[MOAB-dev] r3192 - MOAB/trunk/tools/dagmc
bmsmith6 at wisc.edu
Tue Oct 6 09:47:06 CDT 2009
Author: bmsmith
Date: 2009-10-06 09:47:06 -0500 (Tue, 06 Oct 2009)
New Revision: 3192
Removed:
MOAB/trunk/tools/dagmc/cgm2moab.cc
MOAB/trunk/tools/dagmc/cgm2moab.hpp
Modified:
MOAB/trunk/tools/dagmc/CMakeLists.txt
MOAB/trunk/tools/dagmc/DagMC.cpp
MOAB/trunk/tools/dagmc/Makefile.am
MOAB/trunk/tools/dagmc/cub2h5m.cc
MOAB/trunk/tools/dagmc/main.cc
Log:
Remove code that exists in ReadCGM.
Modified: MOAB/trunk/tools/dagmc/CMakeLists.txt
--- MOAB/trunk/tools/dagmc/CMakeLists.txt 2009-10-02 16:32:41 UTC (rev 3191)
+++ MOAB/trunk/tools/dagmc/CMakeLists.txt 2009-10-06 14:47:06 UTC (rev 3192)
@@ -17,7 +17,6 @@
if ( CGM_FOUND )
set( MOAB_DAGMC_LIB_SRCS
${MOAB_DAGMC_LIB_SRCS}
- cgm2moab.cc
set( MOAB_DAGMC_SRCS
main.cc
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp 2009-10-02 16:32:41 UTC (rev 3191)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp 2009-10-06 14:47:06 UTC (rev 3192)
@@ -14,7 +14,6 @@
#include "CubitVector.hpp"
#include "RefFace.hpp"
#include "RefVolume.hpp"
-#include "cgm2moab.hpp"
#endif
#include <string>
Modified: MOAB/trunk/tools/dagmc/Makefile.am
--- MOAB/trunk/tools/dagmc/Makefile.am 2009-10-02 16:32:41 UTC (rev 3191)
+++ MOAB/trunk/tools/dagmc/Makefile.am 2009-10-06 14:47:06 UTC (rev 3192)
@@ -6,15 +6,13 @@
lib_LTLIBRARIES = libdagmc.la
libdagmc_la_SOURCES = DagMC.cpp
libdagmc_la_includedir = $(includedir)
-libdagmc_la_include_HEADERS = cgm2moab.hpp cubfile.h DagMC.hpp
+libdagmc_la_include_HEADERS = cubfile.h DagMC.hpp
if HAVE_CGM
INCLUDES += $(CGM_INCLUDES)
CPPFLAGS += $(CGM_CPPFLAGS) -DCGM $(MOAB_CGM_DEFINES)
CXXFLAGS += $(CGM_CXXFLAGS)
-libdagmc_la_SOURCES += cgm2moab.cc
noinst_PROGRAMS = update_coords quads_to_tris
bin_PROGRAMS = cgm2moab
cgm2moab_SOURCES = main.cc cubfile.c
Deleted: MOAB/trunk/tools/dagmc/cgm2moab.cc
--- MOAB/trunk/tools/dagmc/cgm2moab.cc 2009-10-02 16:32:41 UTC (rev 3191)
+++ MOAB/trunk/tools/dagmc/cgm2moab.cc 2009-10-06 14:47:06 UTC (rev 3192)
@@ -1,453 +0,0 @@
-#include "GeometryQueryTool.hpp"
-#include "GeometryQueryEngine.hpp"
-#include "ModelQueryEngine.hpp"
-#include "RefEntityName.hpp"
-#include "GMem.hpp"
-#include "RefGroup.hpp"
-#include "RefVolume.hpp"
-#include "RefFace.hpp"
-#include "RefEdge.hpp"
-#include "RefVertex.hpp"
-#include "SenseEntity.hpp"
-#include "Surface.hpp"
-#include "Curve.hpp"
-#include "MBCore.hpp"
-#include "MBInterface.hpp"
-#include "MBRange.hpp"
-#include "MBTagConventions.hpp"
-#include "GeomTopoTool.hpp"
-#include <stdio.h>
-#include <algorithm>
-// default settings
-const char DEFAULT_NAME[] = "cgm2moab";
-// settings
-const char* name = DEFAULT_NAME;
-const char* file_type = 0;
-// copy geometry into mesh database
-bool cgm2moab(MBInterface* iface,
- double faceting_tol,
- int norm_tol,
- double len_tol,
- int actuate_attribs)
- MBErrorCode rval;
- GeomTopoTool geomTool(iface);
- // get some tag handles
- MBTag geom_tag, id_tag, name_tag, category_tag;
- rval = iface->tag_create( GEOM_DIMENSION_TAG_NAME, sizeof(int), MB_TAG_SPARSE,
- MB_TYPE_INTEGER, geom_tag, 0, true );
- assert(!rval);
- rval = iface->tag_create( GLOBAL_ID_TAG_NAME, sizeof(int), MB_TAG_DENSE,
