[MOAB-dev] iMesh vs. MOAB format for string options
Tim Tautges tautges at mcs.anl.gov
Tue Oct 27 11:51:58 CDT 2009
As I discussed earlier with Jason, I'm on the fence about this.  Always putting a delimiter at the front of the string
looks goofy for single-option strings.  Handling options differently between MOAB and iMesh is error-prone.  The
question boils down to: be consistent with (what we view as) a flawed standard, or be inconsistent and risk (somewhat
infrequent) errors that result from that inconsistency.
And, phrasing the question in this way, I guess I feel that it's better to be consistent, even though the resulting code
looks goofy.  Opinions?  Note, this would require changes to existing applications.
- tim
Jason Kraftcheck wrote:
> Both MOAB and iMesh have functions that are passed an optional string
> containing options (e.g. iMesh_loadMesh, iMesh_newMesh, and
> MBInterface::load_file).  The format used by the two interfaces is slightly
> different.  The MOAB format uses a ';' to separate multiple options, with a
> mechanism to request an alternate separator if necessary.  For example:
>   BINARY
>  or
>   PARALLEL=BCAST;MPI_ROOT=1
>  or
>   ;+PARALLEL=BCAST+MPI_ROOT=1
> The iMesh format requires that the desired separator always be the first
> character in the options string.  For example:
>   ;BINARY
>  or
>   ;PARALLEL=BCAST;MPI_ROOT=1
>  or
> In the MOAB implementation of the iMesh API, the functions that accept
> option strings convert the string from iMesh to MOAB format before passing
> it to an MBInterface function.
> Does anyone feel strongly that we should change the MOAB format to be
> consistent with the iMesh one?
> - jason
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
