: 3255
Added:
   MOAB/trunk/m4/mpi.m4
   MOAB/trunk/parallel/MBmpi.h
   MOAB/trunk/parallel/MBmpi_config.h.in
Modified:
   MOAB/trunk/MBCore.cpp
   MOAB/trunk/ReadHDF5.hpp
   MOAB/trunk/Tqdcfr.cpp
   MOAB/trunk/configure.ac
   MOAB/trunk/parallel/MBParallelComm.cpp
   MOAB/trunk/parallel/MBParallelComm.hpp
   MOAB/trunk/parallel/MBProcConfig.hpp
   MOAB/trunk/parallel/WriteHDF5Parallel.cpp
   MOAB/trunk/parallel/WriteHDF5Parallel.hpp
   MOAB/trunk/parallel/crystal.c
   MOAB/trunk/parallel/fcrystal.c
   MOAB/trunk/parallel/gs.c
   MOAB/trunk/parallel/mbparallelcomm_test.cpp
   MOAB/trunk/parallel/parallel_hdf5_test.cc
   MOAB/trunk/parallel/parallel_unit_tests.cpp
   MOAB/trunk/parallel/parallel_write_test.cc
   MOAB/trunk/parallel/pcomm_unit.cpp
   MOAB/trunk/parallel/transfer.c
   MOAB/trunk/parallel/uber_parallel_test.cpp
   MOAB/trunk/refiner/MBMeshRefiner.cpp
   MOAB/trunk/refiner/test_mesh_refiner.cpp
   MOAB/trunk/tools/Makefile.am
   MOAB/trunk/tools/convert.cpp
   MOAB/trunk/tools/iMesh/iMeshP.h
   MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
   MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp
   MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
   MOAB/trunk/tools/iMesh/partest.cpp
   MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
   MOAB/trunk/tools/mbzoltan/MBZoltan.hpp
Log:
o Move MPI configuration macros to a separate file
o Change all #includes of mpi.h to include MBmpi.h instead
o Put better configure logic about handling of conflicts between symbols
  in the MPI C++ API and the standard C IO headers into MBmpi.h:
    - If not C++, just include mpi.h
    - If it works, just include mpi.h
    - Otherwise define MPICH_CXX_IGNORE_SEEK, if that helps
    - Otherwise do old #undef games so that at least the C
        API is usable.
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/MBCore.cpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -47,7 +47,7 @@
  * because its C++ headers do not like SEEK_* macros.
 #include "MBParallelComm.hpp"
-#include "mpi.h"
+#include "MBmpi.h"
 #include "ReadParallel.hpp"
 #endif
Modified: MOAB/trunk/ReadHDF5.hpp
--- MOAB/trunk/ReadHDF5.hpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/ReadHDF5.hpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -25,6 +25,9 @@
 #include <stdlib.h>
 #include <list>
+#ifdef USE_MPI
+#  include "MBmpi.h"
+#endif
 #include "mhdf.h"
 #include "MBForward.hpp"
 #include "MBReadUtilIface.hpp"
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/Tqdcfr.cpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -26,7 +26,7 @@
 #include "exodus_order.h"
 #ifdef USE_MPI
-#include "mpi.h"
+#include "MBmpi.h"
 #endif
 #include <iostream>