- MB_TYPE_INTEGER, id_tag, 0, true );
- assert(!rval);
- rval = iface->tag_create( NAME_TAG_NAME, NAME_TAG_SIZE, MB_TAG_SPARSE,
- MB_TYPE_OPAQUE, name_tag, 0, true );
- assert(!rval);
- std::vector<MBTag> extra_name_tags;
- rval = iface->tag_create( CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE,
- MB_TAG_SPARSE, MB_TYPE_OPAQUE, category_tag, 0, true );
- assert(!rval);
- // CGM data
- std::map<RefEntity*,MBEntityHandle> entmap[5]; // one for each dim, and one for groups
- std::map<RefEntity*,MBEntityHandle>::iterator ci;
- const char geom_categories[][CATEGORY_TAG_SIZE] =
- {"Vertex\0", "Curve\0", "Surface\0", "Volume\0", "Group\0"};
- const char* const names[] = { "Vertex", "Curve", "Surface", "Volume"};
- DLIList<RefEntity*> entlist;
- DLIList<ModelEntity*> me_list;
- // create entity sets for all geometric entities
- for (int dim = 0; dim < 4; ++dim) {
- entlist.clean_out();
- GeometryQueryTool::instance()->ref_entity_list( names[dim], entlist, true );
- entlist.reset();
- for (int i = entlist.size(); i--; ) {
- RefEntity* ent = entlist.get_and_step();
- MBEntityHandle handle;
- rval = iface->create_meshset( dim == 1 ? MESHSET_ORDERED : MESHSET_SET, handle );
- if (MB_SUCCESS != rval)
- return false;
- entmap[dim][ent] = handle;
- rval = iface->tag_set_data( geom_tag, &handle, 1, &dim );
- return rval;
- int id = ent->id();
- rval = iface->tag_set_data( id_tag, &handle, 1, &id );
- return rval;
- rval = iface->tag_set_data( category_tag, &handle, 1, &geom_categories[dim] );
- return rval;
- // create topology for all geometric entities
- for (int dim = 1; dim < 4; ++dim) {
- for (ci = entmap[dim].begin(); ci != entmap[dim].end(); ++ci) {
- ci->first->get_child_ref_entities( entlist );
- entlist.reset();
- MBEntityHandle h = entmap[dim-1][ent];
- rval = iface->add_parent_child( ci->second, h );
- return false;
- // store CoFace senses
- for (ci = entmap[2].begin(); ci != entmap[2].end(); ++ci) {
- RefFace* face = (RefFace*)(ci->first);
- BasicTopologyEntity *forward = 0, *reverse = 0;
- for (SenseEntity* cf = face->get_first_sense_entity_ptr();
- cf; cf = cf->next_on_bte()) {
- BasicTopologyEntity* vol = cf->get_parent_basic_topology_entity_ptr();
- if (cf->get_sense() == CUBIT_UNKNOWN ||
- cf->get_sense() != face->get_surface_ptr()->bridge_sense()) {
- if (reverse) {
- std::cout << "Surface " << face->id() << " has reverse senes " <<
- "with multiple volume " << reverse->id() << " and " <<
- "volume " << vol->id() << std::endl;
- return false;
- reverse = vol;
- cf->get_sense() == face->get_surface_ptr()->bridge_sense()) {
- if (forward) {
- std::cout << "Surface " << face->id() << " has forward senes " <<
- "with multiple volume " << forward->id() << " and " <<
- return false;
- forward = vol;
- if (forward) {
- rval = geomTool.set_sense( ci->second, entmap[3][forward], true );
- return rval;
- if (reverse) {
- rval = geomTool.set_sense( ci->second, entmap[3][reverse], false );
- return rval;
- // create entity sets for all ref groups
- DLIList<CubitString*> name_list;
- GeometryQueryTool::instance()->ref_entity_list( "group", entlist );
- entlist.reset();
