[MOAB-dev] MBInterface API changes for meshsets
Jason Kraftcheck
kraftche at cae.wisc.edu
Tue Oct 27 15:59:47 CDT 2009
MOAB currently defines the following enum in MBTypes.h:
/** Meshset options: properties for meshset creation.
* Values are bit flags that may be combined with a bitwise OR (|)
enum MBEntitySetProperty {
MESHSET_TRACK_OWNER = 0x1, /**< create entity to meshset adjacencies */
MESHSET_SET = 0x2, /**< set contents are unique */
MESHSET_ORDERED = 0x4 /**< order of set contents is preserved */
and has the following three functions in MBInterface that interact with this
enum:
MBErrorCode create_meshset(const unsigned int options,
MBEntityHandle &ms_handle,
int start_id = 0) = 0;
MBErrorCode get_meshset_options(const MBEntityHandle ms_handle,
unsigned int& options) const = 0;
MBErrorCode set_meshset_options(const MBEntityHandle ms_handle,
const unsigned int options) = 0;
This API is somewhat confusing for two reasons:
a) We pass a bitwise-OR of the MBEntitySetProperty values an int,
but the latter two are mutually exclusive in the implementation.
b) The get/set paradigm for the options is not very convenient (and
potentially error prone) because one needs to get the previous
options and flip bits to make sure that some property (e.g.
tracking) isn't accidentally disabled. For example, doing:
set_meshset_options( my_set, MESHSET_SET )
may will remove the MESHSET_TRACK_OWNER property, if it is set.
I think that the API would be easier to understand and less error prone if
we instead had:
enum MBEntitySetStorage { MESHSET_SET, MESHSET_ORDERED };
MBErrorCode create_meshset( MBEntitySetStorage type,
MBEntityHandle& ms_handle,
bool tracking = false,
int start_id = 0 ) = 0;
MBErrorCode get_meshset_options( MBEntityHandle ms_handle,
MBEntitySetStorage& storage,
bool& is_tracking ) = 0;
MBErrorCode set_meshset_tracking( MBEntityHandle ms_handle,
bool tracking ) = 0;
MBErrorCode set_meshset_storage( MBEntityHandle ms_handle,
MBEntitySetStorage type ) = 0;
Any opinions?
- jason