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/configure.ac	2009-11-02 19:55:16 UTC (rev 3255)
@@ -158,42 +158,15 @@
 #                              MPI OPTIONS
-AC_ARG_VAR(MPIEXEC,[Program to use to run parallel tests (default: mpiexec or mpirun)])
-AC_ARG_VAR(MPIEXEC_NP,[Command line flag to specify number of processors to use (default: -np)])
-AC_ARG_VAR(NP,[Number of processors to on which to run parallel tests (default: 2)])
-if test "x$WITH_MPI" != "xno"; then
-  DEFINES="$DEFINES -DUSE_MPI"
-  AC_CHECK_HEADER([mpi.h],[],[AC_MSG_ERROR([mpi.h not found or not working])])
-  AC_MSG_CHECKING([If -DMPICH_IGNORE_CXX_SEEK is necessary])
-  AC_LANG_SAVE
-  AC_LANG_CPLUSPLUS
-  AC_PREPROC_IFELSE([AC_LANG_PROGRAM( [[#include <stdio.h>
-     #include <mpi.h>]],[])],
-    [AC_MSG_RESULT([no])],
-    [save_CPPFLAGS="$CPPFLAGS"
-     CPPFLAGS="$CPPFLAGS -DMPICH_IGNORE_CXX_SEEK"
-         [AC_MSG_RESULT([yes]); AM_CPPFLAGS="$AM_CPPLFLAGS -DMPICH_IGNORE_CXX_SEEK" ],
-         [AC_MSG_ERROR([mpi.h is not usable])]),
-     CPPFLAGS="$save_CPPFLAGS"])
-  AC_LANG_RESTORE
-  if test "x$MPIEXEC" = "x"; then
-    if test "x$WITH_MPI" != "xyes"; then
-      AC_CHECK_PROGS([MPIEXEC],[mpiexec mpirun],[true],[${WITH_MPI}:${WITH_MPI}/bin])
-    else
-      AC_CHECK_PROGS([MPIEXEC],[mpiexec mpirun],[true])
-    fi
-  fi
-  if test "x$MPIEXEC_NP" = "x"; then
-    MPIEXEC_NP="-np"
-  fi
-  if test "x$NP" = "x"; then
-    NP=2
-  fi
-fi
+FATHOM_CHECK_MPI
+FATHOM_CONFIG_MPI_EXEC
+test "xyes" != "x$WITH_MPI" || DEFINES="$DEFINES -DUSE_MPI"
 AM_CONDITIONAL(USE_MPI, [test "xno" != "x$WITH_MPI"])
-AM_CONDITIONAL(USE_MPIEXEC, [test "x$MPIEXEC" != "xtrue"])
+# Used to generate MBmpi.h
+if test "xyes" = "x$MPI_CXX_HELP_NEEDED"; then
+  AC_DEFINE( [MB_MPI_CXX_CONFLICT], [1],
+    [MPICH_IGNORE_CXX_SEEK is not sufficient to avoid conflicts] )
+fi
 #                           Python
@@ -1047,8 +1020,7 @@
 AC_ARG_VAR([FC], [FORTRAN compiler command])
 AC_CONFIG_HEADERS([config.h])
-AC_CONFIG_HEADERS([MBVersion.h])
-AC_CONFIG_HEADERS([MBEntityHandle.h])
+AC_CONFIG_HEADERS([MBVersion.h MBEntityHandle.h parallel/MBmpi_config.h])
 AC_CONFIG_HEADERS([iBase_FCDefs.h])
 AC_CONFIG_FILES([Makefile
                  moab.make
Added: MOAB/trunk/m4/mpi.m4
--- MOAB/trunk/m4/mpi.m4	                        (rev 0)
+++ MOAB/trunk/m4/mpi.m4	2009-11-02 19:55:16 UTC (rev 3255)
@@ -0,0 +1,65 @@
+# Macros for MPI configuration.
+# NOTE: The macro to enable/disable MPI support entirely is
+#       in compilers.m4, as it also affects the choice of compiler.
+#       That code is expected to have set WITH_MPI to either 'yes',
+#       'no' or the directory where MPI is installed BEFORE these
+#       macros are called.