- RefEntity* grp = entlist.get_and_step();
- name_list.clean_out();
- RefEntityName::instance()->get_refentity_name( grp, name_list, true );
- if (name_list.size() == 0)
- continue;
- name_list.reset();
- CubitString name = *name_list.get();
- MBEntityHandle h;
- rval = iface->create_meshset( MESHSET_SET, h );
- return false;
- char namebuf[NAME_TAG_SIZE];
- memset( namebuf, '\0', NAME_TAG_SIZE );
- strncpy( namebuf, name.c_str(), NAME_TAG_SIZE - 1 );
- if (name.length() >= (unsigned)NAME_TAG_SIZE)
- std::cout << "WARNING: group name '" << name.c_str()
- << "' truncated to '" << namebuf << "'" << std::endl;
- rval = iface->tag_set_data( name_tag, &h, 1, namebuf );
- return false;
- int id = grp->id();
- rval = iface->tag_set_data( id_tag, &h, 1, &id );
- return false;
- rval = iface->tag_set_data( category_tag, &h, 1, &geom_categories[4] );
- return false;
- if (name_list.size() > 1) {
- for (int j = extra_name_tags.size(); j < name_list.size(); ++j) {
- sprintf( namebuf, "EXTRA_%s%d", NAME_TAG_NAME, j );
- MBTag t;
- rval = iface->tag_create( namebuf, NAME_TAG_SIZE, MB_TAG_SPARSE, MB_TYPE_OPAQUE, t, 0, true );
- assert(!rval);
- extra_name_tags.push_back(t);
- for (int j = 0; j < name_list.size(); ++j) {
- name = *name_list.get_and_step();
- rval = iface->tag_set_data( extra_name_tags[j], &h, 1, namebuf );
- return false;
- entmap[4][grp] = h;
- // store contents for each group
- entlist.reset();
- for (ci = entmap[4].begin(); ci != entmap[4].end(); ++ci) {
- RefGroup* grp = (RefGroup*)(ci->first);
- grp->get_child_ref_entities( entlist );
- MBRange entities;
- while (entlist.size()) {
- RefEntity* ent = entlist.pop();
- int dim = ent->dimension();
- if (dim < 0) {
- if (entmap[4].find(ent) != entmap[4].end())
- entities.insert( entmap[4][ent] );
- else if (dim < 4) {
- if (entmap[dim].find(ent) != entmap[dim].end())
- entities.insert( entmap[dim][ent] );
- if (!entities.empty()) {
- rval = iface->add_entities( ci->second, entities );
- return false;
- // done with volumes and groups
- entmap[3].clear();
- entmap[4].clear();
- // create geometry for all vertices and replace
- // vertex set handles with vertex handles in map
- for (ci = entmap[0].begin(); ci != entmap[0].end(); ++ci) {
- CubitVector pos = dynamic_cast<RefVertex*>(ci->first)->coordinates();
- double coords[3] = {pos.x(), pos.y(), pos.z()};
- MBEntityHandle vh;
- rval = iface->create_vertex( coords, vh );
- return false;
- rval = iface->add_entities( ci->second, &vh, 1 );
- return false;
- ci->second = vh;
- // create geometry for all curves
- GMem data;
- for (ci = entmap[1].begin(); ci != entmap[1].end(); ++ci) {
- RefEdge* edge = dynamic_cast<RefEdge*>(ci->first);
- Curve* curve = edge->get_curve_ptr();
- GeometryQueryEngine* gqe = curve->get_geometry_query_engine();
- data.clean_out();
- int count;
- CubitStatus s = gqe->get_graphics( curve, count, &data, faceting_tol);
- if (CUBIT_SUCCESS != s)
- return false;
- std::vector<CubitVector> points;
- for (int i = 0; i < data.pointListCount; ++i)
- points.push_back( CubitVector( data.point_list()[i].x,
- data.point_list()[i].y,
- data.point_list()[i].z ) );
- // need to reverse data?
