[MOAB-dev] r3226 - MOAB/trunk/tools/iMesh
kraftche at cae.wisc.edu
Mon Oct 19 20:57:17 CDT 2009
Author: kraftche
Date: 2009-10-19 20:57:17 -0500 (Mon, 19 Oct 2009)
New Revision: 3226
Modified:
MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
o add missing includes
o fix potential buffer overflow in error handling
o fix potential read of invalid memory in error
handling (use stdcpy rather than sprintf to avoid
read of non-existent argument if string contains a '%')
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2009-10-20 01:55:29 UTC (rev 3225)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2009-10-20 01:57:17 UTC (rev 3226)
@@ -15,6 +15,9 @@
#include <iostream>
#include <cassert>
+#include <cstring>
+#include <stdarg.h>
+#include <stdio.h>
#define MIN(a,b) (a < b ? a : b)
MBiMesh::MBiMesh()
@@ -195,10 +198,14 @@
return reinterpret_cast<iMesh_EntityIterator>(iter);
+static inline void
+iMesh_processError( iBase_ErrorType code, const char* desc )
+ std::strncpy( iMesh_LAST_ERROR.description, desc,
+ sizeof(iMesh_LAST_ERROR.description) );
+ iMesh_LAST_ERROR.error_type = code;
-#define iMesh_processError(a, b) {sprintf(iMesh_LAST_ERROR.description, "%s", b); iMesh_LAST_ERROR.error_type = a; *err = a;}
#ifdef __cplusplus
extern "C" {
#endif
@@ -1631,7 +1638,7 @@
static ::std::string name;
MBErrorCode result = MBI->tag_get_name(TAG_HANDLE(tag_handle), name);
if (MB_SUCCESS != result)
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getTagName: problem getting name.")
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getTagName: problem getting name.");
else
iMesh_LAST_ERROR.error_type = iBase_SUCCESS;
@@ -1667,7 +1674,7 @@
MBErrorCode result = MBI->tag_get_size(TAG_HANDLE(tag_handle), *tag_size_val);
- iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getTagSize: problem getting size.")
+ iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getTagSize: problem getting size.");
else {
int this_type;
int success;
@@ -1701,7 +1708,7 @@
MBErrorCode result = MBI->tag_get_size(TAG_HANDLE(tag_handle), *tag_size_bytes);
else {
