[MOAB-dev] [cgma-dev]  Problems with ReadCGM
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Tue Oct 27 09:03:26 CDT 2009
Tim Tautges wrote:
> This might be related to calling the wrong overloaded function in CGM,
> for get_graphics or something related to it.
It shouldn't be possible to call the wrong overloaded function (C++ name
mangling.)  Changing vtables would cause this, but I don't think we're
calling any virtual functions.  Is the get_graphics call in GQT or RefEdge?
> Could you run the cubit-based code under gdb, stop in
> GeometryQueryEngine::get_graphics (all instances, if multiple), and
> print a stack trace?  That would help determine which variants are being
> called on the way down to the function.
As a last resort, you could try running it in valgrind.
- jason