- if (curve->bridge_sense() == CUBIT_REVERSED)
- std::reverse( points.begin(), points.end() );
- // check for closed curve
- RefVertex *start_vtx, *end_vtx;
- start_vtx = edge->start_vertex();
- end_vtx = edge->end_vertex();
- // Special case for point curve
- if (points.size() < 2) {
- if (start_vtx != end_vtx || curve->measure() > gqe->get_sme_resabs_tolerance()) {
- std::cerr << "Warning: No facetting for curve " << edge->id() << std::endl;
- continue;
- MBEntityHandle h = entmap[0][start_vtx];
- rval = iface->add_entities( ci->second, &h, 1 );
- return false;
- continue;
- const bool closed = (points.front() - points.back()).length() < gqe->get_sme_resabs_tolerance();
- if (closed != (start_vtx == end_vtx)) {
- std::cerr << "Warning: topology and geometry inconsistant for possibly closed curve "
- << edge->id() << std::endl;
- // check proximity of vertices to end coordinates
- if ((start_vtx->coordinates() - points.front()).length() > gqe->get_sme_resabs_tolerance()
- || ( end_vtx->coordinates() - points.back() ).length() > gqe->get_sme_resabs_tolerance()) {
- std::cerr << "Warning: vertices not at ends of curve " << edge->id() << std::endl;
- // create interior points
- std::vector<MBEntityHandle> verts, edges;
- verts.push_back( entmap[0][start_vtx] );
- for (size_t i = 1; i < points.size() - 1; ++i) {
- double coords[] = { points[i].x(), points[i].y(), points[i].z() };
- MBEntityHandle h;
- rval = iface->create_vertex( coords, h );
- return false;
- verts.push_back( h );
- verts.push_back( entmap[0][end_vtx] );
- // create edges
- for (size_t i = 0; i < verts.size()-1; ++i) {
- MBEntityHandle h;
- rval = iface->create_element( MBEDGE, &verts[i], 2, h );
- return false;
- edges.push_back( h );
- // if closed, remove duplicate
- if (verts.front() == verts.back())
- verts.pop_back();
- rval = iface->add_entities( ci->second, &verts[0], verts.size() );
- return false;
- rval = iface->add_entities( ci->second, &edges[0], edges.size() );
- return false;
- // create geometry for all surfaces
- RefFace* face = dynamic_cast<RefFace*>(ci->first);
- Surface* surf = face->get_surface_ptr();
- GeometryQueryEngine* gqe = surf->get_geometry_query_engine();
- data.clean_out();
- int nt, np, nf;
- CubitStatus s = gqe->get_graphics( surf, nt, np, nf, &data,
- norm_tol, faceting_tol, len_tol);
- return false;
- // declare array of all vertex handles
- std::vector<MBEntityHandle> verts( data.pointListCount, 0 );
- // get list of vertices in surface
- me_list.clean_out();
- ModelQueryEngine::instance()->query_model( *face, DagType::ref_vertex_type(), me_list );
- // for each vertex, find coincident point in facets
- for (int i = me_list.size(); i--; ) {
- RefVertex* vtx = dynamic_cast<RefVertex*>(me_list.get_and_step());
- CubitVector pos = vtx->coordinates();
- for (int j = 0; j < data.pointListCount; ++j) {
- CubitVector vpos( data.point_list()[j].x,
- data.point_list()[j].y,