+# Options and configuration for mpiexec.  Sets
+# the following variables:
+#   USE_MPIEXEC - AM_CONDITIONAL, true if MPIEXEC is valid
+#   MPIEXEC     - mpiexec binary
+#   MPIEXEC_NP  - mpiexec CLI flag to specify number of procs (e.g. '-np')
+#   NP          - number of procs to use during testing
+AC_DEFUN([FATHOM_CONFIG_MPI_EXEC],[
+  AC_ARG_VAR(MPIEXEC,[Program to use to run parallel tests (default: mpiexec or mpirun)])
+  AC_ARG_VAR(MPIEXEC_NP,[Command line flag to specify number of processors to use (default: -np)])
+  AC_ARG_VAR(NP,[Number of processors to on which to run parallel tests (default: 2)])
+  if test "x$WITH_MPI" != "xno"; then
+    if test "x$MPIEXEC" = "x"; then
+      if test "x$WITH_MPI" != "xyes"; then
+        AC_CHECK_PROGS([MPIEXEC],[mpiexec mpirun],[true],[${WITH_MPI}:${WITH_MPI}/bin])
+      else
+        AC_CHECK_PROGS([MPIEXEC],[mpiexec mpirun],[true])
+      fi
+    fi
+    if test "x$MPIEXEC_NP" = "x"; then
+      MPIEXEC_NP="-np"
+    fi
+    if test "x$NP" = "x"; then
+      NP=2
+    fi
+  fi
+  AM_CONDITIONAL(USE_MPIEXEC, [test "xtrue" != "x$MPIEXEC"])
+# Check for MPI library and MPI.h
+# Error if not found.
+# Defines MPI_CXX_HELP_NEEDED to yes if, when parsed with a c++ compiler,
+# mpi.h conflicts with the C standard library for the definition of SEEK_SET,
+# etc. and defining MPICH_IGNORE_CXX_SEEK is not sufficient to work around
+# the problem.
+AC_DEFUN([FATHOM_CHECK_MPI], [
+    AC_LANG_PUSH([C])
+    AC_CHECK_HEADER([mpi.h],[],[AC_MSG_ERROR([mpi.h not found or not working])])
+    AC_LANG_POP([C])
+    AC_MSG_CHECKING([If mpi.h conflicts with C headers in C++])
+    AC_LANG_PUSH([C++])
+    AC_PREPROC_IFELSE(
+      [AC_LANG_PROGRAM([#include <stdio.h>
+                        #include <mpi.h>],[])],
+      [MPI_CXX_HELP_NEEDED=no; AC_MSG_RESULT([no])],
+      [AC_PREPROC_IFELSE(
+                          #define MPICH_IGNORE_CXX_SEEK
+        [MPI_CXX_HELP_NEEDED=no; AC_MSG_RESULT([MPICH_IGNORE_CXX_SEEK])],
+        [MPI_CXX_HELP_NEEDED=yes; AC_MSG_RESULT([yes])])
+    AC_LANG_POP([C++])
+  fi
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/parallel/MBParallelComm.cpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -40,7 +40,7 @@
 #ifdef USE_MPI
-#include "mpi.h"
+#include "MBmpi.h"
 #endif
 const unsigned int INITIAL_BUFF_SIZE = 1024;
Modified: MOAB/trunk/parallel/MBParallelComm.hpp
--- MOAB/trunk/parallel/MBParallelComm.hpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/parallel/MBParallelComm.hpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -33,37 +33,8 @@
 #include <set>
 #include <vector>
 #include "math.h"
+#include "MBmpi.h"
-#ifdef SEEK_SET
-#  define SEEK_SET_OLD SEEK_SET
-#  undef SEEK_SET
-#endif
-#ifdef SEEK_CUR
-#  define SEEK_CUR_OLD SEEK_CUR
-#  undef SEEK_CUR
-#endif
-#ifdef SEEK_END
-#  define SEEK_END_OLD SEEK_END
-#  undef SEEK_END
-#endif
-#include "mpi.h"
-#ifdef SEEK_SET_OLD
-#  undef SEEK_SET
-#  define SEEK_SET SEEK_SET_OLD
-#  undef SEEK_SET_OLD
-#endif
-#ifdef SEEK_CUR_OLD
-#  undef SEEK_CUR
-#  define SEEK_CUR SEEK_CUR_OLD
-#  undef SEEK_CUR_OLD
-#endif
-#ifdef SEEK_END_OLD
-#  undef SEEK_END
-#  define SEEK_END SEEK_END_OLD
-#  undef SEEK_END_OLD
-#endif
 extern "C" {
   struct tuple_list;
Modified: MOAB/trunk/parallel/MBProcConfig.hpp
--- MOAB/trunk/parallel/MBProcConfig.hpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/parallel/MBProcConfig.hpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -23,28 +23,7 @@
 #ifdef USE_MPI
-/* MPICH2 will fail if SEEK_* macros are defined
- * because they are also C++ enums. Undefine them
- * when including mpi.h and then redefine them
- * for sanity.
