[MOAB-dev] r3229 - MOAB/trunk/tools/iMesh
kraftche at cae.wisc.edu
Tue Oct 20 08:47:04 CDT 2009
Author: kraftche
Date: 2009-10-20 08:47:04 -0500 (Tue, 20 Oct 2009)
New Revision: 3229
Modified:
MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
Fix code that assumes iMesh_processError will update the local *err.
Most of the code does not make that assumption, and removing it entirely
allows iMesh_processError to be a function rather than a macro.
Fixes failing test.
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2009-10-20 02:00:20 UTC (rev 3228)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2009-10-20 13:47:04 UTC (rev 3229)
@@ -1728,7 +1728,7 @@
msg += std::string(tag_name) + std::string("'");
iMesh_processError(iBase_ERROR_MAP[result], msg.c_str());
*tag_handle = 0;
- return;
+ RETURN(iBase_ERROR_MAP[result]);
iMesh_LAST_ERROR.error_type = iBase_SUCCESS;
@@ -2889,7 +2889,8 @@
std::string msg("MBMesh::tag_set_vertices: getting entities didn't succeed., with error type: ");
msg += MBI->get_error_string(result);
- return result;
+ *err = iBase_ERROR_MAP[result];
+ return MB_FAILURE;
// remove any sets
@@ -2903,6 +2904,7 @@
std::string msg("MBMesh::tag_set_vertices: getting vertices didn't succeed., with error type: ");
return result;
@@ -2914,6 +2916,7 @@
std::string msg("MBMesh::tag_set_vertices: couldn't make tag., with error type: ");
return result;
@@ -2925,6 +2928,7 @@
std::string msg("MBMesh::tag_set_vertices: couldn't set pos_tag., with error type: ");
return result;