- data.point_list()[j].z );
- if ((pos - vpos).length_squared() < gqe->get_sme_resabs_tolerance()*gqe->get_sme_resabs_tolerance()) {
- if (verts[j])
- std::cerr << "Warning: Coincident vertices in surface " << face->id() << std::endl;
- verts[j] = entmap[0][vtx];
- break;
- // now create vertices for the remaining points in the facetting
- for (int i = 0; i < data.pointListCount; ++i) {
- if (verts[i]) // if a geometric vertex
- continue;
- double coords[] = { data.point_list()[i].x,
- data.point_list()[i].z };
- rval = iface->create_vertex( coords, verts[i] );
- return rval;
- // now create facets
- MBRange facets;
- std::vector<MBEntityHandle> corners;
- for (int i = 0; i < data.fListCount; i += data.facet_list()[i]+1) {
- int* facet = data.facet_list() + i;
- corners.resize( *facet );
- for (int j = 1; j <= *facet; ++j) {
- if (facet[j] >= (int)verts.size()) {
- std::cerr << "ERROR: Invalid facet data for surface " << face->id() << std::endl;
- return false;
- corners[j-1] = verts[facet[j]];
- MBEntityType type;
- if (*facet == 3)
- type = MBTRI;
- else {
- std::cerr << "Warning: non-triangle facet in surface " << face->id() << std::endl;
- if (*facet == 4)
- type = MBQUAD;
- else
- type = MBPOLYGON;
- // if (surf->bridge_sense() == CUBIT_REVERSED)
- // std::reverse( corners.begin(), corners.end() );
- MBEntityHandle h;
- rval = iface->create_element( type, &corners[0], corners.size(), h );
- return false;
- facets.insert( h );
- // add vertices and facets to surface set
- return false;
- rval = iface->add_entities( ci->second, facets );
- return false;
- return true;
Deleted: MOAB/trunk/tools/dagmc/cgm2moab.hpp
--- MOAB/trunk/tools/dagmc/cgm2moab.hpp 2009-10-02 16:32:41 UTC (rev 3191)
+++ MOAB/trunk/tools/dagmc/cgm2moab.hpp 2009-10-06 14:47:06 UTC (rev 3192)
@@ -1,22 +0,0 @@
- * Library for determining the type of a geometric model file
- * Copyright 2006, Jason Kraftcheck (kraftche at cae.wisc.edu)
- * This library is free software; you can redistribute it and/or
- * modify it under the terms of the GNU Lesser General Public
- * License as published by the Free Software Foundation; either
- * version 2.1 of the License, or (at your option) any later version.
-#ifndef CGM2MOAB_HPP
-#define CGM2MOAB_HPP
- double faceting_tol = 0.001,
- int norm_tol = 5,
- double len_tol = 0.0,
- int actuate_attribs = true);
-#endif
Modified: MOAB/trunk/tools/dagmc/cub2h5m.cc
--- MOAB/trunk/tools/dagmc/cub2h5m.cc 2009-10-02 16:32:41 UTC (rev 3191)
+++ MOAB/trunk/tools/dagmc/cub2h5m.cc 2009-10-06 14:47:06 UTC (rev 3192)
@@ -2,7 +2,6 @@
#include "InitCGMA.hpp"
#include "CGMApp.hpp"
#include "cubfile.h"
#include "Tqdcfr.hpp"
#include "FileOptions.hpp"
Modified: MOAB/trunk/tools/dagmc/main.cc
--- MOAB/trunk/tools/dagmc/main.cc 2009-10-02 16:32:41 UTC (rev 3191)
+++ MOAB/trunk/tools/dagmc/main.cc 2009-10-06 14:47:06 UTC (rev 3192)
@@ -2,7 +2,6 @@
#define GF_CUBIT_FILE_TYPE "CUBIT"