-#  ifdef SEEK_SET
-#    define MB_SEEK_SET SEEK_SET
-#    define MB_SEEK_CUR SEEK_CUR
-#    define MB_SEEK_END SEEK_END
-#    undef SEEK_SET
-#    undef SEEK_CUR
-#    undef SEEK_END
-#  endif
-#include "mpi.h"
-#  ifdef MB_SEEK_SET
-#    define SEEK_SET MB_SEEK_SET
-#    define SEEK_CUR MB_SEEK_CUR
-#    define SEEK_END MB_SEEK_END
-#    undef MB_SEEK_SET
-#    undef MB_SEEK_CUR
-#    undef MB_SEEK_END
-#  endif
+#include "MBmpi.h"
 extern "C"
 #include "types.h"
Added: MOAB/trunk/parallel/MBmpi.h
--- MOAB/trunk/parallel/MBmpi.h	                        (rev 0)
+++ MOAB/trunk/parallel/MBmpi.h	2009-11-02 19:55:16 UTC (rev 3255)
@@ -0,0 +1,35 @@
+/* MBmpi.h.  Generated from MBmpi.h.in by configure.  */
+#ifndef MB_MPI_H
+#define MB_MPI_H
+#include "MBmpi_config.h"
+#ifndef __cplusplus
+#  include <mpi.h>
+#elif !defined(MB_MPI_CXX_CONFLICT)
+#  ifndef MPICH_IGNORE_CXX_SEEK
+#    define MPICH_IGNORE_CXX_SEEK
+#  endif
+#  include <mpi.h>
+#else
+#  include <stdio.h>
+#  ifdef SEEK_SET
+#    define MB_SEEK_SET SEEK_SET
+#    define MB_SEEK_CUR SEEK_CUR
+#    define MB_SEEK_END SEEK_END
+#    undef SEEK_SET
+#    undef SEEK_CUR
+#    undef SEEK_END
+#  endif
+#  include <mpi.h>
+#  ifdef MB_SEEK_SET
+#    define SEEK_SET MB_SEEK_SET
+#    define SEEK_CUR MB_SEEK_CUR
+#    define SEEK_END MB_SEEK_END
+#    undef MB_SEEK_SET
+#    undef MB_SEEK_CUR
+#    undef MB_SEEK_END
+#  endif
+#endif
+#endif
Added: MOAB/trunk/parallel/MBmpi_config.h.in
--- MOAB/trunk/parallel/MBmpi_config.h.in	                        (rev 0)
+++ MOAB/trunk/parallel/MBmpi_config.h.in	2009-11-02 19:55:16 UTC (rev 3255)
@@ -0,0 +1,2 @@
+/* MPICH_IGNORE_CXX_SEEK is not sufficient to avoid conflicts */
+#undef MB_MPI_CXX_CONFLICT
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.cpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.cpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.cpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -22,7 +22,7 @@
 #include <iostream>
 #include <sstream>
-#include <mpi.h>
+#include "MBmpi.h"
 #include <H5Tpublic.h>
 #include <H5Ppublic.h>
Modified: MOAB/trunk/parallel/WriteHDF5Parallel.hpp
--- MOAB/trunk/parallel/WriteHDF5Parallel.hpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/parallel/WriteHDF5Parallel.hpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -9,7 +9,7 @@
 #define WRITE_HDF5_PARALLEL_HPP
 #include "WriteHDF5.hpp"
-#include <mpi.h>
+#include "MBmpi.h"
 #include <map>
 struct RemoteSetData;
Modified: MOAB/trunk/parallel/crystal.c
--- MOAB/trunk/parallel/crystal.c	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/parallel/crystal.c	2009-11-02 19:55:16 UTC (rev 3255)
@@ -48,7 +48,7 @@
 #include <stdlib.h>
 #include <stdarg.h>
 #include <string.h>
-#include <mpi.h>
+#include "MBmpi.h"
 #include "errmem.h"
 #include "types.h"
Modified: MOAB/trunk/parallel/fcrystal.c
--- MOAB/trunk/parallel/fcrystal.c	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/parallel/fcrystal.c	2009-11-02 19:55:16 UTC (rev 3255)
@@ -28,7 +28,7 @@
 #include <stdlib.h>
 #include <stdarg.h>
 #ifdef MPI
-#  include <mpi.h>
 #endif
 #include "fname.h"
Modified: MOAB/trunk/parallel/gs.c
--- MOAB/trunk/parallel/gs.c	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/parallel/gs.c	2009-11-02 19:55:16 UTC (rev 3255)
@@ -71,7 +71,7 @@
 #include <string.h>
 #include <math.h>
 #ifdef USE_MPI
-#  include <mpi.h>
 #endif
 #include "errmem.h"
Modified: MOAB/trunk/parallel/mbparallelcomm_test.cpp
--- MOAB/trunk/parallel/mbparallelcomm_test.cpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/parallel/mbparallelcomm_test.cpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -16,7 +16,7 @@
 #include "StructuredElementSeq.hpp"
 #include "SequenceManager.hpp"
 #include "MBError.hpp"
-#include "mpi.h"
+#include "MBmpi.h"
 #include <iostream>
 #include <sstream>
 #include <assert.h>
Modified: MOAB/trunk/parallel/parallel_hdf5_test.cc
--- MOAB/trunk/parallel/parallel_hdf5_test.cc	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/parallel/parallel_hdf5_test.cc	2009-11-02 19:55:16 UTC (rev 3255)
@@ -10,7 +10,7 @@
 #include <iostream>
 #include <sstream>
 #include <algorithm>
-#include <mpi.h>
+#include "MBmpi.h"
 #include <unistd.h>
 #include <float.h>
 #include <stdio.h>
Modified: MOAB/trunk/parallel/parallel_unit_tests.cpp
--- MOAB/trunk/parallel/parallel_unit_tests.cpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/parallel/parallel_unit_tests.cpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -4,7 +4,7 @@
 #include "FileOptions.hpp"
 #include "MBTagConventions.hpp"
 #include "MBCore.hpp"
-#include "mpi.h"
+#include "MBmpi.h"
 #include <iostream>
 #include <sstream>
Modified: MOAB/trunk/parallel/parallel_write_test.cc
--- MOAB/trunk/parallel/parallel_write_test.cc	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/parallel/parallel_write_test.cc	2009-11-02 19:55:16 UTC (rev 3255)
@@ -1,7 +1,7 @@
-#include <mpi.h>
+#include "MBmpi.h"
 #include <stdlib.h>
 #include <iostream>
 #include <time.h>
Modified: MOAB/trunk/parallel/pcomm_unit.cpp
--- MOAB/trunk/parallel/pcomm_unit.cpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/parallel/pcomm_unit.cpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -12,7 +12,7 @@
 #include <sstream>
 #ifdef USE_MPI
-#  include <mpi.h>
 #endif
 #define STRINGIFY_(X) #X
Modified: MOAB/trunk/parallel/transfer.c
--- MOAB/trunk/parallel/transfer.c	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/parallel/transfer.c	2009-11-02 19:55:16 UTC (rev 3255)
@@ -5,7 +5,7 @@
 #include <stdlib.h>
 #include <stdarg.h>
 #include <math.h>
-#include <mpi.h>
+#include "MBmpi.h"
 #include "errmem.h"
 #include "types.h"
 #include "minmax.h"
Modified: MOAB/trunk/parallel/uber_parallel_test.cpp
--- MOAB/trunk/parallel/uber_parallel_test.cpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/parallel/uber_parallel_test.cpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -4,7 +4,7 @@
-#include "mpi.h"
+#include "MBmpi.h"
 #include <iostream>
 #include <sstream>
Modified: MOAB/trunk/refiner/MBMeshRefiner.cpp
--- MOAB/trunk/refiner/MBMeshRefiner.cpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/refiner/MBMeshRefiner.cpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -8,7 +8,7 @@
 #ifdef USE_MPI
-#include <mpi.h>
+#include "MBmpi.h"
 #else // USE_MPI
 typedef int MPI_Comm;
 #endif // USE_MPI
Modified: MOAB/trunk/refiner/test_mesh_refiner.cpp
--- MOAB/trunk/refiner/test_mesh_refiner.cpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/refiner/test_mesh_refiner.cpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -9,7 +9,7 @@
-#include "mpi.h"
+#include "MBmpi.h"
 #endif // USE_MPI
 #include <iostream>
Modified: MOAB/trunk/tools/Makefile.am
--- MOAB/trunk/tools/Makefile.am	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/tools/Makefile.am	2009-11-02 19:55:16 UTC (rev 3255)
@@ -1,6 +1,9 @@
 AUTOMAKE_OPTIONS = foreign
 DEFS = $(DEFINES)
-INCLUDES += -I$(top_srcdir) -I$(top_builddir)
+INCLUDES += -I$(top_srcdir) \
+            -I$(top_builddir) \
+            -I$(top_srcdir)/parallel \
+            -I$(top_builddir)/parallel
 LDADD = $(top_builddir)/libMOAB.la
 # For old (pre 1.10.x) versions of Automake
Modified: MOAB/trunk/tools/convert.cpp
--- MOAB/trunk/tools/convert.cpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/tools/convert.cpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -36,7 +36,7 @@
 #endif
 #include <time.h>
 #ifdef USE_MPI
-#  include <mpi.h>
 #endif
 #include <stdio.h>
Modified: MOAB/trunk/tools/iMesh/iMeshP.h
--- MOAB/trunk/tools/iMesh/iMeshP.h	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/tools/iMesh/iMeshP.h	2009-11-02 19:55:16 UTC (rev 3255)
@@ -4,7 +4,7 @@
 #include "iMesh.h"
 #include "iMeshP_protos.h"
-#include <mpi.h>
+#include "MBmpi.h"
 #ifdef __cplusplus
 extern "C" {
Modified: MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -16,7 +16,7 @@
 #include <sstream>
 #ifdef USE_MPI
-#include "mpi.h"
+#include "MBmpi.h"
 #endif
 /********************* Error Handling **************************/
Modified: MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp
--- MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -1,5 +1,5 @@
 #include "iMeshP.h"
-#include <mpi.h>
+#include "MBmpi.h"
 #include <iostream>
 #include <vector>
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -10,7 +10,7 @@
 #undef IS_BUILDING_MB
 #ifdef USE_MPI
-#include "mpi.h"
+#include "MBmpi.h"
 #endif
 #include <iostream>
Modified: MOAB/trunk/tools/iMesh/partest.cpp
--- MOAB/trunk/tools/iMesh/partest.cpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/tools/iMesh/partest.cpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -1,7 +1,7 @@
 #include <iostream>
 #include <stdio.h>
 #include <string.h>
-#include "mpi.h"
+#include "MBmpi.h"
 #include "iMesh.h"
Modified: MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp
--- MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/tools/mbcoupler/mbcoupler_test.cpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -4,7 +4,7 @@
 #include "MBCoupler.hpp"
-#include "mpi.h"
+#include "MBmpi.h"
 #include <iostream>
 #include <sstream>
 #include <assert.h>
Modified: MOAB/trunk/tools/mbzoltan/MBZoltan.hpp
--- MOAB/trunk/tools/mbzoltan/MBZoltan.hpp	2009-10-30 07:09:30 UTC (rev 3254)
+++ MOAB/trunk/tools/mbzoltan/MBZoltan.hpp	2009-11-02 19:55:16 UTC (rev 3255)
@@ -23,6 +23,7 @@
 #define MB_ZOLTAN_HPP
 #include <stdlib.h>
+#include "MBmpi.h"
 #include "zoltan_cpp.h"
 extern "C"
